Toymods » Tech & Conversions » how to build a hybrid 2tg
hokey
Kilsyth, Melbourne
how to build a hybrid 2tg Mon, 13 December 2004 08:08 Go to next message
sorry every 1 if there a alot of threads on this but i searched and couldn't get wot i wanted. i want to know wot is exactly involved to make a 2tg 3t hybrid. is it as simple as gettin a 3t block crank and pistons and boltin on the 2tg head or is it a little more complicated than that??
Cheers Calvin
jeffro RA28
Tamworth
Re: how to build a hybrid 2tg Mon, 13 December 2004 08:21 Go to previous messageGo to next message
hmmm, i am interested in knowing about this aswell....
sorry i cant help
styler
Re: how to build a hybrid 2tg Mon, 13 December 2004 08:27 Go to previous messageGo to next message
well hopefully other ppl can add to this...
and correct any mistakes,
i have a hybrid,
the later model blocks - 2tgeu are easier to use,
cos they are the same block as a 3t and dont need
much if any modification compared to the early 2tg
which need some modification.
the pistons need to be flycut to allow the valves
to clear on most, maybe all heads. i have flat top
pistons apparently which didnt need cutting ill find
out soon enough anyway
you should bore it out seeing since you are stroking
it and its worth doing while its all apart
heads have different cams and valves, i have a 88822
head... some have double valve springs which id say
would be better - enable higher rpm
i think the conrods from the 3t are used?
if i think of anything else ill post it, hopefully
any inaccurate info will be corrected
[Updated on: Mon, 13 December 2004 09:30]
hemi twofifteen turbo
Re: how to build a hybrid 2tg Mon, 13 December 2004 08:46 Go to previous messageGo to next message
I'm in the process of doing this. For starters i'll assume you've got all the bits you need to make a 2t into a 2tg
(heads, timing cover, cogs etc)
I had a blown 2t-g, all i did was.
Get a stock 3t crank. Fits straight in if you have a late model
2t-g. If you have a standard 2t block you are converting
you will need to use a die grinder to clearnace the block.
Otherwise just get a 3t block. The 2t/3t rods are the same
length so they are not an issue. Oviously the 2t-g rods are
stronger so use them if you have them.
Since they never made a 3t-g they never made the pistons
to clear the valves. So you will have to buy stock 3t pistons
and get the valve reliefs flycut, making your own 3t-g pistons.
Use 2t pistons as a guide if unsure.. (or measure) (check your cam specs too)
The 3t pistons have a lower pin height, if you used 2t pistons
they would pop out the top of the block with the 3t crank!
Apart from that that's it!
hokey
Kilsyth, Melbourne
Re: how to build a hybrid 2tg Mon, 13 December 2004 09:06 Go to previous messageGo to next message
so should i use the 3t pistons with the 2tg rods cause i hav a 2tg and also hav a complete 3t. my head number is 88260 so does that mean my motor is an older one or a later version???
[Updated on: Tue, 14 December 2004 00:26]
styler
Re: how to build a hybrid 2tg Mon, 13 December 2004 09:27 Go to previous messageGo to next message
hemi twofifteen turbo wrote on Mon, 13 December 2004 19:46
3t-g te ie 3tgte would these pistons work or not just out of interest if anyone has used them
[Updated on: Mon, 13 December 2004 09:29]
hokey
Kilsyth, Melbourne
Re: how to build a hybrid 2tg Tue, 14 December 2004 01:10 Go to previous messageGo to next message
anyone else??? i thought there would b way more info for these motors seein as alot of people hav them Rolling Eyes
dcleyne
Re: how to build a hybrid 2tg Tue, 14 December 2004 02:01 Go to previous messageGo to next message
This might help...
http://forums.toymods.org.au/index.php?t=msg&t h=36226&rid=4098&S=00857c700158801afa4d070 6b0abc28b&pl_view=&start=0#msg_321059
hokey
Kilsyth, Melbourne
Re: how to build a hybrid 2tg Tue, 14 December 2004 02:29 Go to previous messageGo to next message
great thanx alot
Re: how to build a hybrid 2tg Tue, 14 December 2004 02:46 Go to previous messageGo to next message
The only thing about the wiesco pistons are that they are expensive. Flycutting is approx $15 a piston as a baseline,
possibly less. + Stock 3t pistons is fairly cheap.
Just make sure if you use a non 2t-g block you rotate
the non used cam bearing slighly to block their oil feed holes.
About the 3t-gte pistons, they would work, but would have very low comp. I can't remember what it was but it was low.
hokey
Kilsyth, Melbourne
Re: how to build a hybrid 2tg Tue, 14 December 2004 05:59 Go to previous messageGo to next message
so all i need to do is get my 2tg head and bolt it to the 3t block with the 3t crank and pistons????
jesseT18
Castle Hill, Sydney
Re: how to build a hybrid 2tg Tue, 14 December 2004 06:38 Go to previous messageGo to next message
Rolling Eyes ......no
i built one of these engines and found every single bit of information i needed for it from this forum, so its all there somewhere, just look for it!
hokey
Kilsyth, Melbourne
Re: how to build a hybrid 2tg Tue, 14 December 2004 06:42 Go to previous messageGo to next message
yeh i hav searched and i can hardly find anything i just want a rundown of all the things i need to do and get. i have a full 2tg and a 3t so can sum 1 please help me Crying or Very Sad
pheonix83
Devonport Tasmania
Re: how to build a hybrid 2tg Tue, 14 December 2004 07:33 Go to previous messageGo to next message
ok.
step one, pull apart 2tg
step two, pull apart 3t-c
step three, rebore 2tg block
step four, call sean maloney and get some pre flycut pistons for $450
Step five, fit pistons to 2tg rods.
step six, buy new bearings and fit onto 2tg rods on 3tc crank.
install and drive.
thats it in a nutshell.
of course there are areas where u need to know how to build an engine in there, but im presuming you can figure it out from there
hokey
Kilsyth, Melbourne
Re: how to build a hybrid 2tg Tue, 14 December 2004 07:46 Go to previous messageGo to next message
is that boring out to 2.0 litre or sumthin? i am on a tight budget so 1.8 will hav to do so can i use the 3tc pistons and get them flycut??? thanx alot for the help
cooter
perth
Re: how to build a hybrid 2tg Tue, 14 December 2004 08:07 Go to previous messageGo to next message
do ya have to get the 2t block bored if u want to use that. im looking at as little machining etc as possible. my understanding of this is that i can unbolt my 2tg pistons, crank, conrods. then after getting the 3t-c pistons fly cut i can just bolt the 3t crank, conrods pistons in. correct? will i need different bearings or will the ones out of both engines make up for the ones i need?
hokey
Kilsyth, Melbourne
Re: how to build a hybrid 2tg Tue, 14 December 2004 08:31 Go to previous messageGo to next message
yeh i am in the same boat as u. and the answer is..........
[Updated on: Tue, 14 December 2004 08:32]
pheonix83
Devonport Tasmania
Re: how to build a hybrid 2tg Tue, 14 December 2004 10:04 Go to previous messageGo to next message
depends on the minute piston to bore clearences.
etc.
if the 2tg block measures up within tolerances, and the pistons all measure aswell, then yes, just a new set of rings and a hone should suffice.
the pistons are pressed onto the rods aswell.
and with this conversion you need a complete gasket kit aswell.
the 2tg and 3tc bearing are the same, its the 3tgte ones that are different.
and seeing as u are using the 2tg rods, use 2tg bearings.
use new bearings, not old ones.
use new rings not old ones.
for god sake please dont do dodgies.
hokey
Kilsyth, Melbourne
Re: how to build a hybrid 2tg Tue, 14 December 2004 10:31 Go to previous messageGo to next message
pheonix83 wrote on Tue, 14 December 2004 21:04
etc.
wot do u mean by minute piston to bore clearances???????
pheonix83
Devonport Tasmania
Re: how to build a hybrid 2tg Tue, 14 December 2004 12:09 Go to previous messageGo to next message
ok, your bore can wear so much before its considered too much for use with the std piston, so then it needs a rebore and new pistons.
i cant remember the exact tolerances, but any good engine shop should know
hokey
Kilsyth, Melbourne
Re: how to build a hybrid 2tg Tue, 14 December 2004 12:14 Go to previous messageGo to next message
so should i measure the diameter of my bore to see if it needs reboring? do u know wot it should be?
pheonix83
Devonport Tasmania
Re: how to build a hybrid 2tg Tue, 14 December 2004 22:32 Go to previous messageGo to next message
mate, if you are asking all these questions then you prolly dont know enough about engines to do this rebuild yourself, i would consult a professional in this case.
as there is too much room for stuff up if not built correctly
hokey
Kilsyth, Melbourne
Re: how to build a hybrid 2tg Tue, 14 December 2004 23:13 Go to previous message
i may not know it all but my brother and my dad are and when i get the info they can tell me wot to do. u gotta start somewhere right so i am askin as many questions as i can so i don't wreck my motor. i hav a basic idea but just wasn't sure on a few things. well thanx for the info
[Updated on: Wed, 15 December 2004 00:12]
Previous Topic:T series diff ratios
Next Topic:Is the 4AGE of non-interference type?
Current Time: Wed Oct 21 02:56:19 UTC 2026
Total time taken to generate the page: 0.0061240196228027 seconds
