Toymods » Tech & Conversions » ke corolla steering rack conversion
syncro
ireland
ke corolla steering rack conversion Sat, 11 December 2004 07:50 Go to next message
has anybody converted their steering box equipped ke corolla to steering rack and if so what model did you get the parts from?
i have looked at a ke70 rack but its too wide and would need to be narrowed where the inner tie rods mount to use it in my ke11.
(the distance between the bottom arm mounting bolts to the subframe has to be the same as the distance between the inner tie rods)
Re: ke corolla steering rack conversion Sun, 12 December 2004 07:43 Go to previous messageGo to next message
close, the distance between the strut pivot point and the lower arm pivot point must be the same length as the tie rod.
this will mean, using KE10 steering arms, the that rack width is small than the distance between lower arm pivot points (side to side)
syncro
ireland
Re: ke corolla steering rack conversion Tue, 14 December 2004 02:09 Go to previous messageGo to next message
i mean where the two lower arms bolt to the crossmember, this distance should be the same as the distance between the two inner tie rod ends. no room for a rack on a ke 10 with the lower wishbone instead of a lower arm as on a ke20
Re: ke corolla steering rack conversion Tue, 14 December 2004 02:54 Go to previous messageGo to next message
syncro wrote on Tue, 14 December 2004 13:09
nope, think again Wink
the distance you are talking about never changes... but the lower arms change in effective length (due to angle changes) and it is the position of the lower arm with respect to the tierods that is of _utmost_ importance. bump steer is a feature of the geometry between the tierods and the lower arms.. not the distance between lower arms..
Re: ke corolla steering rack conversion Tue, 14 December 2004 04:07 Go to previous messageGo to next message
Howdy, i've spent a lot of time refining my R&P conversion to get it right. Just about there now.. Anyhows, in regards to bump steer...
- this is for a macpherson strut setup. Not double wishbone or anything.
For zero bump steer the control arms and steering arms need to be identical in length. Also they need to be in a parallelogram with each other. eg. The ratio of the difference in height between the control arm inner pivot point and the steering arm inner pivot point, needs to be the same as the difference between the control arm outer pivot point and the steering arm outer pivot point.
Joel
[Updated on: Tue, 14 December 2004 04:08]
syncro
ireland
Re: ke corolla steering rack conversion Tue, 14 December 2004 09:42 Go to previous messageGo to next message
no stewart i mean that the rack length between where the two inner joints pivot has to be the same as the distance between where the two lower arms pivot, the length of the tie rods can be changed easily enough. has anyone found a suitable rack or has anyone shortened a rack to suit a ke 10, 20 or 30.
im thinking if i try it on my ke11 ill need to fit a ke20 crossmember and struts too as the ke 10 and 11 have a lower wishbone.
syncro
ireland
Re: ke corolla steering rack conversion Tue, 14 December 2004 09:53 Go to previous messageGo to next message
fark.. just listen to what joel and i said Wink.. it is the tierod length, angle and position that is critical, and it is the tie rods that determine the rack width. not the other way around...
joel said it very eloquently with:
Joel
heck, don't believe us, just find some good racecar engineering books or call up a competent engineer Smile
twincam_ke20
Castlemaine Vic
Re: ke corolla steering rack conversion Tue, 14 December 2004 10:12 Go to previous messageGo to next message
iv got an ae86 rack steering in my ke25, light as a feather.
Re: ke corolla steering rack conversion Tue, 14 December 2004 22:30 Go to previous messageGo to next message
Yeah I like using the AE86 steering rack (same as KE70). They are cheap to purchase reconditioned - just under $200. Also you can get the quaif (spelling?) quick rack for them. They are one of the narrowest non-powersteer RWD Toyota racks I could find.
There is a small RWD starlet we didn't get in Aus, I think it is a KP60 or something? I've heard these have a smaller rack but would be hard to find.
Joel
Re: ke corolla steering rack conversion Tue, 14 December 2004 23:11 Go to previous messageGo to next message
KE70 rack is nice (Quaife? there's one for sale atm here), but is too wide for KE10.. but if yu swap in the whole KE70 front end and have 4" wider track... now we're talkin Laughing
Re: ke corolla steering rack conversion Tue, 14 December 2004 23:24 Go to previous messageGo to next message
Yeah even in the RA28 the KE70/AE86 rack is around 50mm too wide (25mm per side).
This caused massive bump steer issues as you could imagine. But i've slightly sortened the rack and moved the control arm pivot points out to make up the 25mm each side. Now it feels great Smile plus a wider track, move neg camber.. It's all good.
Just need to get it engineered now which from discussions with the local engineer wont be a problem.
Joel
allencr
tallahassee FL usOFa
Re: ke corolla steering rack conversion Wed, 15 December 2004 14:49 Go to previous messageGo to next message
i don't ever recall anything that had close to the same length suspension arm and tie rod except a purpose built race car. Ackerman(sp?) needs an offset steering knuckle so you're pretty much forced to have a shorter tie rod.
isn't the trick on production cars just keeping them parallel, to minimize the change/bump steer?
I MAY/CAN BE COMPLETELY WRONG.
Re: ke corolla steering rack conversion Wed, 15 December 2004 15:11 Go to previous messageGo to next message
LOL, the way they do it in production cars is to have the tierods as Joel said (when looking from frotn of car), but they mount the rack backwards (when looking from top of car). this way you get the ackermann without the bumpsteer.
the actual relation between the steering knuckle pivot and the tie rod end pivot is not that important for bump steer, but it will affect where the rack needs to be placed for correct ackermann.
actually, on production cars there is a tendency to provide "bump toe-in" so that when joe gumby takes his falcadore too fast thru a corner and hits a bump, it will understeer straigth into a pole Wink (the safest way to crash as opposed to losing tail). having bump induced toe-out is baaad mkay.
no no, the tierod and lower arm length can be the same, the rack doesn't need to be as wide as the lower arm pivots at all... i could draw a pic, but i already have in a previous thread and cbf Wink
Re: ke corolla steering rack conversion Wed, 15 December 2004 21:54 Go to previous messageGo to next message
Yeah like I said when drawn out it is a parallelogram between steering arms and control arms - not a square box.
In the 28 the steering knuckle between the balljoint and outer tie rod is offset by around 10mm for ackerman. So at the rack inner end, it actually sits inbound 10mm of the control arm pivot point.
Production factory cars are not always ideal. In the ae86 which I was using to copy a lot of the steering design from the heights of the control arm and steering arm are quite different and even though i haven't measured it assume it would have some bump steer built into it.
[Updated on: Wed, 15 December 2004 21:56]
syncro
ireland
Re: ke corolla steering rack conversion Thu, 16 December 2004 08:46 Go to previous messageGo to next message
the kp60 rack is narrower than the ke70 rack, i had an ae86 front crossmember,lower arms, rack and struts on my 4age powered ke35 and the front wheels would scrub when turning tightly and it used to bump steer, there was too much neg camber too because the strut tops were too close. i changed it for a crossmember, rack, struts, antirollbar etc from a kp61 starlet and it worked perfectly.
the kp61 rack length between the inner ends was the same as the distance between the lower arm pivots on the starlet crossmember mabey toyota did it this way for shits and giggles or mabey there is a reason for it? if you stick an unshortened rack from a ke70 in to a ke35, with the tie rods shortened to suit, when you hit a bump in the road that wheel will toe in.
i only asked if anyone had come across a suitable rack as the rwd starlets are not available here for the raping of steering racks and other handy components. i did not say the lower arms had to be the same length as the tie rods.
@turbora28 thanks for the info on your conversion, when you say you narrowed the rack do you mean where the inner tie rod ends attach? and you say you moved the lower control arms out 25mm? sounds to me like you were trying to make the distance between the lower arm pivots the same as the distance between your inner tie rod ends.
TA-022
Glenmore Park, NSW
Re: ke corolla steering rack conversion Sun, 19 December 2004 08:08 Go to previous messageGo to next message
any pics joel.... this is sounding like quite a interesting mod.
[Updated on: Sun, 19 December 2004 11:27]
Purple_Beasty
New Zealand
Re: ke corolla steering rack conversion Sun, 19 December 2004 09:09 Go to previous messageGo to next message
Starlet rack shouldn't be that hard to source, just get a few sent over from NZ. There are heaps of rusted out ones floating around.
Callum
Re: ke corolla steering rack conversion Sun, 19 December 2004 22:59 Go to previous messageGo to next message
callum, do you know if the rack ends of the KP will thread into the KE1 or KE2 tierods?? if so, that could be a neat way to go...
Purple_Beasty
New Zealand
Re: ke corolla steering rack conversion Sun, 19 December 2004 23:29 Go to previous messageGo to next message
Sorry, I have a KE25 and a starlet here, but the Starlet no longer has a Starlet rack in it. Embarassed
Callum
Re: ke corolla steering rack conversion Sun, 19 December 2004 23:40 Go to previous messageGo to next message
Purple_Beasty wrote on Mon, 20 December 2004 10:29
Callum
LOL Very Happy no worries, i have more important things to be doing for the moment.. i may have to get back to you about starlet racks if i can't convince an engineer abotu the merits of 4" extra track Wink
Purple_Beasty
New Zealand
Re: ke corolla steering rack conversion Mon, 20 December 2004 00:16 Go to previous messageGo to next message
I consulted a person far more knowledgeable than me so this may help.
Quote:
quote:
Got a quick random question for you.
Would KE10 or 20 tie rod ends screw into a starlet rack?
Callum
God knows if theyre 14mmx1.5 mm most likely if not make them fit i just made tie rods for glenns car as its got high strength 1/2"rose joints for tie rod ends now
syncro
ireland
Re: ke corolla steering rack conversion Wed, 22 December 2004 07:56 Go to previous messageGo to next message
are ke1x and ke2x tierods the same thread as ke3x tierods? i had some ke3x tierods on an ae86 rack a few years ago and from what i remember the starlet and ae86 have the same thread.
Re: ke corolla steering rack conversion Wed, 22 December 2004 08:11 Go to previous messageGo to next message
well... KE10 has two different threads for tie rods, a coarse pitch, and a fine pitch. just to complicate things Wink
syncro
ireland
Re: ke corolla steering rack conversion Fri, 24 December 2004 04:45 Go to previous messageGo to next message
feck never knew that, so chances are the new outer tie rods in my glove box wont fit!
syncro
ireland
Re: ke corolla steering rack conversion Mon, 27 December 2004 02:31 Go to previous messageGo to next message
twincam_ke20 wrote on Tue, 14 December 2004 21:12
how did you fit this to your ke25? did you fit the complete ae86 crossmember, lower arms, struts etc? or did you fab some mounts for the rack and mount it to the ke25 crossmember?
Toycrash
Finland
Re: ke corolla steering rack conversion Sat, 15 October 2005 09:14 Go to previous messageGo to next message
oldcorollas wrote on Wed, 15 December 2004 10:11
Like this Wink
http://www.koti.phnet.fi/crash/Flame/PICT1767_1.jp g
KE70 x-member, lower arms and TA12 struts fitted to KE20. Struts will change to TE71 ones. On image above, strut tops are in stock position,but will be moved outward.
And the rest is here: http://www.koti.phnet.fi/crash/Flame/
Re: ke corolla steering rack conversion Sat, 15 October 2005 09:30 Go to previous messageGo to next message
Pasi, thats MAGIC Smile
how much camber is there is stock position? will the TE7X ones change the stub axle angle? (KPI?)
it's looking very very good Very Happy
Toycrash
Finland
Re: ke corolla steering rack conversion Sat, 15 October 2005 09:42 Go to previous messageGo to next message
I didn't measure the KPI angle, but changing struts cause of thicker axle and wider bearing.
Pics you see are just from test fitting, and havent measured anything, cause some bits will be modified a bit.
domasik
Re: ke corolla steering rack conversion Sun, 16 October 2005 08:55 Go to previous messageGo to next message
also check out this site
www.1uzfe.com
uses wat i believe to be a TE72 steering rack and cut off cross member mounts
Toycrash
Finland
Re: ke corolla steering rack conversion Sun, 16 October 2005 10:51 Go to previous messageGo to next message
domasik wrote on Sun, 16 October 2005 18:55
www.1uzfe.com
Last time i looked, he modified the TE27 x-member to suite starlet's rack&pinion.
And if you do this, you get a load of bump steer Wink
Did some measuring and noticed that TE71 strut has a minimum amount less neg camber (1 or 2 deg) and angle bearing is about 2mm more outward than early TA12 has.
So no significant differences on them.
BradW
Bottom of the hill, Sydney
Re: ke corolla steering rack conversion Sun, 16 October 2005 11:13 Go to previous messageGo to next message
Haven't done any measuring but I was thinking a Mk1 escort steering rack might come close for a KE.
Like I said I haven't done any measuring but it might be another option to investigate.
Toycrash
Finland
Re: ke corolla steering rack conversion Sun, 16 October 2005 12:04 Go to previous messageGo to next message
BradW wrote on Sun, 16 October 2005 21:13
Isn't escort's rack on front side?
domasik
Re: ke corolla steering rack conversion Mon, 17 October 2005 07:04 Go to previous messageGo to next message
Toycrash wrote on Sun, 16 October 2005 20:51
www.1uzfe.com
if you read through carefully u see he actually ends up using the te72 rack and dtches the starlet one
Re: ke corolla steering rack conversion Mon, 17 October 2005 07:18 Go to previous messageGo to next message
domasik wrote on Mon, 17 October 2005 17:04
Te72 track wider than TE27 track = bump steer.... unless you would like to show us otherwise?
Toycrash
Finland
Re: ke corolla steering rack conversion Mon, 17 October 2005 08:24 Go to previous messageGo to next message
[quote title=domasik wrote on Mon, 17 October 2005 17:04
if you read through carefully u see he actually ends up using the te72 rack and dtches the starlet one[/quote]
Nope! He is using TE27 x-member and welded AE72 rack holders in it. For the rack it self, he doesn't say what he is using. He is comparing starlet and MR2 racks. But allso has an AE72 rack...
But as said, if he doesn't shorten the rack, or widen the lower control arm fixing points, he WILL have massive bumpsteer.
And for me, that's not an option.
BradW
Re: ke corolla steering rack conversion Mon, 17 October 2005 10:24 Go to previous messageGo to next message
Toycrash wrote on Sun, 16 October 2005 22:04
Yes, I think you are right, in which case it wont work on the rear of the crossmember.
I'll take my suggestions and leave now Embarassed Laughing
Toycrash
Finland
Re: ke corolla steering rack conversion Mon, 17 October 2005 10:43 Go to previous message
BradW wrote on Mon, 17 October 2005 20:24
Actually it might work...
If you have rhd wehicle, you take lhd rack and flip it around... Razz hmmm... Let's stick with Toyparts Wink
Previous Topic:question on the 4agze
Next Topic:How to cleaning engine for rebuild
Current Time: Sun Nov 1 23:36:48 UTC 2026
Total time taken to generate the page: 0.0081229209899902 seconds
