Toymods » Tech & Conversions » Low Idle, Pause, and Stalling Help?
sweathers
Low Idle, Pause, and Stalling Help? Mon, 14 October 2002 09:18 Go to next message
Thanks for clicking,
I thought id put it to the more knowledgable sorts a few problems im having.
1/ The car idles at about 520, ive adjusted this up, but in 2 weeks its gone back down. Any idea? This is after its warmed up.
2/ When giving it a abit of a push in 1st or 2nd, it pauses for almost 2 seconds, before lurching forward. Hmmm?
3/ Because the car idles so low, occasionally i catch it swaying between 300-500, on the verge of stalling. Strange. Thoughts?
Methinks the points are in the wrong order...Apologies.
sweathers
Pumpkin
Toymods Board Member
Re: Low Idle, Pause, and Stalling Help? Mon, 14 October 2002 22:35 Go to previous messageGo to next message
What car/ engine?
Re: Low Idle, Pause, and Stalling Help? Mon, 14 October 2002 23:51 Go to previous messageGo to next message
Check for leaks betweek the AFM and the engine, as well as a faulty AFM
ra23celicachick
Mornington Peninsula
Re: Low Idle, Pause, and Stalling Help? Tue, 15 October 2002 02:51 Go to previous messageGo to next message
My 18R-C does the same, but in all gears. I put my foot down and it hesitates for about 2 seconds then launches.
I've adjusted the idel on it plenty of times but it just wont idel under 1000 which is a real pain in the ass. Everytime I go to slow down to a stop I have to rev the car to prevent it from stalling. Confused
Any ideas would be great too.
sweathers
Re: Low Idle, Pause, and Stalling Help? Tue, 15 October 2002 06:29 Go to previous messageGo to next message
Apologies, i should have made mention
Its a ST162 Celica, 3SGE jobbie...
Thing is, its only happened recently.
What makes it worse, is i found it had almost zero oil on the weekend.
Shamefull i know...
jimbo
Bugman
Re: Low Idle, Pause, and Stalling Help? Tue, 15 October 2002 07:00 Go to previous messageGo to next message
celica chick, check your points for wear and most likely replace anyway only $10 or something like that, but it is probably a leaking inleat/exhaust gasket, 18r's are bad when it comes to the gaskets.
ra23celicachick
Re: Low Idle, Pause, and Stalling Help? Tue, 15 October 2002 23:13 Go to previous messageGo to next message
I regulary do services on my car, I've changed the points plenty of times and I replaced the manifold gasket back in January. The timing changes have been replaced I regulary clean my spark plugs, my ignition coil has been replaced. Could it be the leads? Confused
It's a lot worse when it's cold. Like I'll be trying to turn out of my road and it'a a blind corner so you have to put your foot down but my car just chugs then after a few seconds really accelerates. I've had a few close calls. Shocked
ra23celicachick
Re: Low Idle, Pause, and Stalling Help? Fri, 18 October 2002 05:04 Go to previous message
I'm running out of things to replace on my car so I'm running out of ideas to why it does it.
I had a compression test done on it at the start of the year and since we've got all the cylinders working properly it's been a little better but not much.
I've got the engine appart on it all at the moment so any suggestions would really be appreciated.
Thanks Surprised
Previous Topic:Weird rattling/tapping noise on start-up
Next Topic:4A-FC
Current Time: Fri Nov 20 02:57:07 UTC 2026
Total time taken to generate the page: 0.0057940483093262 seconds
