Toymods » Tech & Conversions » boost problems
cplux
boost problems Fri, 17 December 2004 11:09 Go to next message
Hi all I have a sc14 supercharged hilux petrol running ea falcon throttle body injection.
I recently installed a suby w/a intercooler and since then for some reason I am not developing much boost (less than 0.5psi)
I have put it down to the bypass/blowoff valve setup but cannot figure out what is different than before.
I used to run a bosch compressor bypass valve and the sytem used to work properly. 5-6psi The only physical differences now being
1.) intercooler
2.) Bypass valve recirculates air closer to the s.c intake than before.
If i run a blowoff valve it will develop alot more boost 4-5psi, but i do not wish to vent air to atmosphere and do not want to attract anymore police/rta attention to my car than is neccessary. i.e noise. however if i convert the blowoff to recirculate air i have the boost loss problem.
Can anyone explain this and how i can get around it. only thing i can think of is to move the bypass hose away from s.c input.
pic is sttached. throttle plate/butterfly valve lay beneath black bosch cbv. and the the air used to recirculate up the intake at a point near the power steering pump previously.
I just cant figure out what has changed other than slight flow loss through intercooler.
http://img.villagephotos.com/p/2004-10/867412/Untitled.jpg
Re: boost problems Fri, 17 December 2004 12:37 Go to previous messageGo to next message
Is the throttle before or after the blower?
cplux
Re: boost problems Fri, 17 December 2004 17:24 Go to previous message
after t/body. and system uses wolf 3d so no afm etc. just map, air/water temp o2 sensors.
Also s.c vent piping is not hooked up to anything, dont know if this makes a difference, its the same as it was before but.
[Updated on: Fri, 17 December 2004 17:27]
Previous Topic:3TGTE CAMS
Next Topic:18inch rims 4 ta22 is it possible
Current Time: Tue Oct 20 04:54:09 UTC 2026
Total time taken to generate the page: 0.0044999122619629 seconds
