Toymods » Tech & Conversions » Stereo mounting Question
bbaacchhyy
Stereo mounting Question Wed, 22 December 2004 03:22 Go to next message
To allow me to fit the guages into the MA61, I am looking at fitting them where the stereo currently sits.
This then leaves me with the issue of trying to fit the stereo somewhere.
Essentially, one of the easiest spots is the centre console (in the armrest storage tray).
Any issues with mounting it vertically (it is a CD/Radio unit only) - heat ? CD operating vertically ?
Or are there any other suggestions ?
Michael B
Dust
Re: Stereo mounting Question Wed, 22 December 2004 03:31 Go to previous messageGo to next message
I have seen em mounted vertically before, heat shouldnt be a problem, only thing i can think of would be dust getting inside the unit or other foreign objects or maybe spilt drinks Smile.
But if its inside the actual compartment then it should be ok I would think, best check with a carsound place about vertical installations, might be different for different brand units.
Dust
Squid
Re: Stereo mounting Question Wed, 22 December 2004 03:32 Go to previous messageGo to next message
You might find shock issues mounting it vertically...
Having it in the centre console would also breach the industry standard - which is basically no more than 2 seconds not looking at the road to operate a system you are familiar with. But as far as i know it is legal.
You could do a highlux style mount and put it on the roof... but running cables is a bitch...
bbaacchhyy
Re: Stereo mounting Question Wed, 22 December 2004 03:41 Go to previous messageGo to next message
Thanks for the quick reply guys.
Essentially the car isn't a daily driver and the radio/CD will only really be on after a drive back from the hill etc, so there won't be too much fiddling around, but valid point Squid.
99% of the time it is on, it will be on the radio and one station at that.
Roof mount means even more work !!! I have a hard time doing what I don't now.
Anyone else ?
lowrlux
Melb
Re: Stereo mounting Question Wed, 22 December 2004 03:52 Go to previous messageGo to next message
What about inside the glove box? Nice and tidy and can't be seen by prick who want to steal it. Cool
bbaacchhyy
Re: Stereo mounting Question Wed, 22 December 2004 03:56 Go to previous messageGo to next message
lowrlux wrote on Wed, 22 December 2004 14:52
The gloebox in the MA61 is pretty small and it is already full of 7M-GTE ECU Laughing
RA65 Sleeka
Re: Stereo mounting Question Wed, 22 December 2004 04:06 Go to previous messageGo to next message
how about under the glovebox there is space with a little cutting..
bbaacchhyy
Re: Stereo mounting Question Wed, 22 December 2004 04:22 Go to previous messageGo to next message
RA65 Sleeka wrote on Wed, 22 December 2004 15:06
hmmm, I'll have a look tonight...
Intensevil
Re: Stereo mounting Question Wed, 22 December 2004 04:36 Go to previous messageGo to next message
Why not make things easy for urself and put the guages in the center glove box? unless its a boost guage or something that needs attention, but if its just temp guages shouldnt be a problem right?
bbaacchhyy
Re: Stereo mounting Question Wed, 22 December 2004 04:46 Go to previous messageGo to next message
The guage are oil pressure, boost and EGT, so I'd rather have them within easy view and do without the stereo...
Plus the guages look really schmick - they are HKS Electronic ones.
Re: Stereo mounting Question Wed, 22 December 2004 05:01 Go to previous messageGo to next message
Aren't most guages a single din height?
Can't you squeeze them in above the deck (if the deck is at the bottom)
Or, remove the ashtray, and put the guages there.
The deck will look shit anywhere else you put it.
bbaacchhyy
Re: Stereo mounting Question Wed, 22 December 2004 05:29 Go to previous messageGo to next message
I wish it was that simple.
If I stagger the guages, they just fit in the opening with about 5mm to spare.
The guages are the bigger 65mm diameter ones and the stereo does not fit in the slot (width ways - the std unit on the car was butchered to make it fit Sad ) and I think that the way the ashtrya sits, it won't go in there due to the angle and the depth that would be needed.
wilbo666
Re: Stereo mounting Question Wed, 22 December 2004 05:58 Go to previous messageGo to next message
under the seat? Razz might sound stupid, but if you get one with a remote?
Easy to cable...and if its only going to be an on off thing....
Just a left field suggestion Smile
Kyosho
Wollongong
Re: Stereo mounting Question Wed, 22 December 2004 06:03 Go to previous messageGo to next message
Get rid of the stereo...
They only add weight...
Although I do like my music... I'm sure you could get away without a stereo if it ISN'T a daily...
levos1
E.W
Re: Stereo mounting Question Wed, 22 December 2004 11:24 Go to previous messageGo to next message
Take out the centre air con vents!
block the holes back up in the dash and mount either the deck there or the guages?!!
bbaacchhyy
Re: Stereo mounting Question Wed, 22 December 2004 21:04 Go to previous messageGo to next message
Kyosho wrote on Wed, 22 December 2004 17:03
It is starting to look that that is an option.
Had a look last night and it is too big to fit under the armrest without totally rooting that part of the console.
I wont fit under the glovebox without major surgery and mounting trickery.
Putting it in the centre air con vents will involve too much work and will look a littel naff as well.
Under the seat is an idea, but I don't want to spend extra money.
I guess there are 2 options left ;
1. Get a smaller unit - does one exist that is smaller than a std stereo ? (preferable)
2. Leave it out alltogether
ANy other suggestions ?
Cheers for the input so far
[Updated on: Wed, 22 December 2004 21:05]
RA65 Sleeka
Re: Stereo mounting Question Thu, 23 December 2004 04:36 Go to previous messageGo to next message
cant you bye a stacker with a controler then run it to a amp then run spekers off that??
bbaacchhyy
Re: Stereo mounting Question Thu, 23 December 2004 04:41 Go to previous messageGo to next message
RA65 Sleeka wrote on Thu, 23 December 2004 15:36
The head unit will still be the same size which is about 180 wide by 50mm tall.
It looks like the stereo may get the flick Crying or Very Sad
Oh well, weight saving !!!!
RA65 Sleeka
Re: Stereo mounting Question Thu, 23 December 2004 04:45 Go to previous messageGo to next message
the controler im talking about was a small little thing like half the size of the face of a head unit and you dont have to mount it.
Re: Stereo mounting Question Thu, 23 December 2004 04:48 Go to previous messageGo to next message
bbaacchhyy wrote on Thu, 23 December 2004 12:41
If you don't mind buying crap, Sony decks have an option of a wired remote control (not wireless).
So put the deck in the hatch, put a stacker in the hatch, and wire the remote stalk (kinda looks like a cruise control stalk) somewhere, maybe on the steering column.
Then you just have to learn to control it.
Having the stacker gives you the option of having many hours of music without swapping a cd.
An MP3 deck will give you the same thing.
Also, AXIS Marine series have a radio wireless controller (radio comms to deck). You can mount that in the dash somewhere, even on the door skin.
Let me try and find some pics.
Re: Stereo mounting Question Thu, 23 December 2004 04:51 Go to previous messageGo to next message
The AXIS one
http://www.audioxtra.com.au/SBEHOMEPAGE/hex2907.gif
Re: Stereo mounting Question Thu, 23 December 2004 04:54 Go to previous messageGo to next message
The NEW sony one appear to be wireless, hopefully radio, not infrared.
http://www.unbeatable.co.uk/resources/images/products/large/109160a.jpg
[Updated on: Thu, 23 December 2004 04:56]
Re: Stereo mounting Question Thu, 23 December 2004 04:56 Go to previous messageGo to next message
The old sony one looked like this, and uses a cable.
http://www.gweep.net/~prefect/eng/cave/rmx4s.jpg
bbaacchhyy
Re: Stereo mounting Question Thu, 23 December 2004 21:18 Go to previous messageGo to next message
Cheers CruZida, any idea of costs ?
Michael B
Re: Stereo mounting Question Fri, 24 December 2004 01:16 Go to previous messageGo to next message
bbaacchhyy wrote on Fri, 24 December 2004 05:18
Michael B
NFI man.
http://www.strathfield.com, Autobahn or JB HiFi would be the places to get it cheap.
gr8r-x
Vic, AU
Re: Stereo mounting Question Fri, 24 December 2004 01:35 Go to previous messageGo to next message
Wired/RF remote with HU in boot is about your only option.
However, there are quite a lot of companies that make such things, not just those listed here.
Best thing to do is go to a large car audio store and ask them what they've got. I know that JVC and Pioneer USED to make wired remote HU's as well, don't know if they still do.
bbaacchhyy
Re: Stereo mounting Question Fri, 24 December 2004 01:50 Go to previous messageGo to next message
Thanks guys, I will investigate it, but if the cost is too high, it might just have to do without it....
Listen tio the whine of the turbo instead Very Happy
ed_ma61
Lost in the K hole
Re: Stereo mounting Question Fri, 24 December 2004 05:42 Go to previous messageGo to next message
you know my philosophy - if it comes out of the car, it doesnt go back in Nod
michael, you know youll only be driving this car hard - i dare you to tell me that your driving performance increases with the stereo going...
i cannot even drive my car properly anymore unless i can hear every noise the girl is making. i turn into a complete gumby when i get no audio feedback
Re: Stereo mounting Question Fri, 24 December 2004 10:57 Go to previous messageGo to next message
Why not be FulSik and mount the gauges on the pillar? Or, better yet, screw the gauges Very Happy
Eagz
Heathridge WA
Re: Stereo mounting Question Fri, 24 December 2004 12:44 Go to previous messageGo to next message
I see no problems but if u r concerned abot heat u can always take off the top cover and wire in a PC chassiss fan. They wont effect your stereo but will cool your stereo jsut as long as it is wired on the inside with sum extraction holes
but hey id neva trust my words
i ussually get things rong hehe
good luck should be fine neva the less
bbaacchhyy
Re: Stereo mounting Question Mon, 27 December 2004 10:03 Go to previous message
ed_ma61 wrote on Fri, 24 December 2004 16:42
You are right Ed, but it is the drive too and from the said "drive areas" that the stereo will be used.
That said, it looks like it is going into the for sale section soon Cool
Previous Topic:which celica box behind a 202?
Next Topic:Coolent leaking! not Toyota vehicle
Current Time: Tue Nov 24 01:08:40 UTC 2026
Total time taken to generate the page: 0.0069270133972168 seconds
