Toymods » Tech & Conversions » Supercharged MR2 check engine light?
4agte
Toronto, Downtown
Supercharged MR2 check engine light? Thu, 16 December 2004 10:44 Go to next message
The other day we changed the clutch and gearbox on my sc finally i have put it all bak together and now i am getting a check engine light when the engine is reved not at idle. Im guessing its something i have forgotten to plug in anyone have any ideas? The timing hasnt been altered and all the ignition leads are on tight. The engine dosent sound rough at all...
PerformanceCars
Re: Supercharged MR2 check engine light? Thu, 16 December 2004 11:44 Go to previous messageGo to next message
speed sensor?? put it into diagnosis mode - it will basically tell you what is wrong.. i assume you can do this with mr2's
^ Search..
4agte
Toronto, Downtown
Re: Supercharged MR2 check engine light? Thu, 16 December 2004 11:48 Go to previous messageGo to next message
is there a problem with not running a speed sensor?
PerformanceCars
Re: Supercharged MR2 check engine light? Thu, 16 December 2004 11:53 Go to previous messageGo to next message
not 100% sure with the mr2 but i know with my 20v the speed sensor not being hooked up will put the check light on AND reduce the rev limit of the engine.. If that is the problem.. putting it into diagnosis mode is really easy.. takes 2 minutes.
4agte
Toronto, Downtown
Re: Supercharged MR2 check engine light? Thu, 16 December 2004 11:57 Go to previous messageGo to next message
the speed sensor is attached to the gearbox right under the thermostat ?
feral4mr2
Bundaberg, Qld.
Re: Supercharged MR2 check engine light? Thu, 16 December 2004 12:59 Go to previous messageGo to next message
when i did the gze swap in '99 the check engine light would come on after about 5 mins of operation and stay on. i found no faults and the ECU didnt throw any codes so i just kept flooging it.. Evil or Very Mad
oneday it just went away and didnt do it again.
4agte
Toronto, Downtown
Re: Supercharged MR2 check engine light? Thu, 16 December 2004 21:02 Go to previous messageGo to next message
that is exactly what happens feral it comes on after a while not straight away. hrmmm sounds like i need to check the fault code from the ecu.
[Updated on: Thu, 16 December 2004 21:03]
FKN16V
NSW, East Coast
Re: Supercharged MR2 check engine light? Sat, 18 December 2004 01:37 Go to previous message
find out which fault the ecu is telling you then adjust replace that particular sensorproblem, pos
Steve
Previous Topic:RA40 Master Brake Cyl Specs
Next Topic:BEAMS Red Top 3SGE ECUPIN OUT wiring diagram required
Current Time: Wed Oct 14 12:05:13 UTC 2026
Total time taken to generate the page: 0.02314019203186 seconds
