Toymods » General Car Talk » extractors
Meat_rack
East Maitland NSW
extractors Sun, 19 December 2004 12:35 Go to next message
hi guys
i have been told that the best type of extractors for road use are 4-2-1. but i have also been told that cylinder one and four must join, then two and three before all joining into one. is this true or should you follow your engines firing order?
st184 sillycar
Re: extractors Sun, 19 December 2004 22:30 Go to previous messageGo to next message
Meat_rack wrote on Sun, 19 December 2004 23:35
hi guys
Dude: the objective of extractors is to have pulses evenly spaced when pipes join. That means the primaries need to be joining 1+4 and 2+3 when they merge into the secondaries, because those pistons fire at even intervals from each other, i.e. one whole revolution.
Joining 1+2, 3+4 would probably make a whack off-beat exhaust note (slightly WRX-like perhaps?) but wouldn't be terribly efficient.
I hope that helps.
jesseT18
Castle Hill, Sydney
Re: extractors Sun, 19 December 2004 23:35 Go to previous messageGo to next message
4 to 1 extractors are pretty common?
i read on toymods somewhere, 4-1's give more top end power and 4-2-1's give more low down power, just find out where your engine makes all the power and that'll help u make ur decision
eg: i have a 2tg hybrid with most its power up high, so went with 4-1's
st184 sillycar
Re: extractors Mon, 20 December 2004 01:02 Go to previous messageGo to next message
Depends on who you talk to. Some people swear 4-1 is the only way to go, others say 4-1 just looks pretty and does nothing. I think people who talk trash about either sort have just had/made a poorly tuned set of extractors, or a sloppily made set with poor flow in some of the pipes.
Below From the horses mouth ( Pacemaker )
Quote:
A 4-into-1 design is perhaps the most traditional design. This design is common to the US market and is well used within the drag race fraternity. The basic principle behind the design is that the scavenging effect within the collector cone effects the three remaining pipes (in a V8 half), instead of limiting the pulse to the very next pipe in the sequence. This generally results in a header that performs very well in the mid-range to top end of the engines performace.
A TRI-Y on the other hand splits the firing order evenly and uses the secondary pipes as sequential collectors. This results in generally a greater scavenging effect due to the fact that scavenging is achieved at 2 different points in the header design, firstly at the primary to the secondary collector and secondly to the secondary outlet collector. Generally this improves torque in the lower to mid range perfomance of the engine.
So there ya go: Tri-Y is more efficient at scavanging low-mid RPM, but 4:1 flows easier and starts working better at high RPM.
Tuned-Length DeFillipo extractors for Holden 5L :
http://i7.ebayimg.com/01/i/02/eb/8b/a9_1_b.JPG
Gemini 4cyl 4-2-1 :
http://i6.ebayimg.com/03/i/03/08/7c/c0_1_b.JPG
See - 1+4 join, 2+3 join.
Re: extractors Mon, 20 December 2004 03:52 Go to previous messageGo to next message
When I had mine built, the exhaust shop guy said he'd have to do 4-2-1 because there wasn't enough room for 4-1.
Whether there is any other benefit/problem with 4-2-1 over 4-1 besides size restriction, I don't know.
4-2-1
http://www.oz-enet.com.au/~peewee/extractors/extractors_passengers_side_7.jpg
db__
Re: extractors Mon, 20 December 2004 04:53 Go to previous messageGo to next message
If you look on Billzilla's site, in regards to a 4AGE 4-2-1 extractors are apparently best suited, in the 4+1 2+3 form.
Re: extractors Mon, 20 December 2004 04:56 Go to previous messageGo to next message
db__ wrote on Mon, 20 December 2004 12:53
The matching of ports of the extractors in 4-2-1's is based on the firing order of the motor.
Re: extractors Mon, 20 December 2004 05:43 Go to previous messageGo to next message
my take on all this is that 4-2-1 will give you better scavengine in mid to high rpm... and 4-1 is for top end.. for me that means if you have a power band _starting_ around 6000rpm, you would only want 4-1. but if you have a power band starting around 4-6000rpm, you would want 4-2-1..
4-1 and 4-2-1 also have different length primaries, so there is more to it than just one or the other, as you can tune 4-1 to work with lower rpm.... thing is, when you have a reflected wave travelling up 4 pipes, it will not be as strong as travelling up two pipes Wink
st184 sillycar
Re: extractors Mon, 20 December 2004 10:17 Go to previous messageGo to next message
oldcorollas wrote on Mon, 20 December 2004 16:43
Exactly.
Either type can be tuned for higher or lower RPM by the length of the runners. I guess the harmonics of a 4:1 system are more efficient than 4:2:1 at high RPM. Maybe it's just easier to get bulk-flow through a 4:1 system.
Also, alot of people want to run the stock catalytic convertor, which in most new cars needs to be really close to the engine. That automatically means 4:1 extractors for alot of people, as it can half the distance before you can mount the cat.
riceburna73
Re: extractors Tue, 21 December 2004 03:22 Go to previous messageGo to next message
what about for turbo cars,I never seem to hear anyone doing them,whats the go?
st184 sillycar
Re: extractors Tue, 21 December 2004 07:21 Go to previous messageGo to next message
It doesn't really matter, coz there's so much back-pressure exhaust scavenging will be minimal to non-existant. Also, the intake-charge is being forced into the cylinder hard enough to push the exhaust gas out anyway.
cheese_cracka
Tamworth
Re: extractors Tue, 21 December 2004 10:46 Go to previous messageGo to next message
um hey guys i dont really exactly know wot extractors do..... Embarassed but um would it b worth while getting them put on a 21r-c?
Re: extractors Tue, 21 December 2004 11:57 Go to previous messageGo to next message
cheese_cracka wrote on Tue, 21 December 2004 18:46
No, not really, unless you get them free/cheap
cheese_cracka
Tamworth
Re: extractors Tue, 21 December 2004 12:01 Go to previous messageGo to next message
CrUZsida wrote on Tue, 21 December 2004 22:57
would they add any sort of power increase or would it just make it more fuel efficient(if thats wot it does..??.?)
Meat_rack
East Maitland NSW
Re: extractors Tue, 21 December 2004 12:06 Go to previous messageGo to next message
they will do both
Re: extractors Tue, 21 December 2004 12:32 Go to previous messageGo to next message
Meat_rack wrote on Tue, 21 December 2004 20:06
they will do both
Probably 1-2% of each
cheese_cracka
Tamworth
Re: extractors Tue, 21 December 2004 13:16 Go to previous messageGo to next message
so thars pretty much no point then.....??
Re: extractors Tue, 21 December 2004 13:22 Go to previous messageGo to next message
ahh no...
might help a bit, but only do it if they are free/cheap.
the rest f the exhaust should be upgraded at the same time.
here's mine.. home made.
http://www.materials.unsw.edu.au/~sford/exhaust-2.jpg
Meat_rack
East Maitland NSW
Re: extractors Tue, 21 December 2004 13:23 Go to previous messageGo to next message
well i belive there is a noticeable diffirence when extractors are fitted to a car. plus it means your car doesnt run as hot and therefore less strain on the motor.
Meat_rack
East Maitland NSW
Re: extractors Tue, 21 December 2004 13:29 Go to previous messageGo to next message
hey oldcorollas what does that system that you have on your car sound like as i am thinking about just having one hotdog instead of two.
Henn
Rosanna, Melb
Re: extractors Wed, 22 December 2004 06:10 Go to previous messageGo to next message
Extraactors for turbo engines (Tuned/equal length turbo manifolds) do exist and can make a significant improvement over factory or log type manifolds.
They aren't really that big because you can find improvements elsewhere, eg diff turbo or more boost, cheaper than a really nice manifold.
And post turbo the design of dump pipe and wastegate pipe is an issue in itself.
Hen
st184 sillycar
Re: extractors Wed, 22 December 2004 07:08 Go to previous messageGo to next message
Henn wrote on Wed, 22 December 2004 17:10
Hen
Wouldn't that be more a problem with messy, poor flow through crappy cast factory manifolds, rather than benefits from tuned length exhaust runners? From what I've read, it's most important to keep the pulses at the turbo housing evenly spaced, so that the pressure and flow through the turbine & housing is as even as possible. I think this is where most of the benefit is in twin-scroll exhaust housings, because it's easier to keep the exhaust pulses from different cylinders from "seeing" each other. i.e. an L4 motor would run cyl 1&4 through 1 scroll, 2&3 through the other.
I don't THINK exhaust scavenging is a priority with turbo engines anyway. I think you'd get as much/more benefit from keeping the xsorszt manifold as short as possible, to keep the heat in the gas, and the velocity as high as possible.
hhmmm.. . - ask Peter Luxon at APS. He'll know Razz
Re: extractors Wed, 22 December 2004 10:33 Go to previous messageGo to next message
Meat_rack wrote on Wed, 22 December 2004 00:29
it's very quiet. if you have a cat, it will be as effective as a resonator as it is a pretty big restriction.
this is a 2" system on a 1.3L motor that revs to 8000rpm. i get much more intake noise than the exhaust.
as for turbo manifolds... having equal length pipes will mean the exhaust pulses will hit the turbo at even intervals. that is probably a good thing.
having tuned length is primarily an exhaust scavenging thing, BUT it may help if you manage to have a positive pulse hit the exhaust valve such that you minimise intake blowing through the chamber. but thats a pretty small window of rpm...
White Rabbit
Maitland, NSW
Re: extractors Tue, 28 December 2004 06:28 Go to previous message
Meat rack
Guess what - i just fit extractors to the car that you are buying!! how about that!!
I believe they are 4-2-1's
Stu
Previous Topic:bonnet vents - suppliers??
Next Topic:Initial D -Altezza Episode- TRD*Spoilers*inside
Current Time: Sun Oct 25 02:06:07 UTC 2026
Total time taken to generate the page: 0.006525993347168 seconds
