Toymods » Tech & Conversions » Speedo Re-Calibration
Tomski
Speedo Re-Calibration Thu, 16 December 2004 08:41 Go to next message
Hi All,
I have an 04 Liberty and am upgrading the stock tyres 215/45R17 to a decent set of 235/40R18. I know this is going to throw out my speedo and odometer.
How do I go about re-calibrating everything or can anyone recommend where I get this done..I'm in Sydney..
Cheers Everyone
Tomski
Re: Speedo Re-Calibration Thu, 16 December 2004 08:44 Go to previous messageGo to next message
Why not get 235/35/R18's?
Or 215/40/R18's?
Then you speedo would be perfect.
Thats the logical and normal thing to do.
Are you not normal?
sideshow
Re: Speedo Re-Calibration Thu, 16 December 2004 09:26 Go to previous messageGo to next message
if your speedo is electronic
i can seel you a speedo ratio box and its fully adjustable
to make your speedo faster or slower
jaycar have a kit out but it is always delayed its release day
Tomski
Re: Speedo Re-Calibration Thu, 16 December 2004 10:08 Go to previous messageGo to next message
Unfortunately the Maths of it isn't that easy.
Try These sites to see what I mean
http://www.1010tires.com/TireSizeCalculator.asp?ac tion=submit\
OR
http://secret-secret.com/turbo/DIY/tirecalc/turbot ire.html
The rolling diameter changes with width and profile of the tyre.
If I had a mechanical speedo, then I have no problems as I just send it to a mechanic and he can calibrate it. But electronic speedo's are more funny. I've spoken to 3 Auto Electricians and they alll said that they don't have the equipment. Subaru doesn't want to touch it either.
T
Corona RT142
Campbelltown
Re: Speedo Re-Calibration Thu, 16 December 2004 10:17 Go to previous messageGo to next message
not really 235x.4x2+18x25.4=645.2
215x.45x2+17x25.4=625.3
The speedo would be reading under by 3%
sideshow
Re: Speedo Re-Calibration Thu, 16 December 2004 12:02 Go to previous messageGo to next message
it is piss easy to do
i have devices that adjust the signal comin in to what goes out to the speedo
all u need to do is get a car with accurate speedo to drive beside you and you adjust yours till its similar
mind you its not 100% accurate but if u put the car on the dyno then u can adjust it to be accurate
i have fitted many of them and its no problem
i dont know what theyre talkin about
Conquest
Sydney/Wollongong
Re: Speedo Re-Calibration Thu, 16 December 2004 12:12 Go to previous messageGo to next message
Another tyre size calculator, the best one i've found so far Cool
http://www.miata.net/garage/tirecalc.html
Re: Speedo Re-Calibration Thu, 16 December 2004 13:55 Go to previous messageGo to next message
Tomski wrote on Thu, 16 December 2004 18:08
Actually, those tyre sizes I listed will make your speedo accurate within less than 1% (0.6% actually).
As opposed to the tyre you suggested which is 3% out.
stark
Re: Speedo Re-Calibration Thu, 16 December 2004 14:05 Go to previous messageGo to next message
Jaycar sells a kit which modifies the pulse signal from the gearbox to the speedo.. There $70 from memory...
RAV-GT4
Toymods member
Rydalmere, NSW
Re: Speedo Re-Calibration Fri, 17 December 2004 00:49 Go to previous messageGo to next message
Good thread this, as mine is currently out as well. It was supposed to be running stock 215/70R16's all round, but it's now running 255/50R17's all round (beefy bastards) and not only that, the gearbox is from an ST205, so it's calibrated to turn the speedo at the ST205's factory rim and tyre spec's and rolling diameters. Sleep It's been thrown WAY out now, running approx. 5km/h slower (on the speedo) than actual speeds at around 50km/h. I really need one of these calibration units... Rolling Eyes
How hard are they to install on an electronic sender (gearbox -->> speedo)?
Bobski
Re: Speedo Re-Calibration Fri, 17 December 2004 01:10 Go to previous messageGo to next message
while u guys are calculating stuff, help me out with this, i had a standard diff in my sprinter before 4.1 i think, my new lsd one is 4.3, whats the differance in speed?
I think when im going 70 speedo says 77 so yeah
Thanx
Adam
Re: Speedo Re-Calibration Fri, 17 December 2004 01:13 Go to previous message
Bobski wrote on Fri, 17 December 2004 09:10
Think about it dude, you're revs have increased but 4.3/4.1 ~ 5%
Therefore for any given speed, you speedo will now read higher.
So 70 on the speedo, is 73.5 in real life.
But, if you tyres are out, or your gbox has been changed, then you can't even go by that.
Previous Topic:Thermatic fan choice?
Next Topic:dead 4ac omg no!
Current Time: Sun Oct 18 01:14:15 UTC 2026
Total time taken to generate the page: 0.00553297996521 seconds
