Toymods » Tech & Conversions » engine mounts
jcmunga
adelaide
engine mounts Wed, 15 December 2004 13:23 Go to next message
im putting a 1g into my ra28 and as read the engine mounts need to be moved to the front set of holes but only 2 holes on one side of the bracket match up on both mounts. iv tried bending them out to fit but its pretty impossible.
have people come accross this problem before?
what to do?
Re: engine mounts Thu, 16 December 2004 00:39 Go to previous messageGo to next message
This is just a guess, but mid mount mounts wont bolt into the front mount holes.
You will have to source a set of front mount mounts, from a GA61, or GX61, GX71, GX81 or GZ10. I'm not sure what else uses front mounts.
amon
Darwin
Re: engine mounts Thu, 16 December 2004 07:58 Go to previous messageGo to next message
i have just done that conv and i think it was chucklandwher who went and pulled mine from the wreckers,then i used standard new nolathene iso mounts all bolted together sweet.
you might try and msg him,hopefully it was him........
Ta Guy
jcmunga
adelaide
Re: engine mounts Thu, 16 December 2004 13:01 Go to previous messageGo to next message
made a few call and it seems there pretty hard to find? havnt messeged chucklandwehr yet, might do that now
cheers guys
[Updated on: Thu, 16 December 2004 13:04]
manmx83
Re: engine mounts Thu, 16 December 2004 15:18 Go to previous message
Bush mechanic method-cut a chunk out of neighbours bbq plate [steel] and with the aid of a paper template rubbed over the block's mounting holes with greasy fingers [to accurately mark hole positions] drill the holes and bolt the plate to block.
Put engine [block] in desired position.put desired mounts in their spot and mark the bbq plate where you require bolts to magically appear.unbolt the bbq,drill holes and weld bolts in.finito.drink more beer.Merry Xmas.Pete. Smile
Previous Topic:2j ct12b's onto ct12a set up? edit not practical-thanks.....
Next Topic:Has anyone done 7K conversion to a KE3#?
Current Time: Mon Oct 19 10:57:51 UTC 2026
Total time taken to generate the page: 0.041278123855591 seconds
