Toymods » Tech & Conversions » Removing MA61 Instrument panel
Supra Saiyan
Removing MA61 Instrument panel Fri, 17 December 2004 00:01 Go to next message
How do you remove it?!?!? Sad
I've unscrewed and removed the cover for it, how do I get the panel out?
STR8 2.8
Re: Removing MA61 Instrument panel Fri, 17 December 2004 00:22 Go to previous messageGo to next message
what do you want to remove?
you say you have removed the "cover",
do you mean the surround that holds the rear wiper control etc. ?
or the actual clear plastic cover over the speedo etc.?
rsdeo
Burlington, On. Canada
Re: Removing MA61 Instrument panel Fri, 17 December 2004 00:23 Go to previous messageGo to next message
The panel below the instrument cluster must be removed. Try taking the little rectengular panels in the lower panel off to get at the instrument cluster mounting screws.
Re: Removing MA61 Instrument panel Fri, 17 December 2004 00:27 Go to previous messageGo to next message
After the cover is off, I think there is 2 screws at the top, and 2 at the sides, (from memory), then get your hand up under the dash and pull the speedo cable out.
Then just inch the dash cluster forward and inplug the wires from the rear.
There are 4 or 5 wires there.
Wire number 12 is the 4 pulse per speedo rev signal
http://www.cygnusx1.net/supra/library/TSRM_MKII/be /BE_033.gif
Supra Saiyan
Re: Removing MA61 Instrument panel Fri, 17 December 2004 00:29 Go to previous messageGo to next message
I need to remove the digital instrument panel
I've taken off the cover above it and i've just removed the steering column cover. I think the instrument panel is being held by wires at the back.
Supra Saiyan
Re: Removing MA61 Instrument panel Fri, 17 December 2004 01:28 Go to previous messageGo to next message
ok, so now that i've found the speed signal wire, how do i go about connecting my speedo wire from the control unit to it?
Just solder it on somehow?
Re: Removing MA61 Instrument panel Fri, 17 December 2004 01:31 Go to previous messageGo to next message
Yeah, grab some side cutters or wire strippers, and strip some insulation off the wire, without cutting it through, and without removing it from the plug.
Then just wrap the new wire around this bare section, and solder it up, and tape it up.
You can then remove it later and have the car still working as before.
rob_RA40
c'town, NSW
Re: Removing MA61 Instrument panel Fri, 17 December 2004 01:39 Go to previous messageGo to next message
BESTEST TOOL IN TEH WORLD
http://www1.jaycar.com.au/products_uploaded/productLarge_7240.jpg
Re: Removing MA61 Instrument panel Fri, 17 December 2004 01:41 Go to previous messageGo to next message
Doesn't look enough like a WST for my liking
Supra Saiyan
Re: Removing MA61 Instrument panel Fri, 17 December 2004 02:54 Go to previous messageGo to next message
awesome. Very Happy its all connected now. all thats left now is the illumination wire. now, gotta get sum lunch and get ready for work Crying or Very Sad
thanks again CrUZsida
Re: Removing MA61 Instrument panel Fri, 17 December 2004 02:55 Go to previous messageGo to next message
I'm still waiting on photo's of these gauges.
Supra Saiyan
Re: Removing MA61 Instrument panel Fri, 17 December 2004 03:03 Go to previous messageGo to next message
soon, soon Very Happy
Supra Saiyan
Re: Removing MA61 Instrument panel Fri, 17 December 2004 03:12 Go to previous messageGo to next message
by the way, my cig lighter doesnt work...where else can i connect the illumination wire to?
Re: Removing MA61 Instrument panel Fri, 17 December 2004 03:14 Go to previous messageGo to next message
Just coz the cig lighter doesn't work doesnt mean the light around it doesn't.
Does that light up?
Do the Aus delivered Ma61's have a light in the ashtray? or is that just a JDM thing?
Also the light that lights up the heater controls is another good place to get the signal.
Supra Saiyan
Re: Removing MA61 Instrument panel Fri, 17 December 2004 03:20 Go to previous messageGo to next message
cig lighter doesnt light up at all. neither do the heater controls, and ashtray doesnt have a light.
boo Sad
Re: Removing MA61 Instrument panel Fri, 17 December 2004 03:21 Go to previous messageGo to next message
I'd say you either have a few blown globes, or a blown fuse.
Test the voltage to the globes with the lights on, that will tell you if the fuse is ok.
Supra Saiyan
Re: Removing MA61 Instrument panel Fri, 17 December 2004 04:04 Go to previous messageGo to next message
ok, i just quickly checked the fuse and they're ok. must be the globe then. I'll check up on it later cos i gotta go to work. thanks for the advice
Re: Removing MA61 Instrument panel Fri, 17 December 2004 10:33 Go to previous message
Get power for illumination from the dimmer switch, that's what the rest of the dash lights are hooked up to. It's nice and easy to get at as well.
Previous Topic:oops...
Next Topic:Turbo for 18rg HKS manifold (70x85mm) (TO4?)
Current Time: Sun Oct 18 08:02:19 UTC 2026
Total time taken to generate the page: 0.043319940567017 seconds
