Toymods » Tech & Conversions » Your Opinions Plz - Fusion sub and Fusion amp
Bozza
Your Opinions Plz - Fusion sub and Fusion amp Mon, 13 December 2004 02:50 Go to next message
Hey everyone, just wanting ppl's advice on sub and amps i'm gettin. I'm gettin 2 12" subs,
FEW-12 Encounter woofer from fusion. Power handling-400 watt, Impedance- 4 Ohms, Efficiency- 91 db
Fusion FE-1002 - 2 ch Encounter Amp, 100 WRMs x 2 into 4 OHMS or 160 WRMS x 2 into 2 OHMS
Can anybody tell me if these are good components? Would the amp run the subs easily?
Thanks in advance
[Updated on: Mon, 13 December 2004 04:09]
86DRFT
Rockhampton QLD
Re: Your Opinions Plz - Fusion sub and Fusion amp Mon, 13 December 2004 10:29 Go to previous messageGo to next message
Fusion is brilliant, the setup should run well Smile
Major Clod
Re: Your Opinions Plz - Fusion sub and Fusion amp Mon, 13 December 2004 15:20 Go to previous messageGo to next message
If you want doof doof I'd look at getting an amp that has a little more power. It will power them fine but if you are in to turning them up you may find they start to clip and distort. Most amped setups run around 50-80WRMS into front splits alone, so you might want a little more power to those subs. If you are just into SQ then it should be fine.
gr8r-x
Vic, AU
Re: Your Opinions Plz - Fusion sub and Fusion amp Mon, 13 December 2004 21:23 Go to previous messageGo to next message
That amp will run the subs fine.. The fact that it runs 160W RMS x 2 into 2ohms is good. Most people really go overboard on amp/sub power. Unless you really want to crank it up to ear bleeding levels, you don't need a gajillion watts. Smile
I run a crappy Jaycar 50wx4ch amp, bridging one channel for the sub, so it's putting out approx. 100w (not quite though), and that's more than enough for a little bit of doof-doof. It's only in a Magna, so who cares? lol
Bozza
Re: Your Opinions Plz - Fusion sub and Fusion amp Tue, 14 December 2004 04:13 Go to previous messageGo to next message
Wat about if i just go 1 sub and 1 amp? I think i will do that.
rb20det
Re: Your Opinions Plz - Fusion sub and Fusion amp Tue, 14 December 2004 05:05 Go to previous messageGo to next message
if you go one sub get a better one as the standard fusions are crap.
Chris Davey
sunny coast, qld
Re: Your Opinions Plz - Fusion sub and Fusion amp Tue, 14 December 2004 05:08 Go to previous messageGo to next message
same power level, but twice the cone area will mean the two subs will still be louder. Seems like a decent setup to me.
If you want really good advice check out www.caraudioaustralia.com
Major Clod
Re: Your Opinions Plz - Fusion sub and Fusion amp Tue, 14 December 2004 11:10 Go to previous message
It may run 160WRMS x 2Ohms, but the impendence of the subs are 4Ohm. To get the most out of it look for some 2Ohm subs, or get a monoblock and DVC subs and use the correct wiring setup to get your impendence.
www.caraudioaustralia.com is an excellent place to go.
Previous Topic:1J head studs
Next Topic:Small Celica window mechanism question/favour
Current Time: Fri Oct 23 15:37:02 UTC 2026
Total time taken to generate the page: 0.010222911834717 seconds
