Classifieds » Parts Wanted » WTD: Steel, "front" mounted engine mounts
matt_84
Ipswich
WTD: Steel, "front" mounted engine mounts Thu, 16 December 2004 04:18 Go to next message
Need a set of these mounts, anybody? I've got some gen 3 injectors, if by some rare stroke of luck anyone would like to swap.
Just have to be sure they're not the alloy, rear mounted type.
As per;
http://www.toymods.org.au/Darren/build_notes.htm
Re: WTD: Steel, "front" mounted engine mounts Thu, 16 December 2004 05:08 Go to previous messageGo to next message
When you say front mounted, you mean the ones from a GA70 Supra cut?
matt_84
Ipswich
Re: WTD: Steel, "front" mounted engine mounts Thu, 16 December 2004 07:39 Go to previous messageGo to next message
I'm not sure, I'm fairly sure my engine came from a ga70, but has rear mounted alloy type mounts...Hmmm
According a search, the GA61, GX61, GX71, GX81, GZ10 have the correct mounts, can't find whether GA70's have the right ones though. If they are, mine must be either a freak, or not from a GA70.
EDIT: I need ones that are bolted to the position indicated "mid" on the following pic;
http://www.toymods.org.au/Darren/mount(14).jpg
[Updated on: Thu, 16 December 2004 07:43]
Siktoy ra23
Plumpton/sydney
Re: WTD: Steel, "front" mounted engine mounts Thu, 16 December 2004 10:33 Go to previous message
Matt
don't bother with trying to get them mounts just cut the mounts off you crossmember and weld mounting plates on there to bolt the engine to
Previous Topic:AE86 Coilover. *dimensions*
Next Topic:Front Mount Intercooler and pipes suit ST162
Current Time: Thu Oct 29 15:57:10 UTC 2026
Total time taken to generate the page: 0.12205004692078 seconds
