Toymods » Tech & Conversions » Gearstick switch adjustment ... '85 MX73 Cressida
gpvm
Gearstick switch adjustment ... '85 MX73 Cressida Sun, 12 December 2004 00:46 Go to next message
As you would know, the gear stick must be in park or neutral before the engine will ignite. My problem is that the switch that senses the position of the gearstick appears out of adjustment because I often have to "pull and shove" the stick before ignition happens.
Is there a switch? How do I access it, from beneath the car or down through the internal panels etc? Are there any tricks to fixing this? Any advice would be much appreciated, thanks...
MacroP
Binningup WA
Re: Gearstick switch adjustment ... '85 MX73 Cressida Sun, 12 December 2004 02:31 Go to previous messageGo to next message
Put the car on stands and get under the right side near the gearbox, straight under the drivers seat. It's easiet to have the car jacked up and sitting on the two left wheels and support the weight front and rear on the right side. MX73's are damn low riding cars so are a pain to work on from underneath.
There is a lever the comes down from the shifter and connects to a horizontal rod (about 50cm long)that runs towards the front of the gearbox. This bar in turn connects to the switch in question(via another short lever). The neutral start switch is mounted to the front right side of the gearbox.
You'll see that, where the bar connects to the gearstick/shifter, the connection is adjustable becuase of a slotted hole. Check and adjust here aswell were the small lever actually connects to the gearbox. There is a nut there too that might be loose.
Good luck.
[Updated on: Sun, 12 December 2004 02:33]
gpvm
Re: Gearstick switch adjustment ... '85 MX73 Cressida Mon, 13 December 2004 00:53 Go to previous messageGo to next message
Great, thanks for the reply. Does this mean the lever, bar, switch are all visible without there being a need to remove access covers or anything like that?
MacroP
Binningup WA
Re: Gearstick switch adjustment ... '85 MX73 Cressida Mon, 13 December 2004 01:16 Go to previous messageGo to next message
Yes, it's all done from underneath. No need to rip out any centre console bits inside.
gpvm
Re: Gearstick switch adjustment ... '85 MX73 Cressida Tue, 15 March 2005 09:42 Go to previous messageGo to next message
Well I finally got under the car to check this out but I got worried. By adjusting the position of the lever on the bar using the slotted hole, the position of the switch actuator would move (which is what I want) but I worried the transmission would be affected as well. I worry that this might cause slippage or other transmission problems.
I guess I'll just have to bite the bullet and get out the spanner, see what happens!
Re: Gearstick switch adjustment ... '85 MX73 Cressida Wed, 16 March 2005 00:51 Go to previous messageGo to next message
There is a little 1/4pie shaped thing under there.
Adjust it with that instead.
Undo the little bolt, move it a few degrees.
Re: Gearstick switch adjustment ... '85 MX73 Cressida Wed, 16 March 2005 00:54 Go to previous message
Will look similar to
http://www.oz-enet.com.au/~peewee/1uz_auto_3.jpg
Previous Topic:runnin temp for 1ggte
Next Topic:engine conversion
Current Time: Sat Nov 21 07:27:19 UTC 2026
Total time taken to generate the page: 0.0049319267272949 seconds
