Toymods » Tech & Conversions » TACHO converter suitable fo high voltage Tacho's
celicamad
newcastle
TACHO converter suitable fo high voltage Tacho's Mon, 14 October 2002 11:19 Go to next message
HIGH all
i had a tacho converter fitted by SIXWORKS yesterday and it works perfect .This unit works on the high voltage input tachos .
So the Cressida's tacho now works compliments of a little grey box .Its easy to install and has an inbuilt test cycle to make sure you set it up right
Because a lot of factory tachos need a high voltage input the 12v units are no good for these
AND best of all it only cost $98
you can get one here sixworks@optusnet.com.au
Bugman
Re: TACHO converter suitable fo high voltage Tacho's Mon, 14 October 2002 13:03 Go to previous messageGo to next message
will this work on a ra28 tacho fitted with a 1g?
Grant
Newcastle, NSW, Australia
Re: TACHO converter suitable fo high voltage Tacho's Mon, 14 October 2002 22:34 Go to previous messageGo to next message
Hello Luke,
All 1G's that I've come across already have a high voltage tacho output from the igniter so your original tacho should work.
Grant
Bugman
Re: TACHO converter suitable fo high voltage Tacho's Tue, 15 October 2002 06:51 Go to previous messageGo to next message
I thought there were problems with running the 1g into the standard tacho, or do you just need it recalibrated or something along them lines?
celicamad
newcastle
Re: TACHO converter suitable fo high voltage Tacho's Tue, 15 October 2002 09:30 Go to previous messageGo to next message
When i fitted the 1ggze to the Celica i just had the tacho modified for a 6 cylinder input .cost about $100.
But the Cressida was FAR more difficult .
The converter That sixworks made has a pre programmed chip on board and actually modifys the original signal output voltage to suit
The Nissan boys will also be very happy
Grant
Re: TACHO converter suitable fo high voltage Tacho's Tue, 15 October 2002 22:04 Go to previous message
Luke,
You are correct. You will need it recalibrated for a 6 cylinder pulse. Most instrument fitters that deal with automotive gear can do it. Cost is usually between $40 and $100 depending on model of Celica.
Previous Topic:Replacing the 7M-GTE Head Gasket
Next Topic:ENGINE INFO
Current Time: Mon Oct 19 19:05:53 UTC 2026
Total time taken to generate the page: 0.079375028610229 seconds
