Toymods » Tech & Conversions » Timing belt snaped quick question.
MFX_AE86
Liverpool
Timing belt snaped quick question. Wed, 15 December 2004 13:20 Go to next message
Hey guys,
As the title states I snaped my timing belt a little while ago & am about to replace it.
I just wanted to know if the 4AGZE has a non interferance head. I wouldnt wanna test it & think its ok & find it goes boom when i start it.
Dave
Spanktown
Inside a giant turbo (syd...
Re: Timing belt snaped quick question. Wed, 15 December 2004 13:43 Go to previous messageGo to next message
you'll be sweet Wink
Dust
Re: Timing belt snaped quick question. Wed, 15 December 2004 14:00 Go to previous messageGo to next message
what about the 1ggte? that non interference too?
YelloRolla
On your mum!
Re: Timing belt snaped quick question. Wed, 15 December 2004 20:57 Go to previous messageGo to next message
I believe tht all Toyota belt driven engines are non interference.
YOGI8U
up yours!
Re: Timing belt snaped quick question. Wed, 15 December 2004 21:07 Go to previous messageGo to next message
20v are most definitely not! Very Happy
takai
Re: Timing belt snaped quick question. Wed, 15 December 2004 21:27 Go to previous messageGo to next message
Beware if head work has been done to the engine, its relatively easy to get a NI head to become and Interference head again.
YelloRolla
On your mum!
Re: Timing belt snaped quick question. Wed, 15 December 2004 23:32 Go to previous messageGo to next message
Hi Yogi - merry christmas
MR 1JZ
Re: Timing belt snaped quick question. Thu, 16 December 2004 01:59 Go to previous messageGo to next message
takai wrote on Thu, 16 December 2004 07:57
explain please as my head is being rebuilt in the near future Smile
Re: Timing belt snaped quick question. Thu, 16 December 2004 02:31 Go to previous messageGo to next message
machining face of head will bring valves closer to pistons, using hi-comp pistons with higher than factory crown high does same... if you remove too much height, valves meets the piston very intimately (and violently).
MR 1JZ
Re: Timing belt snaped quick question. Thu, 16 December 2004 02:41 Go to previous messageGo to next message
so as long as i only machine it the bare minimum I should be ok?
or is it when you machine heads 2 or 3 times that the motor then becomes an interference engine?
RobertoX
Re: Timing belt snaped quick question. Thu, 16 December 2004 04:04 Go to previous messageGo to next message
be careful with new cams too... higher lift could possibly make valves meet piston especially with that minimal headwork Confused
Mr DOHC
Re: Timing belt snaped quick question. Thu, 16 December 2004 07:37 Go to previous messageGo to next message
just get them to measure it when they machine it and they should be able to tell u whether it'll still clear
MR 1JZ
Re: Timing belt snaped quick question. Thu, 16 December 2004 12:19 Go to previous messageGo to next message
rad
cheers MR DOHC Wink
4agte
Toronto, Downtown
Re: Timing belt snaped quick question. Thu, 16 December 2004 12:28 Go to previous messageGo to next message
toyota technology means 4aze's clear not like some other brands *cough* nissan..
Mr DOHC
Re: Timing belt snaped quick question. Thu, 16 December 2004 12:36 Go to previous messageGo to next message
4agte wrote on Thu, 16 December 2004 22:28
its not really toyota technology, its just logic Rolling Eyes
Jake001
B risbane
Re: Timing belt snaped quick question. Thu, 16 December 2004 23:08 Go to previous messageGo to next message
Dust wrote on Thu, 16 December 2004 01:00
I broke one and didn't bend a valve.
P.S. It sux changing a timing belt on the side of the road Mad
MFX_AE86
Liverpool
Re: Timing belt snaped quick question. Sun, 19 December 2004 07:45 Go to previous messageGo to next message
So i should be fine to use the standard methods of testing.. i.e spinning the harmonic balancer and seeing if there is any interferance?
Dave
Re: Timing belt snaped quick question. Sun, 19 December 2004 14:26 Go to previous message
Yup, turning the engine by hand will tell you straight away if things are bumping into other things.
Previous Topic:ae86 rear wheel bearing replace?
Next Topic:Increasing intake runner bore size??
Current Time: Sat Oct 24 22:21:35 UTC 2026
Total time taken to generate the page: 0.0055809020996094 seconds
