Toymods » Tech & Conversions » apexi SAFC
drift86levin
brisvegas
apexi SAFC Sun, 19 December 2004 22:33 Go to next message
hey guys, would this actually help for a little more tuning capabilities?
it could be going into my 86
following are the mods to the motor
AE92 map GZE
10psi boost (stock pullys)
TRD HP coated extractors W/ 2.25" mandril exhaust
Custom FMIC
3SGE throttle body w/ machined out down pipe
Flowed (just a wee bit shaved too) head
1mm 3 layer steel headgasket
Bigport cams
i have heard that you can sorta tune that bit of a 'hole' when the mapsensor see's 0psi-1psi of boost, i've heard it kinda leans out for a sec, then richens up..
ae86drift
sydney.au
Re: apexi SAFC Mon, 20 December 2004 05:00 Go to previous messageGo to next message
SFC is a fuel mix controller
can tune at 200rpm increments (for an SAFC2) and at 500pm increments for a SAFC1
so you can richen and lean the mix over the rev range.
takai
Re: apexi SAFC Mon, 20 December 2004 10:50 Go to previous message
Any of the SAFC series will have issues with the AFM GZE ECUs. The MAP ones tend to be a bit more compliant in not retuning around the SAFC.
No idea why it does it, but thats what has been reported on about 5 or 6 forums that im on.
Previous Topic:*Urgent AW11 AC Issues
Next Topic:Difference between 88-89 Celica front strut and 90-93 (st182/4/5) front struts?
Current Time: Sun Oct 18 10:51:53 UTC 2026
Total time taken to generate the page: 0.010567903518677 seconds
