Toymods » Tech & Conversions » Stock 1J Injectors
KOFFEE-BLACK
Stock 1J Injectors Fri, 17 December 2004 23:44 Go to next message
Hey guys,
How much can the 1j injectors hold?
I remember, a friend who has a JZA80 TT, said his stock injectors, should handle 280rwkw, and he was right on the money, anything above this figure, they would max out!
Cheers.
stark
Re: Stock 1J Injectors Sat, 18 December 2004 04:32 Go to previous messageGo to next message
Ok... first of all the 1JZ GTE comes with two different type of injectors...
The first are the Yellow top side feed injectors found on the Twin Turbo variants...
The second are Denso Grey top Top feed injectors as found on the VVTi Single turbo version of the engine..
Both type of injectors have the same flow rate of about 370-380cc
As for there power handling if you read the lates zoom mag No 84 (The one with the Yellow VL on the cover) There is a blue 1JZ powered Hilux with stock injectors which puts out 242KW at the wheels
Chris Davey
sunny coast, qld
Re: Stock 1J Injectors Sun, 19 December 2004 00:48 Go to previous messageGo to next message
stark wrote on Sat, 18 December 2004 15:32
seconded. Although that would be very close to maxing them out. I assume this Hilux is a manual car.
Re: Stock 1J Injectors Sun, 19 December 2004 01:34 Go to previous messageGo to next message
Supposed to be with a stock manual ECU, manual trans but custom intake/exhaust manifold, hence the claimed low boost (.89)
Manny
Re: Stock 1J Injectors Sun, 19 December 2004 10:13 Go to previous messageGo to next message
My stock injectors were at 92% duty cycle at 245rwkw with stock ECU/fuel pressure - wouldn't want to run any more than that as detonation won't be too far away.
stark
Re: Stock 1J Injectors Sun, 19 December 2004 11:00 Go to previous messageGo to next message
Yeah the rule of thumb is that you usually dont want to run your injetors at anything more than 80 - 85 percent duty cycle otherwise yuour injectors can fail..
KOFFEE-BLACK
Re: Stock 1J Injectors Sun, 19 December 2004 12:02 Go to previous message
cool, thanks guys!
Previous Topic:4AGZE ke70 gearbox diff etc
Next Topic:No heat from heater.. ?
Current Time: Thu Nov 19 14:35:49 UTC 2026
Total time taken to generate the page: 0.0055160522460938 seconds
