Toymods » Tech & Conversions » ma70 diff conversion???
driftpig
ballarat
ma70 diff conversion??? Sat, 18 December 2004 00:48 Go to next message
hi guys, i just got a ma70 supra and am a keen drifter, ive always owned nissans but i went outside the square and got a supra, it has a 5 spd, 1jzgte, gtr cooler, adj cam gears, 13 psi, alimin radiator, strut brace, susp work, the only problem is that the car aint a drifter due to a shitty diff, im wondering how i'd go bout putting an lsd in this and what sort of money am i looking at, will a jza80 diff fit?? i would prefer a direct bolt in, or would it just be easier to pull out the old welder and lock the bastard.
cheers and thanks in advance for any help.
Danny
Re: ma70 diff conversion??? Sat, 18 December 2004 00:57 Go to previous messageGo to next message
Chances are it already has a LSD in it, but it's worn out from the last wannabe-drifter who owned it. Check the build plate on the firewall and tell us what the axle code is.
driftpig
ballarat
Re: ma70 diff conversion??? Sat, 18 December 2004 05:19 Go to previous messageGo to next message
yeah it has g258 and w58 on it, guessin w58 is trans code, it came with auto and 7mge in it, now its manual 1jz so not sure what else had been played with.
Re: ma70 diff conversion??? Sat, 18 December 2004 15:40 Go to previous messageGo to next message
W58 is the transmission code for the 5-speed manual, so something weird is going on if it was originally auto. Confused
Also G258 can't be right for the axle code, the last digit should be 4 (open centre) or 5 (LSD). The middle two digits indicate a 4.556:1 final drive ratio.
[Updated on: Sat, 18 December 2004 15:40]
Bugman
Re: ma70 diff conversion??? Sun, 19 December 2004 01:34 Go to previous messageGo to next message
and 8 denotes a torsen center.
Re: ma70 diff conversion??? Sun, 19 December 2004 01:38 Go to previous messageGo to next message
If you're at all serious my advice would be to fit an aftermarket LSD, e.g. Kaaz, Cusco etc. Should cost $1500-2000, and sure does make a big difference to the way the car behaves. Personally I think it's streets ahead of a weldy, too! A cheaper option might be a spool though.
Bugman
Re: ma70 diff conversion??? Sun, 19 December 2004 01:42 Go to previous messageGo to next message
oh.. you could always undo the eight or so bolts on the rear plate for the diff and take a look. and change your diff oil while your at it. a diff loves new oil.
or just take the filler nut out and have a look through the hole with a torch and see if you can see worm gears.
Re: ma70 diff conversion??? Sun, 19 December 2004 02:21 Go to previous messageGo to next message
Bugman wrote on Sun, 19 December 2004 11:34
I'm pretty sure 9 denotes a torsen. Besides, only JZA70's had a torsen and they didn't come with a W58!
Re: ma70 diff conversion??? Sun, 19 December 2004 02:25 Go to previous message
this might help - axle codes:
<http://www.geocities.com/MotorCity/Pit/9975/dataBy Subject/AxleCodes.html
Previous Topic:check engine codes for 67 mini with ep82 GT eng?
Next Topic:Big port vs small port for turbo?
Current Time: Thu Nov 19 19:22:17 UTC 2026
Total time taken to generate the page: 0.0064139366149902 seconds
