Toymods » Tech & Conversions » 1G Throttle postition sensor
amon
Darwin
icon5.gif  1G Throttle postition sensor Thu, 16 December 2004 08:12 Go to next message
i think my sensor has corrupted it seems to break down a little and run a bit rough at a certain position where you would normally sit at cruise speed.
but touch the accelerator a fraction and we are off and as smooth as,or if i race though my changes and sit on 130 i am laughing not...
anyhoo does that sound right? and does anyone have a sparey or tell us where i can get one
Ta Guy Confused
Re: 1G Throttle postition sensor Thu, 16 December 2004 12:19 Go to previous messageGo to next message
what model of 1G? some have TPS with rather complex switch arrangement inside , others use a simple variable resistor with an idle (or is it WOT) switch.
either could be dirty/injfected with oil, moisture, corrosion - or actually damaged, in which case it's good to know which you need.
dont ask me which one is what version fo engine tho... 'cause i dont know.
M.W.P.
Rocky Mountains, Canada
Re: 1G Throttle postition sensor Thu, 16 December 2004 12:40 Go to previous messageGo to next message
Nope, not the TPS...
Sounds more like a dead EGO sensor or bad EGO sensor wiring connections.
dispatcher
Malaysia,Kuala Lumpur
Re: 1G Throttle postition sensor Thu, 16 December 2004 12:58 Go to previous messageGo to next message
EGO sensor ? picture or diagram please ? Smile
Re: 1G Throttle postition sensor Thu, 16 December 2004 13:11 Go to previous messageGo to next message
EGO = O2 sensor - thing attached to cast housing that joins the two turbo exits.
analyses O2 content of combustion gases.
Dirty_Sanchez
Re: 1G Throttle postition sensor Thu, 16 December 2004 22:48 Go to previous messageGo to next message
i've got the exact same problem with mine. I'd be doing 60 or so, with my foot staying still and then it would start to drop off. I put my foot down a bit and it goes back to normal.
It's driving me nuts Confused
Fattony
Re: 1G Throttle postition sensor Fri, 17 December 2004 07:00 Go to previous messageGo to next message
I doubt it is the tps also. In finding out a problem with my car under accelaration which turned out to be the afm maxing out, we went through the procedure of testing the tps. This was done by unplugging it. Car still ran like it did before (which was fine under normal throttle) it did not make the car drop of power at cruising speed, as you will find that the tps is used for acceleration enrichement. Fueling ect is controlled by afm and your cas. You might have a fault with your afm. The shitty trap door could be gettin jamed open and causing the car to run rich and therefore make jack all power. This has also happend to me and when comming to a stop the motor stalled. Just a thought and perhaps something for you to look into.
Cheers Adam
[Updated on: Fri, 17 December 2004 07:01]
dispatcher
Re: 1G Throttle postition sensor Fri, 17 December 2004 11:36 Go to previous messageGo to next message
So what's the best way to 'clean' the AFM ? Would i need to 'reset' the springs ? It's alredy been 'tampered' with when i got the half cut from Japan.
Fattony
Re: 1G Throttle postition sensor Fri, 17 December 2004 12:19 Go to previous messageGo to next message
Well i really dont have a problem with the afm sticking, only did it once on me. I just pulled the top cover of and freeded the needle and it aint done it since. THough i dont know if this would fix it. If your afm has been tampered with it aint a good sign, chances are that your spring might be to tight or loose and your mixtures are up to shit. Can you describe exactly wats happening when your car looses power, What does the car motor actually do, cut out ect?
Cheers Adam
dispatcher
Re: 1G Throttle postition sensor Fri, 17 December 2004 12:29 Go to previous messageGo to next message
Nothing serious yet,Engine was Mod earlier...so AFM was adjusted to compensate. Will have to adjust spring again..to see if the mixture is right.
amon
Darwin
Re: 1G Throttle postition sensor Sat, 18 December 2004 22:16 Go to previous messageGo to next message
Well i pulled my 02 sensor out and cleaned it the best i could ,the car drove instantly better but still has a milder case of prob before so i might replace 02 sensor and go from there.
Where can i get one and how much?
Tanks Fellas
Guy Smile
amon
Darwin
Re: 1G Throttle postition sensor Tue, 11 January 2005 08:37 Go to previous message
Right,was not o2 sensor replaced TPS[finaly a common part cheap as chips]ran again much better smoother so maybe cured?
Are the any tips on how to put one in,i scored a line from the throttle body on to the plastic of the rooted one so i could put it back in at the right spot but what about the new one.
if anyone can help
ps the TPS came out of a 89-92 corolla
Ta Guy
Previous Topic:Series II 4AGZE Igniter options (CAS/DFI)
Next Topic:3K radiator for 2TG??, is it ok?
Current Time: Thu Nov 26 11:46:54 UTC 2026
Total time taken to generate the page: 0.0070450305938721 seconds
