Toymods » Tech & Conversions » stupid Q on 4wheel alignment
b1gb3n
south Melbourne/KL
stupid Q on 4wheel alignment Sun, 12 December 2004 05:57 Go to next message
why is it that newer cars allow alignment on the rear wheels? with older cars we only needed align. on front wheels. what is the reason for allowing rear wheel alignment?
off the top of my head, so we can adjust the toe for racing setup on the rear??
alex_ta22
Newcastle, Hunter Valley
Re: stupid Q on 4wheel alignment Sun, 12 December 2004 06:16 Go to previous messageGo to next message
i belive its because of IRS...........I think
YelloRolla
On your mum!
Re: stupid Q on 4wheel alignment Sun, 12 December 2004 06:17 Go to previous messageGo to next message
Most modern cars are equipped with independent rear, and the toe and camber will change with the normal wear of components.
This seems like a likely reason - I am not 100% sure though.
b1gb3n
south Melbourne/KL
Re: stupid Q on 4wheel alignment Sun, 12 December 2004 06:58 Go to previous messageGo to next message
alex_ta22 wrote on Sun, 12 December 2004 17:16
IRS?
alex_ta22
Re: stupid Q on 4wheel alignment Sun, 12 December 2004 07:12 Go to previous messageGo to next message
IRS - independent rear suspesnsion', basically what yellorolla said. Because the suspension is now independent like the fronts, the same rules apply i guess
b1gb3n
south Melbourne/KL
Re: stupid Q on 4wheel alignment Sun, 12 December 2004 08:49 Go to previous messageGo to next message
i thought the front needs alignment because its the steering wheel. rear wheels dont steer. (apart frm 4ws).
anybody got definate answer?
DiZ_
The Eastwood MASSIVE !
Re: stupid Q on 4wheel alignment Sun, 12 December 2004 09:01 Go to previous messageGo to next message
Obviously introduction of IRS has lead to it alot , but then again it comes down to manufacturers and commonsense.
It makes sense that both rear and front wheels be adjustable , when accelerating and braking the alignment changes , and also as bushes and componants wear down , but have yet to need replacing , wheel alignment is slightly off. Having fully adjustable front and rear allows to keep the car with a optimium alignment for handling and safety at all times.
Some of the older cars I have worked on , even ones that had IRS did not have any adjustments at the back wheels , and only toe at the front. My cars has rear camber adjustment and front toe adjustment , all the rest are preset from factory with the bushes and control arms ect ect , but as the bushes wear my alighment will move out slightly unless I replace bushes.
However the new cars I work on , have lots of goodies , like 5 link rear suspension setups and castor , camber and toe adjustments on front and rear. It's mainly due to progress of technology.
20 years ago it was easier to make suspension systems with factory set alignment on everything but toe at the front. Now days totally alignable systems are easily and cheaply manufactured onto lots of models of cars.
Jonny2TG
Tasmania
Re: stupid Q on 4wheel alignment Sun, 12 December 2004 14:56 Go to previous message
I do a fair few wheel alignments. If I give a simple answer, it won't make propper sence.
When ever I do a wheel alignment, its always a "4 wheel alignment" in one sence, in that I clamp the measuring devises to all 4 wheels. Some laze people only clamp the things to the front wheels.
With a live rear axle (all RWD corollas, HiLux, Hiace, Cruiser etc) there is no way you can adjust toe. Its welded set in one position (and not always zero toe by the way). But idealy you want a bit of toe-in on the back, for stability. And with IRS, its a less robust setup, and more corrections need to be done after a crash.
For tyre wear, toe in is the most critical adjustment. Mostly on the front. But if you can adjust the back also, you have more chance of getting the car to run straight with even tyre wear.
But don't talk about caster on the rear, you will confuse yourself. I don't believe there is a caster angle on the rear.
I could go on...
Previous Topic:4AGTE T/B Choices
Next Topic:stupid battery question
Current Time: Thu Nov 19 21:08:25 UTC 2026
Total time taken to generate the page: 0.0059859752655029 seconds
