Toymods » Tech & Conversions » 4age 20valve bottom end to 16 valve head?
AE86 Levin Melbourne
4age 20valve bottom end to 16 valve head? Sun, 19 December 2004 07:39 Go to next message
does anyone know is it possible to put a 16 valve 4age head directly on to a 20 valve block?
ae86drift
sydney.au
Re: 4age 20valve bottom end to 16 valve head? Sun, 19 December 2004 07:41 Go to previous messageGo to next message
yup
IRA11Y
Club Member
Re: 4age 20valve bottom end to 16 valve head? Sun, 19 December 2004 09:00 Go to previous messageGo to next message
yup
Re: 4age 20valve bottom end to 16 valve head? Mon, 20 December 2004 02:04 Go to previous messageGo to next message
thanks guys...
if the 20 valve piston runs no problem with the 16 valve head, by theory that's the easiest way to get hi compression piston in a 16 valve 4age huh?
[Updated on: Mon, 20 December 2004 02:07]
ae86drift
sydney.au
Re: 4age 20valve bottom end to 16 valve head? Mon, 20 December 2004 04:59 Go to previous messageGo to next message
im not sure that the pistons from a 20v would be a good idea in a 16v head.
as they have 5 valve cuts into the head of the piston. hehe not a good idea.
IRA11Y
Club Member
Re: 4age 20valve bottom end to 16 valve head? Mon, 20 December 2004 06:25 Go to previous messageGo to next message
I wouldnt advise using the 20V piston
Rex_Kelway
Re: 4age 20valve bottom end to 16 valve head? Mon, 20 December 2004 07:15 Go to previous messageGo to next message
If its higher compression you're after in the 20V Rex would suggest the easiest way is also one of the smartest ways. Just fit a thinner head gasket between the stock 20V head and block.
Many companies produce them and with one about 0.6mm they suggest the C/R will be around 11.6.
If its the compression of the 16V you're looking to upratio, then just use a 16V one.
Der
mr_corolla
    none
Re: 4age 20valve bottom end to 16 valve head? Fri, 07 January 2005 11:12 Go to previous message
u got to use the 20V piston
Previous Topic:MA70 rear disc brakes with Z32 callipers - will it work?
Next Topic:Rev's Vs Speed - 2TGEU
Current Time: Mon Nov 2 06:39:14 UTC 2026
Total time taken to generate the page: 0.0079059600830078 seconds
