Toymods » Tech & Conversions » speco water temp guage
berad
speco water temp guage Sun, 12 December 2004 04:05 Go to next message
just wondering wat people think about these guages its tellin me water temp is 100degrees just normal drivin is that right its plugd into a 3sgte... and my thermo fan runs all the tme i dunno if the guage is in accurate or the engine is runnin hot
Re: speco water temp guage Sun, 12 December 2004 07:41 Go to previous messageGo to next message
get a thermometer.
Aust162
Melb, Victoria
Re: speco water temp guage Sun, 12 December 2004 08:53 Go to previous messageGo to next message
sounds like its running a bit hot. i had my cooling system checked on my 3sgte and the thermo fan would switch on at 92-94degrees and switch off after 35secs down to 84degrees. this was done with the radiator cap off and a thermometer in it...
people100
Rocklea qld
Re: speco water temp guage Sun, 12 December 2004 09:20 Go to previous messageGo to next message
where do you have the gauge sender pluged into. is it electrical or mechanical...might just have the gauge in a hot part of the engine..should always be as close as possible to the tempsender..
berad
Re: speco water temp guage Tue, 14 December 2004 02:51 Go to previous messageGo to next message
electrical i replaced the factory sender with the speco one.. turns out the guage is juts shit... my mangment tells me it barely even comes up to 90 cauz of the thermo fan on all the time drivin round it sits on 70degrees so i dont recomend speco water temp guages
Aust162
Melb, Victoria
Re: speco water temp guage Tue, 14 December 2004 07:42 Go to previous messageGo to next message
yeah speco sucks!good price thou...
hey berad, do you have one or both of ur thermo fans wired to ignition?you say its "on all the time" . my friends suby is setup that way too, is it a good idea??it would run the engine cooler obviously yeah?
berad
Re: speco water temp guage Wed, 15 December 2004 10:31 Go to previous messageGo to next message
yer it runs cooler mine runs at about 70 - 78 degrees its alright thats still hot enuff not to break nething. i juts have one thermo fan as the turbo is in the way one does the job well
Re: speco water temp guage Thu, 16 December 2004 12:20 Go to previous messageGo to next message
Why the hell would you want your fan on all the time? That's a bit like using a torch on a sunny day Laughing
[Updated on: Thu, 16 December 2004 12:20]
Re: speco water temp guage Thu, 16 December 2004 12:23 Go to previous messageGo to next message
i want what these guys are smoking Wink
speco (apparently) have more accuracy than some of your fooly sik bling bling gauges...
whytf would you pay $200 for a gauge?
sideshow
Re: speco water temp guage Thu, 16 December 2004 12:26 Go to previous message
70 to 78 thats bullshit
what is yr thermostat openin at
most themrostats open at 82 deg
so yr thermostat would be openin closing openin closing
in theory the thermo fan should turn off at just sabove the temp of thermostat
so turn on at about 87 to 90 then turn off at about 84
Previous Topic:how to remove steering arm from control arm?
Next Topic:Wiring Diagram for 18RGEU - NEEDED
Current Time: Thu Oct 22 07:03:30 UTC 2026
Total time taken to generate the page: 0.0056049823760986 seconds
