Classifieds » Parts Wanted » AE86 Coilover. *dimensions*
setsuna
AE86 Coilover. *dimensions* Thu, 16 December 2004 04:01 Go to next message
need to know the dimensions of these coilovers!
height/length, width/diameter, ya
thats it ;p
slydar
Re: AE86 Coilover. *dimensions* Thu, 16 December 2004 10:58 Go to previous message
this belongs in tech and conversions. or you can go to www.club4ag.com and read their tech referance.
anyway. usually an ae86 coilover is made from a modified stock strut leg. and using an insert from an ae92 (front) or sw20 mr2 (front or rear). the housing is also shortended, a section cut out below the internal threads then the top piece is welded back on, typically around 30mm. a spacer will be required also (inside the strut leg under the insert).
then the stock spring perch is cut off and a threaded coilover sleeve fitted, usually welded on.
Previous Topic:WTB heavy duty clutch
Next Topic:WTD: Steel, "front" mounted engine mounts
Current Time: Thu Oct 29 19:25:01 UTC 2026
Total time taken to generate the page: 0.015290975570679 seconds
