Toymods » Tech & Conversions » 4AGTE Belt Setups
monkeymajik
4AGTE Belt Setups Sat, 11 December 2004 03:46 Go to next message
Okay, how are toymodders running their belts on 4agte's?
At the moment the alt is currently on the right hand side of the engine (turbo side) on a custom bracket, water pump on the left. Meaning I'm going to need to run two belts most probably. This makes me a sad panda.
If possible I would like to run 1 belt and throw the alt over on the left somewhere.
What are toymodders running? What did you use for brackets? A picture speaks 1000 words Smile
takai
Re: 4AGTE Belt Setups Sat, 11 December 2004 03:52 Go to previous messageGo to next message
Use a 100kw alternator bracket and alternator which will put it on the intake side, you do need the tensioning bracket from the 100kw though.
monkeymajik
Re: 4AGTE Belt Setups Sat, 11 December 2004 04:53 Go to previous messageGo to next message
Will this foul my water pump in a RWD setup? Because I have heard talk of RWD and FWD Alt brackets for the 4age.
[Updated on: Sat, 11 December 2004 04:54]
takai
Re: 4AGTE Belt Setups Sat, 11 December 2004 06:13 Go to previous messageGo to next message
No it wont, thats how they are setup in RWDs. You could probably use a rwd ae86 97kw mount. Maybe a 86kw fwd mount would work too.
Re: 4AGTE Belt Setups Sat, 11 December 2004 13:13 Go to previous messageGo to next message
a couple of very important things to note which could shit you off if you didnt know beforehand!!!
# Smallport 4age top radiator outlet is different to smallport 4A-GZE to rad. outlet!! The 4age one has the bolt holes where the alternator slide bracket is bolted to - the GZE one does not!
# 4A-GZE alternator is a mirror image of the 4A-GE alternator.
# Take the bottom braket (mounts to bottom intake side of block) and the top bracket (the slide one - bolts to top rad outlet) and the top radiator outlet.
On the 4age, the one belt runs from crank to water pump to alternator.. and thats it.
See here (ignoring the PCV shite)
http://www.rollamods.com/witzl/ae71%20conversion/manifolds/PCV-hose-1.jpg
monkeymajik
Re: 4AGTE Belt Setups Sun, 12 December 2004 03:28 Go to previous messageGo to next message
Cheers for that Witzl
I'm using a bigport gze, and will be having a closer look at the workshop tomorrow. Will get a few happy snaps and post up the solution.
EVOSTi
cambo
      no
Re: 4AGTE Belt Setups Sun, 12 December 2004 10:00 Go to previous messageGo to next message
all i did on mine was space out the water pump pulley so that it can run off the same belt as the altenator. its the easiest way. would be a neater job to relocate the altenator but im lazy and wanted results now!
feral4mr2
Bundaberg, Qld.
Re: 4AGTE Belt Setups Sun, 12 December 2004 12:40 Go to previous message
monkeymajik wrote on Sun, 12 December 2004 13:28
i used a bigport 4agze as well, just turned it into a bigport 4age (alt location) and went from there.
Previous Topic:stupid battery question
Next Topic:20v lsd box's
Current Time: Thu Nov 19 22:32:47 UTC 2026
Total time taken to generate the page: 0.0048799514770508 seconds
