Toymods » Tech & Conversions » sprinter fuel?
cri_ag
northern beaches
sprinter fuel? Wed, 16 October 2002 10:22 Go to next message
ive just brought a sprinter and im not sure if its suposed to take leaded or unleaded fuel, i asume its leaded because of the age? its just the standard 4ac motor. is the 4age leaded or unleaded?
also when i turn the igniton to 'on' there is a knocking sound in the rear, is this an electric fuel pump? i was under the impresion that sprinters had a mechanical fuel pump driven of the crank?
DAMO
MELBOURNE
Re: sprinter fuel? Wed, 16 October 2002 10:45 Go to previous messageGo to next message
4a-c is leaded and the 4a-ge's are unleaded. Sounds like your exhaust is knocking on something. The fuel pump is mechanical on the 4a-c
cri_ag
northern beaches
Re: sprinter fuel? Wed, 16 October 2002 11:22 Go to previous messageGo to next message
the knocking noise is when the engine is not running, just when the ignition is "on"
SW20R
Re: sprinter fuel? Wed, 16 October 2002 14:24 Go to previous messageGo to next message
the 4AC was Leaded?
but i had an unleaded sticker.. and only fed her that.. hmm?
Hunty
Re: sprinter fuel? Wed, 16 October 2002 19:22 Go to previous messageGo to next message
The 4ac's in sprinters are leaded, most if not all 4acs built before 1986 are leaded. After that they added all this anti pollution crap cat converters and the like and they made them run unleaded.
Hunty
Re: sprinter fuel? Wed, 16 October 2002 19:24 Go to previous messageGo to next message
As for the knocking, i can't think of anything electrically operated that would cause that sound in the rear of a 4ac powered sprinter, the 4acs are mechanical fuel pump
gt20v
Re: sprinter fuel? Wed, 16 October 2002 19:57 Go to previous messageGo to next message
the 4ac are leaded as you can tell by the fuel filler neck, but it's one of those engines that you can run unleaded without any problems, but timing needs to be adjusted, most likely it's already been adjusted to run unleaded..
how does the "knocking" sound sounds like? If it's a "buzzing" noise, then it's a fuel pump, 4ac uses mechanical fuel pump, but there's nothing stopping you from installing an electric fuel pump right?
cri_ag
northern beaches
Re: sprinter fuel? Thu, 17 October 2002 08:07 Go to previous messageGo to next message
its like a tap tap tap, my mate has a dato 1200 ute with a ca18 in it with a electric fuel pump and it sounds just like that just a bit quieter.
last night i found a wire that comes from the rear of the car near the tank to the front. it has an inline fuse, so i took the fuse out and turned the ignition on and the knocking wasnt there. i started the car and after about a minute or to it died (through lack of fuel i suspect)i put the fuse back in and started it and it ran fine. so i supose this means someone has fitted an electric pump?
Hunty
Re: sprinter fuel? Thu, 17 October 2002 14:22 Go to previous messageGo to next message
i looked at doin the conversion to a efi fuel tank and internal pump on my 4ac just to save me doing it later when i install the 20v, but i decided against it as the fuel pump puts outabout 40 or 50 psi pressure and the carby is designed for like 6 or 7 psi so i would have to install a fuel pressure regulator to keep it all working...was a waste of time and money to do it so if someone has done it i don't know why they would... no real gains to be had. i'd say check the fuel line from the carby and see if it goes into a round thing with tow other hoses coming off it. that should be the mechanical fuel pump. and yeh the fuel pumps i've heard make a humming or buzzing sound
gt20v
Re: sprinter fuel? Thu, 17 October 2002 14:32 Go to previous messageGo to next message
if you've heard your friend's fuel pump making the same tapping noise, and if after removing the fuse, your car dies within minutes of starting up, one can only assume it's the fuel pump, or should I say, it HAS to be the fuel pump, coz it can't be anything else right?
But I assume it'd be fairly dangerous to have an electric fuel pump connected this way without an ECU of some sort, as the fuel pump would still be on after an accident etc. even when the engine isn't running!
Hunty
Re: sprinter fuel? Thu, 17 October 2002 14:52 Go to previous messageGo to next message
Yeh that reminds me that was the other problem, i owuld have had to have a kill switch for the pump...though if i were knocked out it would still be useless.....one way to test for sure i guess is to take the fuel line off the carby stick it in a jar or something similar and turn the ignition to on if petty comes out then there a electric pump pumping it Smile
Dabbid
Yowie Bay, Sydney
Re: sprinter fuel? Fri, 18 October 2002 07:52 Go to previous messageGo to next message
mate its an electric diaphragm pump (not a motor or efi pump)
they're designed to replace the mechanical pump
i fitted one to the outside of my tank and use it to fill my surge tank which is under the bonnet
and yes it makes a tapping noise, mazda sold one in their cars that was quiet though, they're about $110 if it annoys u that much
cri_ag
northern beaches
Re: sprinter fuel? Fri, 18 October 2002 08:40 Go to previous messageGo to next message
the pump running after the car had stalled or watever was my main concern! ill have a look for the mechanical pump tomorow, and i might even pull the fuel line off.
thanks guys
cri_ag
northern beaches
Re: sprinter fuel? Sun, 20 October 2002 03:35 Go to previous messageGo to next message
ok so when i upgrade to 4age i can use this pump to fill the surge tank and then run a high pressure pump from there?
EVOSTi
cambo
      no
Re: sprinter fuel? Sun, 20 October 2002 11:46 Go to previous messageGo to next message
what must be done to the timing to run the 4ac on unleaded? first night i got my sprinter i ran it on unleaded by accident of habbit, and have run it on leaded since then. i suppose the timing has to be retarded a couple of degrees?
Re: sprinter fuel? Sun, 20 October 2002 14:01 Go to previous messageGo to next message
You could probably run a 4AC on paint thinner Shocked or any other leftover kitchen substances? Twisted Evil
(hang on, is that suggesting I cook with thinners?)
gt20v
Re: sprinter fuel? Sun, 20 October 2002 15:41 Go to previous messageGo to next message
I don't see any problem using your electric fuel pump with your surge tank.. Smile
EVOSTi, I think you'll have to ask your mechanic or search the web for the answer, but I assume your engine has already been adjusted for unleaded, try running the car with unleaded and if you don't have major power problem, or pinging problem, then it should mean that it's already been adjusted.. (but leaded fuel will run with more power compared to unleaded fuel, also the lead additive is also an anti-pinging additive, sort of an octane booster to a certain point, but the extra cost associated aren't worth it I reckon)
EVOSTi
cambo
      no
Re: sprinter fuel? Mon, 21 October 2002 06:57 Go to previous messageGo to next message
yeahs tuff it ill run it on unleaded. if the motor blows ill just have to chuck the GZE in sooner... without the brake conversion i am saving up for first Rolling Eyes
Dabbid
Yowie Bay, Sydney
Re: sprinter fuel? Mon, 21 October 2002 07:03 Go to previous message
i ran my old 4a-c only ever on optimax, got an extra 80-100k out of a tank of fuel, never had any problem and i drove it in a way that it should have shit itself instantly but it just wouldnt die!! drove it damn hard for a bit over a year on unleaded
Previous Topic:LSD for Cressida
Next Topic:disc brakes for an AE86 SR-5
Current Time: Thu Nov 19 10:24:12 UTC 2026
Total time taken to generate the page: 0.0070888996124268 seconds
