Toymods » Tech & Conversions » AW11 Tyre pressure
Zhyr
Sunshine Coast
AW11 Tyre pressure Fri, 17 December 2004 07:51 Go to next message
any idea whats the best tyre pressure to run on standard tyres?
muaythaiman
Re: AW11 Tyre pressure Fri, 17 December 2004 08:02 Go to previous messageGo to next message
32psi?
toof
Re: AW11 Tyre pressure Fri, 17 December 2004 08:07 Go to previous messageGo to next message
we run 38 in 205/45/16's and its pretty nice and tight.
GUN METAL 87 SC
SYDNEY
Re: AW11 Tyre pressure Tue, 21 December 2004 01:59 Go to previous messageGo to next message
It depends on many factors, even with the starndard wheels and tyres.
I have had my AW11 for 15 years with varoiuse wheel tyre combos both on and off the race track.
on standard wheels 14x6 with the Bridgestone RE88 i used to run 33 front and 38 rear for around the street, raise them a few PSI if you are doing a longer trip or on the track.
Different tyres ride, handle and wear differently, not to mention driving styles !! so i reckon just experiment.
Note the factory setting are very conservative as is the wheel alignment settings !!
I am running way more negative camber than the factory specs and running toe out not toe in on the front.
good luck and have fun.
Scott Dood
Starfire
Re: AW11 Tyre pressure Wed, 22 December 2004 07:17 Go to previous messageGo to next message
I have a tire placard for my 89sc that just arrived from the US. I will check it out when I get home and post the details. The specified pressures are suprisingly low (something like 24 at the front and 29 at the rear - but dont quote me on that, Ill check for sure and post tomorrow some time).
Starfire
Re: AW11 Tyre pressure Tue, 28 December 2004 03:28 Go to previous messageGo to next message
Slack - I know...
TOYOTA MR2
RECOMMENDED RIM SIZE: 6-JJx14
RECOMMENDED TYRE SIZE: 185/60R14 82H
RECOMMENDED COLD TYRE INFLATION PRESSURE FOR NORMAL OPERATION
FRONT: 180 (240) KPA
REAR: 200 (260) KPA
( ) : AT SPEED OVER 140KM/H
THE TYRES FITTED TO THIS VEHICLE SHALL HAVE A MAXIMUM LOAD RATING NOT LESS THAN 475KG, OR A LOAD INDEX OF 82 AND A SPEED CATEGORY OF H
SEE OWNER'S MANUAL FOR ADDITIONAL INFORMATION
old_mr2
Re: AW11 Tyre pressure Tue, 28 December 2004 07:52 Go to previous messageGo to next message
Hey starfire come on over to AW11 owners anonymous and tell us about your ride and AW11 experiences
4agte
Toronto, Downtown
Re: AW11 Tyre pressure Tue, 28 December 2004 10:00 Go to previous message
i run 34 psi front and 32 psi rear seems to work well for the street b ut for the track its 40 front and 38 rear
[Updated on: Tue, 28 December 2004 10:00]
Previous Topic:MR2 HEAD LITES, GLOBE DRAMAS!!!
Next Topic:T50 rear seal
Current Time: Fri Nov 20 13:17:33 UTC 2026
Total time taken to generate the page: 0.005357027053833 seconds
