Classifieds » Miscellaneous » 2TG HEADS
egg man
townsville
2TG HEADS Tue, 15 October 2002 10:04 Go to next message
I have a few 2TG heads all are yammie heads 2 are complete with cams and i also have 1 half cam and timing cover to convert a 2t motor. I am looking around $300 for each head but offers will be considered.
Re: 2TG HEADS Wed, 16 October 2002 00:23 Go to previous messageGo to next message
Mate i've heard there are a few different style 2tg heads around with different model numbers. Do you know which one these are? think it starts with 11111 - xxxxxx or something?
Joel
inferno
Re: 2TG HEADS Wed, 16 October 2002 14:22 Go to previous messageGo to next message
All of the 'Yamaha' heads end with a #8826x, and have a two bolt face plate on the front with "Yamaha", as opposed to the eight box alloy face plate with nothing and #8822x. The general rule is the later the head, the bigger the valves but shorter the cams.
is there anything 'special' about these heads, like modified cams, bigger valves, ported etc..? if so i could be interested.
rob.
thetoyman75
Club President
Re: 2TG HEADS Thu, 17 October 2002 05:15 Go to previous messageGo to next message
Rob,
The 11111-88220 Head has the small valves. All heads after 88222, 88260 and 88261 have the same size valves. I am unsure of the valve sizes in the 88262 (Unnumbered) Head. The 22860 and 22261 had increased webbing for a slightly stronger head and were typically EFI heads. The 88220 was only ever carby and the 88222 head was mostly carby fed.
Cam sizes did vary I haven not the exact figures for all cams. I havethe 88220 and 88222 specs somewhere.
Eggman,
Yamaha made ALL the 2TG heads. If they are 8826x Heads I'll give you $300 for the lot if you are in Sydney and the heads are in usable condition !
inferno
Re: 2TG HEADS Thu, 17 October 2002 06:39 Go to previous messageGo to next message
rod,
yep thats the long version of what i was trying to say Razz u sure about the #222 not having reinforced head webbing? that's the impression i was under until i looked at-
http://www.tassie.net.au/~jar/2tg-info.html
I wouldn't really care but that's the model i have in my ta22 atm.
i'm interested in the specs on the cams if you could find them.
thetoyman75
Club President
Re: 2TG HEADS Thu, 17 October 2002 07:14 Go to previous messageGo to next message
I'll have a look tonight pretty sure there is a 88222 head there !
I only have the cam specs for the 88220 and 88222 cams as fitted to the GT TA22.
Thay are listed in the Tech section of the Toymods Web site in the TA22 Article I wrote.
BigBadBenny
Brisbane, Queensland
Re: 2TG HEADS Fri, 18 October 2002 09:42 Go to previous messageGo to next message
ah I tend to disagree
my 2tg head is a 88220 and I was planing to put bigger valves in but there is no room for them
my inlet valve is about the size of a 50cent peice.
anyway my head has big valves,
egg man
townsville
Re: 2TG HEADS Fri, 18 October 2002 14:08 Go to previous messageGo to next message
Iam not sure what the numbers are but will find out, Asfor any thing special they are stock but in very good nic and all have the large valves.
thetoyman75
Club President
Re: 2TG HEADS Mon, 21 October 2002 00:14 Go to previous messageGo to next message
Benny,
Mate the 88220 Head has smaller valves ! No question !
88220 has 43mm inlet and 37mm Exhaust !
88222 on has 44.5 mm inlet and 38.5mm Exhaust.
Eggman,
Let me know re my offer ?
inferno
Re: 2TG HEADS Mon, 21 October 2002 07:41 Go to previous messageGo to next message
amazing what 1.5cms does to performance!!
hey rod, u seem to know a bit about the #262 2TG head, is there any chance the elliptic ignition chamber in the head could be machined circular so that a non-off centre piston can be used (eg 3T flycut piston)?
rob
thetoyman75
Club President
Re: 2TG HEADS Tue, 22 October 2002 01:37 Go to previous messageGo to next message
Rob,
Mate I am yet to get my hands on a 262 head. (anyone ???) I want to play with one a bit first to make sure but if you used a flat top piston you should be able to use that head.
If you want a High compression piston you will have clearance issues with the combustion chamber.
The stock 3TGTEU pistons would foul on the Chamber as far as I can guess without getting my hands on one.
thetoyman75
Club President
Re: 2TG HEADS Tue, 22 October 2002 01:40 Go to previous messageGo to next message
Oh as for machining out the combustion chamber ! It could be done but it would be cheaper to buy a non emmision head like a 88261 or similar. Do you have an 88262 head ?
batesy
Re: 2TG HEADS Wed, 23 October 2002 10:57 Go to previous message
i do Smile
http://home.iprimus.com.au/vk5kbj/e01.jpg
if you look close-ly at picture you'll see the off center combustion chamber Smile
Previous Topic:4AGE Throttle Boddies $400 Bargin !!!!!
Next Topic:Corolla KE30-55 bits
Current Time: Sat Oct 24 01:23:33 UTC 2026
Total time taken to generate the page: 0.0045177936553955 seconds
