Toymods » Tech & Conversions » bolt torque and engine car manuals
ToyT18
Hobart
bolt torque and engine car manuals Mon, 13 December 2004 10:51 Go to next message
Rolling Eyes i am looking for the torque specs for everything on a 3T-GTE bottom end. Sad also i am after a TE72 car manual like a gregorys one and if anyone has ever seen one a 3T-GTE manual or manual for jap cars that came out with the 3T-GTE pref corona.
TE72_Turbo
Re: bolt torque and engine car manuals Mon, 13 December 2004 11:33 Go to previous message
Here you go:
Toyota 3T-GTEU Torque Specifications
Foot-Pounds
Crank main bearings 58
Conrod big end bearings 36
Harmonic balancer to crank 65
Flywheel to crank 62
Clutch pressure plate to flywheel 14
Head bolts to block 58
Timing gears to cams 54
Cam bearing caps 14
Exhaust manifold to head 29
Intake manifold to head 14
Turbo to exhaust manifold 29
Exhaust dump pipe to turbo 16
Throttle body to intake manifold 9
Gearbox bellhousing to block
12mm bolt 47
10mm bolt 27
Waterpump 14
Oil Pump 15
Valve clearances
Intake 0.29mm +/- 0.05
Exhaust 0.34mm +/- 0.05
Source: Toyota 3T-GTEU (1982-89) factory manual
Previous Topic:4age20v part numbers or sizes preferably
Next Topic:4agze/20v Conversion
Current Time: Wed Oct 28 17:36:31 UTC 2026
Total time taken to generate the page: 0.083791971206665 seconds
