Toymods » Tech & Conversions » ke30 2dr track?
styler
ke30 2dr track? Wed, 22 December 2004 07:35 Go to next message
wat is the rear track on a 1974 ke30 2dr sedan ?
which is the same track as the sedan i think...
i want to put a lsd into it as easy as possible
so far ideas - shortened r31 skyline
- hicace van
- hilux
any input appreciated
[Updated on: Wed, 22 December 2004 07:38]
Re: ke30 2dr track? Wed, 22 December 2004 08:09 Go to previous messageGo to next message
matti kalahati's site.
Jonny2TG
Tasmania
Re: ke30 2dr track? Thu, 23 December 2004 07:42 Go to previous messageGo to next message
Both wheelbase and track will be the same as a 4dr KE30 or KE55. The exact track, will be effected by wheel width and offset, so a few slighly different figures can be found. Also note that on a KE30, you have heaps more room at the back and can go a bit wider if you want.
This is my setup: KE55. Complete rear diff assembly from a RA23 Celica. This is about 5 or 10mm wider, so the perfect side. I cut the spring mounts off and welded leaf spring mounts on. I use a LSD center from a early AE86 twincam. I just measured the rear track on my car and its roughly 1290mm. That is with 14 x 6-1/2" wheels, offset -25.
My diff, drum to drum (RA23) is 1233mm.
BradW
Bottom of the hill, Sydney
Re: ke30 2dr track? Thu, 23 December 2004 09:04 Go to previous messageGo to next message
Jonny2TG wrote on Thu, 23 December 2004 18:42
Standard Ke30 sedan rear track width is 1285mm.
Johnny2TG: Did you measure your diff width from wheel mounting face to wheel mounting face? The reason I ask is because a standard KE55 diff is 1350mm wmf to wmf.
As Johnny2TG suggested the easiest lsd diff would be to fit a celica TA/RA2x diff then get a lsd centre.
Brad
[Updated on: Thu, 23 December 2004 09:07]
Jonny2TG
Tasmania
Re: ke30 2dr track? Thu, 23 December 2004 14:44 Go to previous message
That 1233mm was the bare axle housing sorry, not drum to drum. On a RA23 Celica diff.
Previous Topic:The "Green" injectors???
Next Topic:Help! ---> Which Mixture Meter for car?
Current Time: Sun Nov 1 02:50:29 UTC 2026
Total time taken to generate the page: 0.0046761035919189 seconds
