Toymods » Tech & Conversions » how to remove steering arm from control arm?
Big T
icon5.gif  how to remove steering arm from control arm? Mon, 13 December 2004 11:09 Go to next message
hey peoples. i got a control arm outta an ae71 to use on my sprinter but am having trouble removing the steering arm from
the control arm. i only need the control arm cause thats the only damaged part i have but the steering arm just seems to swivel
with the bolt connecting the two together. do i just need to whack the thing out with a hammer or am i doing something wrong?
i tried prying the thing off and of course, grease just squished all over my hand as the rubber seal came off. Confused help please!!!
edit: oh and both the control/steering arms are both out of the car now.
[Updated on: Mon, 13 December 2004 11:10]
TA-022
Glenmore Park, NSW
Re: how to remove steering arm from control arm? Mon, 13 December 2004 11:46 Go to previous messageGo to next message
the socket with a bolt is called a "Ball joint"
you wont be pulling this apart, youll have to find the end of the ball joint and unhook there.
http://users.tpg.com.au/nbdean/steering.jpg
this is just in general remembering this pic is from a TA22 manual.
Nathan
Re: how to remove steering arm from control arm? Mon, 13 December 2004 11:49 Go to previous messageGo to next message
Go buy a pitman arm puller or similar.
people100
Rocklea qld
Re: how to remove steering arm from control arm? Mon, 13 December 2004 12:07 Go to previous messageGo to next message
its much easier to seperate them while there in the car and get a ball joint splitter.
YelloRolla
On your mum!
Re: how to remove steering arm from control arm? Mon, 13 December 2004 13:04 Go to previous messageGo to next message
People most commonly try to hit the ball joint out by hitting on the loosened nut with the hammer (seems straight forward) and they drive themselves crazy doing so.
The ball joint has a tapered shaft and it slots into a corresponding taper on the "knuckle arm" as it is so called in the drawing above!
Rapping the side of the "knuckle arm" (at the point closest to where the tapered tie rod end ball joint is well at home) with a sizeable hammer (and don't fairy tap it), shocks the taper and often results in the two parts coming apart (it is necessary to hold a dolly at the opposing side of the knuckle end to where it will be struck).
Failing that? the ball joint separator thing is an awesome tool.
Big T
Re: how to remove steering arm from control arm? Tue, 14 December 2004 07:45 Go to previous messageGo to next message
ahhhh crud... well if i just take both control and steering arms outta both cars, is there someone that could swap the steering
arm from the bent control arm and switch it to the straight one? would a wheel alignment place or someone like pedders do this
sorta thing? how much am i looking at in terms of cost? thanks for all the help so far!
Fattony
Re: how to remove steering arm from control arm? Tue, 14 December 2004 23:41 Go to previous messageGo to next message
Oh GOD dont hit the thing with a hammer, unless you want to buy new ball joints and then have the fun of installing them. Get your self a ball joint seperator, these are available at Repco. All you do is insert the forked end into the ball joint and then tighted the bolt in the middle and it shall force the other end of the ball joint to pop out. Tool costs like 15 bucks and takes about 10seconds to do. Much easier than being a tight arse and trying to use hammers to take it out.
Cheers Adam
Big T
Re: how to remove steering arm from control arm? Wed, 15 December 2004 07:52 Go to previous messageGo to next message
ok then. so how do you go about putting the thing back together then? can you use the same tool to remove AND install as well Fattony?
Fattony
Re: how to remove steering arm from control arm? Wed, 15 December 2004 08:03 Go to previous messageGo to next message
That tool is only used to pop out a ball joint from an ajoining arm.
styler
Re: how to remove steering arm from control arm? Wed, 15 December 2004 10:46 Go to previous messageGo to next message
iv done both ways on these types of jobs,
the sturdy hammer and the special tool and i can
recommend using the tools if one is avaliable
for this. they dont usually cost much and saves
heaps of time and effort and broken parts
lever tie rod remover
threaded tie rod remover
pitman puller
pronged puller
[Updated on: Wed, 15 December 2004 11:52]
Big T
Re: how to remove steering arm from control arm? Wed, 15 December 2004 12:03 Go to previous messageGo to next message
thanks for all the info guys. i dont have to actually remove the tie rods because only the control arm seems to be bent. guess i'll just take the seperated control arm/steering arm along with my car to somewhere that has the tools to re-install them. i'll need to get the wheels realigned anyways so i guess it wont cost that much more to get the parts swapped in. now... if i can just find a way to get there without having to turn left Rolling Eyes
YelloRolla
On your mum!
Re: how to remove steering arm from control arm? Wed, 15 December 2004 21:15 Go to previous messageGo to next message
Fattony wrote on Wed, 15 December 2004 10:41
Cheers Adam
Adam, the way that I have described actually does NO damage to the items in question - it is merely a matter of shocking the taper free (as a fitter and machinist of 15yrs, I am pretty familiar with self locking tapers and how they work). I have used both methods on numerous occassions.
The separator is VERY capable of fucking the rubber boot, but it is quicker and easier.
Make no assumptions about being a tight arse if you DON'T understand the method being employed.
end rant
Fattony
Re: how to remove steering arm from control arm? Wed, 15 December 2004 23:39 Go to previous messageGo to next message
No Message Body
[Updated on: Thu, 16 December 2004 00:07]
YelloRolla
On your mum!
Re: how to remove steering arm from control arm? Thu, 16 December 2004 00:48 Go to previous messageGo to next message
I must've been a little sensitive this morning
Re: how to remove steering arm from control arm? Thu, 16 December 2004 01:37 Go to previous messageGo to next message
What I use, but like Jason said, it fucks the boot everytime.
http://members.optusnet.com.au/gianttomato/5MTE/weapons%20of%20choice.jpg
Fattony
Re: how to remove steering arm from control arm? Thu, 16 December 2004 02:08 Go to previous messageGo to next message
Bah i use something different, never fucked a boot with wat i have i will get a pic later.
Fattony
Re: how to remove steering arm from control arm? Thu, 16 December 2004 08:40 Go to previous messageGo to next message
Well i went to come on to insert an image, but it wont let me Sad
Re: how to remove steering arm from control arm? Thu, 16 December 2004 12:59 Go to previous message
I use both the bolt-up type seperator, and the big hammer method, depends on the job, how easy it is to get at, etc. I don't seem to remember ever actually stuffing a rubber unless is was already leaking/split anyway. Also, the ball joints aren't that hard to replace, or that expensive.
Previous Topic:AE86 owners help
Next Topic:speco water temp guage
Current Time: Wed Oct 21 02:55:14 UTC 2026
Total time taken to generate the page: 0.008512020111084 seconds
