Toymods » Tech & Conversions » 12V electric oil pumps
Steve_Reynolds
Gold Coast
icon5.gif  12V electric oil pumps Wed, 15 December 2004 03:02 Go to next message
Howdy,
I recall some dicussion on this a while back (shane?)
Unfortunately Search button = zippo.
I have located a mocal oil pump and another brand (name escapes my just now)on some pommy sites.
see -> http://www.thinkauto.com/oilpumps.htm
Does anyone know where I can locate a similar style electric oil pump in Oz?
I want to transfer oil from the sump to a tank - similar to a dry sump set-up. Just toying with the idea and of course the cost comes into the equation.
Any info appreciated.
Steve
IRA11Y
Club Member
Re: 12V electric oil pumps Wed, 15 December 2004 05:51 Go to previous messageGo to next message
steve ilooked in to this a while back, unfortunately most of the pumps i found were in excess of $1K here in aus, my alternative which i havent put in to practice yet is to imrovise a power steering pump driven off the crank.. for the volume pumped there isnt a lot of parasitic loss, but that depends on your application i guess
Steve_Reynolds
Gold Coast
Re: 12V electric oil pumps Wed, 15 December 2004 06:28 Go to previous messageGo to next message
Thanks Michael.
I'm contemplating emulating a set-up I saw in a rotary race car a while back. He had a holden red motor oil pump (the external bolt on jobbies) mated to the small drive shaft rotaries have to drive the small oil injection pump to the carby. That was used to scavenge oil from the sump up into a oil resevior that had an oil/air seperator in it as well. The tank would have been about 6 or 7 litre capacity. The bottom of the tank then fed the regular oil pump via a few speed flow style fittings back on the sump.
It worked very well in combating oil surge etc. It is of course a poor mans dry sump system (& I'm poor).
By incorporating this, I can also reduce the depth of the sump (a-la dry sump set-up) which means my engine can sit a bit lower as well.
I'll look into the pwr steer pump (I threw it away 3 weeks ago would you believe ;-(.
Steve
Re: 12V electric oil pumps Wed, 15 December 2004 12:17 Go to previous messageGo to next message
you might be able to run an elec fuel pump also...
something cheap and shitty could work.. like a walbro pump Wink
sure the temps are higher, but the pump is fuel proof... the gerotor ones are effectively an electric oil pump anyway...
they will not probably last as long as a 'proper' pump, and may not like pumping oil foam either (less suction), but it is a poormans way of doing it..
other than that, either holden external pump or PS pump would be easy.. you'd want high volume for scavenging the oil foam?
gemtoy
melb
Re: 12V electric oil pumps Wed, 15 December 2004 21:44 Go to previous messageGo to next message
Steve,
I know that the Holden Astra runs an electric power steering pump. This might be able to be adapted
Steve_Reynolds
Gold Coast
Re: 12V electric oil pumps Thu, 16 December 2004 04:38 Go to previous messageGo to next message
Astra Yeh?? Very interesting.
I assume that would have to be a late model one??
Many thanks for that!
Steve
hemi twofifteen turbo
Re: 12V electric oil pumps Thu, 16 December 2004 08:15 Go to previous messageGo to next message
Do you know what year runs the elec pump?
gemtoy
melb
Re: 12V electric oil pumps Thu, 16 December 2004 09:46 Go to previous messageGo to next message
The Astra that has been out for the last few years (now called the Astra Classic)and I think the brand new one as well-it uses the same engine.
Let us know how you go.
Re: 12V electric oil pumps Thu, 16 December 2004 09:48 Go to previous messageGo to next message
In the Goss catalogue there is a pump that's intended for pumping oil in gearboxes and diffs for cooling - maybe this would be useful?
Steve_Reynolds
Gold Coast
Re: 12V electric oil pumps Thu, 16 December 2004 23:09 Go to previous messageGo to next message
Shinny,
Is the catalogue on line or do you have a hard copy?
Spec?
Thx
Steve
Re: 12V electric oil pumps Fri, 17 December 2004 10:30 Go to previous messageGo to next message
Those gearbox/diff pumps are pretty damn small and are unlikely to flow enough to be useful for this application.
Re: 12V electric oil pumps Fri, 17 December 2004 11:11 Go to previous message
I just used a paper copy at my local parts place. I also figured they'd likely be a bit small, and that the cost could add up once several were purchased...
Previous Topic:Where do i go to get new Brakes?
Next Topic:oops...
Current Time: Mon Oct 19 17:46:42 UTC 2026
Total time taken to generate the page: 0.12593603134155 seconds
