Classifieds » Engines, Accessories and other Mechanicals » 1G-GTE Turbos
earthweb
Perth, WA.
1G-GTE Turbos Sat, 11 December 2004 02:15 Go to next message
1G-GTE CT-12 Turbos off my 1988 Soarer GT complete with manifold, dump and metal oil lines.
Reason for selling, I just did a HKS TO4E single turbo conversion yesterday.
Price: $200.
Pics here..
http://www.arach.net.au/~earthweb/pics/TT1.jpg
http://www.arach.net.au/~earthweb/pics/TT2.jpg
http://www.arach.net.au/~earthweb/pics/TT3.jpg
http://www.arach.net.au/~earthweb/pics/TT4.jpg
http://www.arach.net.au/~earthweb/pics/TT5.jpg
- Chris.
[Updated on: Sat, 11 December 2004 02:18]
Gazza53
Re: 1G-GTE Turbos Sat, 11 December 2004 05:45 Go to previous messageGo to next message
What milage is on the turbs please,
any shaft play?
jackel
Re: 1G-GTE Turbos Sat, 11 December 2004 06:36 Go to previous messageGo to next message
as he said ^ Smile
these are off a gen 3 no?
[Updated on: Sat, 11 December 2004 06:38]
earthweb
Perth, WA.
Re: 1G-GTE Turbos Sun, 12 December 2004 04:01 Go to previous messageGo to next message
93,000km rounded off.
There's shaft play, which I assume you would expect from 16 year old turbos. The blades don't touch the housing, so it's probably around .5mm
The turbos were working fine before I took them out.
As for what gen it is, I haven't actually looked at the colour of the ecu plug and injector plugs to tell. I'll have a look this afternoon but if you can tell from the factory boost pressure then it was 8psi.
- Chris.
[Updated on: Sun, 12 December 2004 04:04]
HyDrA
Adelaide, SA
Re: 1G-GTE Turbos Sun, 12 December 2004 05:21 Go to previous messageGo to next message
Probably a gen 2 then.
coronaturbo
Re: 1G-GTE Turbos Sun, 12 December 2004 09:43 Go to previous messageGo to next message
hows the to4 kit go ?
u got a computer?
how much power?
laggy?
earthweb
Perth, WA.
Re: 1G-GTE Turbos Sun, 12 December 2004 22:38 Go to previous messageGo to next message
Hydra and Jackel, must be gen2 as it has a yellow ecu plug and pale green injector tops.
Coronaturbo, it's good. Took a few hours to get the old twin turbos out. Now with the single there's heaps of room plus it weighs less.
I don't have a computer, I've got an Apexi S-AFCII and Apexi S-ITC to tune the airflow for fuel and ignition timing. ITC isn't installed yet and the SAFC still has the twinturbo map on it. So once I get them both tuned again I should see a bigger improvement.
It's not laggy, boost seems to come on earlier since all the exhaust ports fire into the one turbo. It's only set to 10psi on the external 50mm wastegate. I'm not using a boost controller rather I'm using the adjustable spring in the gate. I'm going to set it to 15psi before I get the electronics tuned as I'm pretty sure the standard injectors can handle that.
- Chris.
Adsport
Perth WA
Re: 1G-GTE Turbos Mon, 13 December 2004 06:51 Go to previous messageGo to next message
i will vouch for the good condition of these turbo's i took them out, and have been in the car with them running. they have never seen any more boost than factory and work well. the play in the shafts is very minimal , and is what can be expected from good condition sleeve bearing turbos.
coronaturbo
Re: 1G-GTE Turbos Mon, 13 December 2004 09:19 Go to previous messageGo to next message
mad i might do the same thing
let me know what sort of power u get when its all finished if u dont mind cheers
suss_suzuki
wollongong
Re: 1G-GTE Turbos Mon, 13 December 2004 11:26 Go to previous messageGo to next message
hey earthweb i have sent you an email
earthweb
Perth, WA.
Re: 1G-GTE Turbos Mon, 13 December 2004 22:39 Go to previous messageGo to next message
Shall do coronaturbo.
Suss_suzuki, have replied.
Here's a pic of the single turbo conversion, thanks to Adz for the pic Smile Don't want to talk too much about it otherwise my thread will be send to general discussion.
http://www.members.westnet.com.au/adsport/gz20_t04e1.jpg
- Chris.
indian
south east - melbourne
Re: 1G-GTE Turbos Tue, 14 December 2004 02:40 Go to previous messageGo to next message
nice setup mate , may i ask if ur using the stock intercooler as well and if u dont mind ho much did all this cost
earthweb
Perth, WA.
Re: 1G-GTE Turbos Wed, 15 December 2004 00:40 Go to previous messageGo to next message
No, I'm using a cut down truck intercooler. Used to be on a Nissan DR30 Skyline racecar with a worked FJ-20DET engine.
Cost around the $2.5k mark if you include the electronics aswell.
Oh, the stock 1G-GTE intercooler is for sale aswell for $60.
- Chris.
indian
Re: 1G-GTE Turbos Wed, 15 December 2004 03:07 Go to previous messageGo to next message
cheers for the info matey , hope u get some good figures out of this set up you have im still debating wetr to go single or use the stock setup, as im not after a lot of power , but yeah time will tell , lollllllll Shocked Shocked Shocked Shocked Shocked
earthweb
Perth, WA.
*Sold* Re: 1G-GTE Turbos Fri, 17 December 2004 03:53 Go to previous messageGo to next message
Turbos are now sold.
The twin turbo manifold is still for sale, make an offer + freight and it's yours.
Also have the left hand side intake pipe aswell.
Indian, I know you can convert the CT-12a turbos from the 1J to steel wheel using Toyota Starlet compressor wheels. Might be able to do it the CT-12 turbos from our 1G's. Could be a cheaper option then you could just increase boost to around 15psi safetly.
Regards,
Chris.
indian
Re: *Sold* Re: 1G-GTE Turbos Fri, 17 December 2004 03:57 Go to previous message
YEAH but why bother the ct12 turbos are steel wheeled anyway, too much of stuffing around changing to bigger hweels and all , rather just get the single and be done , but i dont have the money atm Crying or Very Sad Crying or Very Sad Crying or Very Sad Crying or Very Sad Crying or Very Sad Crying or Very Sad
Previous Topic:1GGTE $100 last chance before it becomes an anchor
Next Topic:extractors and exhust 2 suit ta22
Current Time: Wed Oct 21 10:54:41 UTC 2026
Total time taken to generate the page: 0.0084311962127686 seconds
