Toymods » Tech & Conversions » CT26 turbo
jcmunga
adelaide
CT26 turbo Tue, 14 December 2004 10:56 Go to next message
what are the specs on these?
would they run well on a 1g??
what would need to be done to fit it to a 1g?
Re: CT26 turbo Tue, 14 December 2004 11:16 Go to previous messageGo to next message
I think you should take the time to search this one bro. It's been covered more than once.
MR 1JZ
Re: CT26 turbo Wed, 15 December 2004 04:13 Go to previous messageGo to next message
it has been established that for the time and money required that it wouldnt really be worth it and you would be much better going for a ball bearing turbo such as a VG30 Roller or T28 Roller, or if you are really lucky a GT28 roller off a GTIR pulsar, 200+ rwkw is possible with all three of these turbos Smile
Fattony
Re: CT26 turbo Wed, 15 December 2004 05:57 Go to previous messageGo to next message
Better make sure that you dont wind up with a ceramic wheel version of the t28 otherwise you wont be making more boost than stock without spitting it into the exhaust
Siktoy ra23
Plumpton/sydney
Re: CT26 turbo Wed, 15 December 2004 06:07 Go to previous messageGo to next message
Give me a couple of months to finish mine and ill tell you how they go
MR 1JZ
Re: CT26 turbo Wed, 15 December 2004 07:12 Go to previous messageGo to next message
fattony they can run 14psi safely with no dramas, i know of several S15 owners running over 14 psi with no issues either, obviously you wouldnt want to gotoo far tho Smile
Fattony
Re: CT26 turbo Wed, 15 December 2004 08:09 Go to previous messageGo to next message
Well considering stock gen 3s run 11psi, i do not consider 3psi difference a worth while result. When you could keep the stock turbos and end up being able to run the same boost. Comon lets be honest, why would you waste all that time and money putting a single turbo on a 1g when you cant even reach higer boost levels than whats attainable on the stock twin setup if thats your reasoning for the single turbo setup.
You would have to forgive me just got home from work before and you would usually get stupid unthought answers like that out of me. Now i have had time to rest the above is the meaning of what i wanted to say before Smile
MR 1JZ
Re: CT26 turbo Wed, 15 December 2004 08:38 Go to previous messageGo to next message
yeah but the simple fact reamins that you cannot make 220rwkw on stock gen 3 turbos, with a T28BB you can Smile
They dont run out of puff on high boost like the CT12's do
JustenGT4
Re: CT26 turbo Thu, 16 December 2004 02:56 Go to previous message
Fattony, it's not boost you are after it's flow, so the increase in 3 psi isn't the issue, it's how much flow the T series turbo would make at 14psi.....if it's more than the twin CT12 at their max boost then it's worth the effort.
As for whether a T28 will flow 200rwkw i've yet to see it. Put a T28 BB next to a GT2540 which is it's natural upgrade and you will see a huge size difference. These are both Garrett turbos and Garrett themselves only rate the GT2540 at a max of around 240rwkw (i have one on my 3SGTE and it's about right).
A CT26 will get you close to 200rwkw but it's definitely pushing it. The beauty is they are easy to upgrade with larger comp wheels so if you want to stay with a toyota product then there's nothing wrong with a CT26.
At the end of the day though, if you are going to go to all the trouble of ditch the twin setup you may as well do it properly and at least run a GT25 frame or an IHI RX6...something bigger than the factory offerings. If not you're better off just optimising what you have the best you can.
Previous Topic:K series sump
Next Topic:Help!! GZE won't fire! *solved*
Current Time: Sun Oct 25 09:16:25 UTC 2026
Total time taken to generate the page: 0.007612943649292 seconds
