Toymods » Tech & Conversions » 3SGTE into KE25?
toyboy
geelong
3SGTE into KE25? Mon, 20 December 2004 20:17 Go to next message
hi, has anyone done the 3SGTE into a Ke25 converion?
i realy like this engine, very torquey and powerfull
even in standard trim. which gearbox, diff to take 300 flywheel
horses.
would it be able to be registered in vic.
i know this is not a common conversion like the 4age or 13b etc..
but its the one i would like to try.
any help would be greatly apreciated.
steve. Surprised
Toobs
Re: 3SGTE into KE25? Tue, 21 December 2004 04:48 Go to previous messageGo to next message
Re: 3SGTE into a KE25
I doubt this would be legal without going to the point of engineering your car with a custom chassis.
I'm pretty sure 13B's aren't legal in this sort of car either.
It would be an interesting yet extremely difficult conversion to undertake... you might be better off putting in a 3TGTE or 4AGZE in.
3T and 4A conversions are quite common in this sort of car and I'm sure you'll find a reasonable amount of information on the forums if you search hard enough.
toyboy
geelong
Re: 3SGTE into KE25? Tue, 21 December 2004 05:04 Go to previous messageGo to next message
yeah, seen those conversions on here, but its the 3sgte that i want, fantastic low end torque and an easy 150 rwkw. with boost mods. nowhere near as much stuffing around as a 4agte, its their from the factory.
steve.
twincam_ke20
Castlemaine Vic
Re: 3SGTE into KE25? Tue, 21 December 2004 11:32 Go to previous messageGo to next message
hey dude, just got off the phone to ya Smile (the guy with the ke25) i reckon go the 4agte
Re: 3SGTE into KE25? Tue, 21 December 2004 12:22 Go to previous messageGo to next message
13B, not legal, too big.
3SGTE? not legal, too big (probably)
a KE10 is 720kg and can put a 1.7L turbo, KE20 is what? 750? 770?
you could maybe put in a 1.9L turbo, btu thats the limit.
there are 3SGE's in KE2x and KE3X, but the motors are tall, heavier than 4A, and you will not need or use the power... even a 4A is nearly overpowering th thing...
remember that a KE2x is about 3/4 the weight of an AE86....
no point having 300hp, when you will probably only get about 150 or so to the ground Wink
toyboy
geelong
Re: 3SGTE into KE25? Tue, 21 December 2004 16:52 Go to previous messageGo to next message
yeah, im into that sort of thing, lack of traction and such Surprised
steve.
ke382TG
Re: 3SGTE into KE25? Tue, 21 December 2004 23:04 Go to previous messageGo to next message
My 4AGTE will light up the rear tyres (Dunlop FM901's 205/45R16) in the dry in 4th gear at 100 - 110 km/h when boost comes on. That is why I had to change to some stickier rubber on the back as it was a joke to try and get the power to the ground.
Oh and if you don't believe me there are about 4 or 5 CCG members who have been in a car behind me that will verify this claim Very Happy and many scared passengers.
Note: FM901's are not real shit tyres either Smile
I say do the 3SGTE it will be a weapon, but a lot of work and a tight fit. The transmission tunnel needs some "massaging" too in order to fit the W series gearbox.
I won't try and convince you into anything else but my KE25 with 4AGTE has plenty of power for the size of the car and it last made 170rwkw at a dyno day with a slipping clutch (the power curve shows this nicely and a few days after it gave up completely). Clutch is now replaced and gripping well.
If you do the 3SGTE conversion and go to dyno days, make sure you have some mates to sit in the boot for you as every dyno day mine has been to it has needed 3 people to add wieght to the rear end to prevent it from spinnning on the rollers, yes they are a light car Very Happy
4AGTE Vs 3SGTE in a KE25, both options have pros and cons, I would estimate though that final build cost for either would be about the same though.
So go the 3SGTE and let us know how you go.
Edit: of course you should also check what you can legally fit in your car in Victoria, my above comments are based on the ACT where we can still fit a 20B twin turbo to a KE25 and have it registered Shocked
[Updated on: Tue, 21 December 2004 23:18]
Re: 3SGTE into KE25? Tue, 21 December 2004 23:43 Go to previous messageGo to next message
thats just insane!!!!!
i've seen that once before with a similar weight car and an SR20 turbo... it must be hairy and scary!!!!!
if you have about 300Nm (at flywheel) thats about the same torque to weight as a "Sports Sedans", which is just ridiculous. the 3S should do that with under a Bar of boost!!.
i'd love to see you do the 3SGTE also, but you may have to lighten your right foot a little.. heck even a stock one would be monstrous!!
ke382TG
Re: 3SGTE into KE25? Wed, 22 December 2004 00:05 Go to previous messageGo to next message
I will try and dig up a dyno sheet with torque plotted on it, most of the ones I have have show air:fuel plotted instead. Full boost comes on very early so it pulls nice and hard from down low in the rpm range.
I am keen to throw it on the dyno in the New Year and see what some of my minor adjustments have netted me Up To Something might throw it on the dyno at summernats for a look-see (no chance in hell of getting a place but it's worth a run to get a nice pic of your car and a laminated dyno sheet Very Happy ).
You can get into some trouble and wet weather driving means I flick the switch to low boost and take it nice and easy.
Note: my brother has nearly completed his 4AGTE corolla and it made quite a few more ponies than mine prior to the rebuild, now it will probably make a few more Evil or Very Mad
toyboy
geelong
Re: 3SGTE into KE25? Wed, 22 December 2004 06:48 Go to previous messageGo to next message
wow te382tg thats impressive, i was cosidering the 4agte version, i just looked through toymods and noticed how difficult and expensive this conversion can be though with a decent gearbox (w series). but now im quite interested in the nissan ca18det.
the motor and box are strong and easily modded for good power.
they are also cheap and plentifull.
any sugestions on this setup in a ke25 as im quite sure this could be legaly accomplished in vic. being a 1.8 ltr.
steve. Very Happy
[Updated on: Wed, 22 December 2004 08:13]
twincam_ke20
Castlemaine Vic
Re: 3SGTE into KE25? Wed, 22 December 2004 09:29 Go to previous messageGo to next message
CA's cheap and plentiful ?!?! haah a mate of mine just took finished his ca18det conversion in to his 1200 wagon, took him ages to find a CA, called SA, SYD and vic and all said that CA's are getting hard to come by these days.
but he finally found one at CVAP (forum sponser) with our an ecu, for 1400.
why cant you just be happy with a 4agte?! proven power i feel.
toyboy
geelong
Re: 3SGTE into KE25? Wed, 22 December 2004 17:03 Go to previous messageGo to next message
im thinking of about 4 years ago, they were $795 for motor and box and you couldnt go to an engine importers in this country without tripping over at least two of em. steve.
DJ345
eastern suburbs, Melb
Re: 3SGTE into KE25? Thu, 23 December 2004 04:18 Go to previous messageGo to next message
Steve I have a 3sge sitting in the engine bay of my ke25 and it does fit.
There would be just enough room for a turbo and to run intercooler lines etc. I may turbo it down the track.
It has a W57 sitting behind it. To get it to fit i had to tap the left hand side if the trans tunnel out, but not much. A the shifter from an RA60 will fit out the original hole in the floor.
If I had a digi camera i could send you some pictures or upload them but don't have a qlue how to.
There is a guy in NZ with a 3SGTE in a KE20 but its not the neatest conversion.
As you can guess Id agree with doing this conversion good luck
Damian
toyboy
geelong
Re: 3SGTE into KE25? Thu, 23 December 2004 04:34 Go to previous messageGo to next message
say dj345, how hard was it to get the w series box to fit for rwd in your car, and how does vicroads veiw the 3sge and 3sgte
respectiveley for rego purposes in the ke25.
good to see a fellow victorian with a decent car, maybee though your tired of your car and would like to sell it cheaply because your growing family no longer fits?
steve.
[Updated on: Thu, 23 December 2004 04:42]
twincam_ke20
Castlemaine Vic
Re: 3SGTE into KE25? Fri, 24 December 2004 03:30 Go to previous messageGo to next message
if you are after a 3sge, a mate up here has one for sale if need be.
YelloRolla
On your mum!
Re: 3SGTE into KE25? Fri, 24 December 2004 05:30 Go to previous message
For the legality of it I think that you should consult an approved engineer in your state. If the 3S GTE is legal, then I would go for that (I have considered this conversion which is why there is a 3S in my garage) - I dont see it being that much harder than the 3TGTE, just more time would be needed to fabricate the water lines, and the conversion gear required (sump, flywheel, starter etc).
As for the CA? I don't see the point - if 1.8L is as big as you are allowed to go, then I would suggest that the 3TGTE (old now and unlikely to get one from the importers) is a go.
ke382tg has a well proven 4AGTE combo (one that needs plenty of respect)and I have the 3TGTE combo well proven too!
As for the cost? Speed costs money. How fast do you wanna go?
$0.02
Previous Topic:TA22 Rear Windows
Next Topic:LSD's
Current Time: Wed Nov 18 22:06:08 UTC 2026
Total time taken to generate the page: 0.013313055038452 seconds
