Classifieds » Cars For Sale & Wanted » Turbo AE86 For Sale
Big Azza
Hobart, Tas
Turbo AE86 For Sale Wed, 22 December 2004 13:21 Go to next message
FOR SALE: AE86 Sprinter Turbo
http://forums.toymods.org.au/index.php?t=getfile&id=8672
Rebuilt body:
Shell stripped out , body deadener removed
Seam welded chassis from front struts through floor to rear suspension mounting points
Fresh DuPont 2-pack paint in april 02, Porsche yellow (gelb)
Colour coded bumpers and mirrors
Levin tail lights
Customised front bar to take I/c
Repainted interior trim
New black carpet
Mazda Familia GTX seats
Autotechnica tiller
Tinted Windows
Battery mounted in the boot
http://forums.toymods.org.au/index.php?t=getfile&id=8675
Minor suspension work:
TRD short front shocks
Monroe short rear shocks (Holden)
Factory springs
Wheels and Tyres:
Advan racing wheels 15x6
195x50R15 Front Firestone sz50
Rear Yokohama gpM7
http://forums.toymods.org.au/index.php?t=getfile&id=8673
Fresh Engine:
4AGZEhas done less than 2000kms
Assembled by Aaron Bremner under the watchful eye of Adrian Brooke from Brooke Engineering a.k.a. Team 23 (Gold Coast)
Worked Small port head
Port and valve work done by Adrian Brooke
Crankcase die grinded smooth
Heat proof coated piston crowns
ACL rings, bearings
Toyota Head gasket
Natural Cams
High Volume sump
Custom tuned length aluminium inlet manifold with bell mouthed runners
Custom tuned length HPC steam pipe turbo exhaust manifold
KKK k 16 internal gate Turbo (off 993tt Porsche)
3inch mandrel bent exhaust
K&N panel filter inside cold air box, air duct thru inner guard
PWR Intercooler core with custom end tanks 600x200x75. Entire core gets fresh air thru front bar, making it very efficient.
Remote mounted larger oil filter
B&M Oil cooler
Oil catch can
Microtech LTX8, Tuned by Mathew Spry, PITS, Gold Coast
4 coil set up using 1JZ-GTE coils mounted directly on top of plugs
Bosch 044 fuel pump
Malpassi fuel pressure regulator and gauge
4 AGZE injectors (365cc)
4 AGZE Flywheel (bigger and lighter than 4AGE)
5 puck brass button clutch and 2200lb pressure plate built by Nicks Performance Clutches, Brisbane
T50 gearbox and S314 diff (standard)
AE70 Levin Radiator (Steel tanks, twin core)
Twin thermos
Other Improvements:
Turbosmart bleed valve
R33 Skyline blow off valve, plumbed back
Mechanical Oil Pressure Gauge
Mechanical Boost Gauge
Turbo timer
Jay Car Electronics Central locking
Jay Car Electronics Alarm & Keyless entry
Air horns
This car is a very nice handling package, and very well behaved when pushed to drift. The set up I run lends itself more toward cornering than drifting, but with a few minor changes this can be dramatically changed. With around 220hp at the wheels running 14psi boost on the dyno, it is a respectable streetcar, and with an engine strong enough to run up to 25psi reliably, it still has a lot of potential. It comfortably handles 18-20 with standard injectors, though traction is regularly a problem, as you would expect.
The engine is incredibly responsive, even when off boost, thanks to some great port and valve work, thanks Adrian, and the torque curve is very fat and flat due to the induction and exhaust tract designs. Plumb back blow off valve and boxed panel filter are both legal and functional.
The highway economy is as good as 7l/100km, the power is very smooth and the exhaust note crisp and clean, Mathew Spry @ Performance Injection Tuning Services has done a superb job of tuning this package.
All the fabrication and turbo conversion was done at Trickyweld on the Gold Coast, where many excellent conversions and Sprinter projects occur, where I worked until recently. Many thanks to Richard for his support and help with this project.
The next step for this car, were I to keep it would be a brake upgrade, and I would fabricate a half roll cage. The discbrake rear end I have already, but are not assembled. I also have a good friend, Aaron Bremner (aza510), who supplies gearbox conversion plates for W series boxes, which would be a sensible precaution, although I haven't had any dramas so far, and this car has been turbo for over a year now. If I were going to drag I wouldn't hesitate to put in a W box.
It is a very regrettable sale, this is my favourite car, I have had 5 or so of them at various stages and I think they look and handle sweet. I am getting married very soon and then travelling around the world for a year or so and It can't be done without my girl and I selling both of our vehicles. (She has a 99 323 Astina, in case you were wondering). I hope that when we get back I can acquire another ae86. I genuinely will regret this sale, but someone will get a car with an enormous amount of work done to it at a fraction of what it cost to actually do.
Other parts that I'll throw in:
1l Surge tank and lift pump
super heavy short rear springs (sets up nicely to drift)
Sparco racing pedals
High stop light (legal requirement in some states)
Items I'll keep, negotiable:
Tighe Billet Cams, 284deg @ 10thou, with Brooke Engineering Adjustable Cam Gears.
S3 TRX Bluebird Disc Brake Rear End, modified to bolt under a sprinter, with brand new DBA rotors and rebuilt calipers. The rear end is a lot stronger than the Sprinter one with larger axles, bigger diff but still runs 3.9:1 ratio. Nissan makes an Lsd that bolts in.
How much do I want for it? $13,000
I am negotiable and there are parts on the car which I would happily keep to lower the price. I am in Tasmania at the moment, the car is registered in Qld but it is only a short boat ride away from Melbourne or Sydney, so if you are serious I'm sure the location will not be an issue. I am serious about selling this car, so please, genuine enquires only, thankyou. My email address is reflekta4jc@yahoo.com.au if you are interested and have some cash, drop me a line and I will be in touch.
Attachment: carpics10[1][1].12.04001~1.JPG
(Size: 82.52KB, Downloaded 5980 time(s))
Attachment: Carpics10[1].jpg
(Size: 93.14KB, Downloaded 5577 time(s))
Attachment: carpics10[1][1].12.04003~1.JPG
(Size: 75.84KB, Downloaded 5569 time(s))
p3rky
icon14.gif  Re: Turbo AE86 For Sale Wed, 22 December 2004 14:07 Go to previous messageGo to next message
very very nice ride man <insert drool here> gl with the sale
[Updated on: Wed, 22 December 2004 14:09]
phaser
Mulgrave, Melbourne
Re: Turbo AE86 For Sale Wed, 22 December 2004 14:23 Go to previous messageGo to next message
Ohh La Lah. Sexy! Shocked
Good Luck with the sale.
also, excuse my gayness.
wog_85
Re: Turbo AE86 For Sale Wed, 22 December 2004 14:41 Go to previous messageGo to next message
That is sweet as man if i had the $$$ i would buy it not a bad price either concidering the mint condition
horner boy
Re: Turbo AE86 For Sale Thu, 23 December 2004 00:39 Go to previous messageGo to next message
Hey have you got any interior pics?
mrf_ool
Taree (4 hrs north of syd...
Re: Turbo AE86 For Sale Thu, 23 December 2004 04:14 Go to previous messageGo to next message
big bird is driving in style.. Cool its fucking great car dude good luck with the sale
[Updated on: Thu, 23 December 2004 04:15]
joshyd
Re: Turbo AE86 For Sale Thu, 23 December 2004 07:46 Go to previous messageGo to next message
hell yeh thats awesome. one of the best 86's ive seen! love it.
wish i had the money Sad
Les
Re: Turbo AE86 For Sale Thu, 23 December 2004 13:09 Go to previous messageGo to next message
Big Azza wrote on Thu, 23 December 2004 00:21
dump her
keep it
Chobits
Northmead
Re: Turbo AE86 For Sale Thu, 23 December 2004 13:18 Go to previous messageGo to next message
if, it wasnt turbo, and if, it wasnt in Tasmania...
it would be in my garage this very moment...
nice ride though.
gl with sale
monkeymajik
Re: Turbo AE86 For Sale Thu, 23 December 2004 15:46 Go to previous messageGo to next message
Is it engineered with the battery in the boot? How did you get away with it?
Very very very nice car!
Fattony
Re: Turbo AE86 For Sale Fri, 24 December 2004 00:26 Go to previous messageGo to next message
Nice car dude, if i had the $$$ you would be waving goodbye
Big Azza
Hobart, Tas
Re: Turbo AE86 For Sale Fri, 24 December 2004 08:48 Go to previous messageGo to next message
Thanks for all the compliments ppl, I like it too.
This is the only interior pic I have, it's a bit dirty but you'll get the idea.
http://forums.toymods.org.au/index.php?t=getfile&id=8698
Attachment: Carpics10[1]12.JPG
(Size: 85.72KB, Downloaded 4481 time(s))
Lucid
Toymods Club Secretary
Re: Turbo AE86 For Sale Fri, 24 December 2004 10:41 Go to previous messageGo to next message
Nice, makes a trip to Tassie look even more appealing! Smile
pr1nce
NSW, Sydney
Re: Turbo AE86 For Sale Fri, 24 December 2004 11:06 Go to previous messageGo to next message
what's with the dash?
Big Azza
Hobart, Tas
Re: Turbo AE86 For Sale Fri, 24 December 2004 11:23 Go to previous messageGo to next message
the dash may be a bit much for some of you kids watching at home, thats right, pornstar crushed velvet covered dash, speaker pods and you guessed it... hood lining. Not to everyones styling preference I know, but hey I like it. It can be remedied no doubt, if you buy it and you don't like it.
As for battery in the boot, monkey majik, you may have to correct me but a mod plate is not required for that in QLD? if so it is no drama to arrange one.
bass_boy
Re: Turbo AE86 For Sale Wed, 29 December 2004 03:02 Go to previous messageGo to next message
ill be the first to put my hand up to "mind" the car for a year while ur away!!!...
Razz Razz Razz
cmwb
Devonport, Tasmainia!
icon14.gif  Re: Turbo AE86 For Sale Sun, 02 January 2005 13:54 Go to previous messageGo to next message
'BUMP'
hay aron its corey baxter!
and to every one else this is a great looking car with engine to realy make it mumbo!!!!
look guys i know this car is in tas but it not hard to it back over on to the mainland! i sold my ae86 to someone in sydney! and i myself have brought 2 mor cars since on the mainland and it is not that hard!
good luck with it aron! if i hadent started the project that im on to now i would really of considered this car for my new ride!
SC_Trueno
Re: Turbo AE86 For Sale Mon, 03 January 2005 08:48 Go to previous messageGo to next message
Shocked Surprised
[Updated on: Wed, 12 January 2005 12:29]
mrf_ool
Re: Turbo AE86 For Sale Wed, 12 January 2005 08:46 Go to previous messageGo to next message
so a standard sprinter diff is this ..
Big Azza
Hobart, Tas
Re: Turbo AE86 For Sale Fri, 14 January 2005 01:43 Go to previous messageGo to next message
hey everybody, just to update the thread...
-the engine has now done over 3000km since being run in on the dyno. I'm giving it an oil change today, the second it's had since then.
-I put 6 months rego on it last night so it is reg until 22 july.
-Unless it sells in the next week, I am racing at baskeville raceway at a private practise day on the 22nd put together by hobart-toyota group. That means I have stripped out the rear seats and plastics, reinstalled the surge tank, and the car will have new tyres the week after it comes back.
I'm also thinking about going down to launceston for some car show on sunday, for any of you tas guys who are in the area and want to check it out.
Cheers, Azza
86DRFT
Rockhampton QLD
Re: Turbo AE86 For Sale Fri, 14 January 2005 03:45 Go to previous messageGo to next message
As soon as i win some kind of lottery i'll give you a call, going out to buy a scratchy now, wish me luck. Laughing Rolling Eyes
cmwb
Re: Turbo AE86 For Sale Sun, 16 January 2005 12:29 Go to previous messageGo to next message
" B U M P "
o here is a pic from the car show we took it up to today!
Attachment: azza.jpg
(Size: 64.60KB, Downloaded 320 time(s))
cmwb
Re: Turbo AE86 For Sale Tue, 18 January 2005 01:16 Go to previous messageGo to next message
i finally got to go for a ride in this beast yesterday and all i can say is hell yer!!!!!! and that i have not been able wipe the smile of my face since!!!!!!
SC_Trueno
Re: Turbo AE86 For Sale Wed, 19 January 2005 06:15 Go to previous messageGo to next message
is that car still for sale or is it sold ?
Big Azza
Hobart, Tas
Re: Turbo AE86 For Sale Wed, 19 January 2005 08:59 Go to previous messageGo to next message
This car is definately still for sale. It now has fresh oil, the surge tank back in, a new pair of bridgestone G3's and 40l of high octane fuel, until saturday at least. it's also lost the back half of the interior in the interest of weight loss, looking very ready for a half cage or some sub boxes, whatever moves you. there has been alot of interest in this car but still no one has made a serious offer. I am going overseas in 4 weeks and it would be really good if I can sell it before I go. e-mail me reflekta4jc@yahoo.com.au
Big Azza
Hobart, Tas
Re: Turbo AE86 For Sale Sat, 05 February 2005 11:49 Go to previous messageGo to next message
Baskerville was awesome, my car was quite comfortably mixing it with sr20det celicas, fj20det dattos and even kept up with an sti impreza targa tas car on the straight bits, I was very surprised myself! I found a few things that need some sorting for track work but this is one tough streer car!
I leave to travel for a couple of months on thursday and as no one has made me a serious offer, it looks like i need to get a cover and park it. Its still for sale but i'm not too sad that it's still mine. at least i get to drive it again when i get back! but there is still time...
Big Azza
Hobart, Tas
Re: Turbo AE86 For Sale Sat, 05 February 2005 21:15 Go to previous messageGo to next message
I just worked this out last night and honestly surprised myself, check it out:
Small port 4agze long motor $1000
cost of head work $1000
second hand KKK turbo $500
turbo manifold $500
HPC coating on manifold, exhaust housing, dump pipe and pistons $500
inlet manifold $500
Intercooler and plumbing $1000
oil cooler, remote filter mount, oil lines (incl turbo feed) $400
Fuel system (2 pumps, surge tank, malpassi, lines) $650
Microtech LTX8 installed and tuned $1500
Engine prep and rebuild $1000
3inch Mandrel bent exhaust, turbo back $1000
I have been in the business of doing these mods to cars everyday for the last couple of years, so I know that these figures are fair, if not a little conservative. there are places out there that are charging a hell of a lot more than what i've allowed for.
Total: $9550 and thats just what makes it go! thats no car even, nor paint, seats, wheels... and on the list goes.
So as you can see, this is a lot of car for the money. I wish I had looked around at what people had already started before launching into my own project... something to think about anyway.
Cheers, Aaron
Big Azza
Hobart, Tas
Re: Turbo AE86 For Sale Mon, 07 February 2005 22:58 Go to previous messageGo to next message
I'm outta here in a day and a half, looks like i'll be parking my ride for a couple of months. I'll be back in April for a couple of weeks if anyone who doesn't have the cash now finds it in the meantime. I geuss this thread will dissappear into cyber space soon, but i'll put another one back up if I reckon it's worth it and I am still keen to sell.
Big Azza
Hobart, Tas
Re: Turbo AE86 For Sale Tue, 08 February 2005 10:27 Go to previous messageGo to next message
Change of plans: A friend of mine, Richard Gilmour, is selling the car on my behalf in Hobart. His e-mail is Dikbob@dodo.com if anyone is interested, please don't hesitate to send him a message. Thanks
Big Azza
Hobart, Tas
Re: Turbo AE86 For Sale Sat, 16 April 2005 06:34 Go to previous messageGo to next message
hey dudes, I'm back in oz, man i missed driving my car. I'm hanging out down in hobart for a few months now, still selling the car if anyone is keen but i'm not too desperate. looking around at what people are paying for sprinters, even natural ones, in the rest of the country, I don't think what i'm asking is too much.
It's so cold down here, my turbo is going to love having a proper winter, something it has not experienced living in queensland.
Well i'm off to take down some V8's...
EldarO
Perth, WA
Re: Turbo AE86 For Sale Sat, 16 April 2005 06:44 Go to previous messageGo to next message
why are all 4AGTE sprinters yellow? Smile
Very sexy car dude, looks the goods, gl with sale!
Eldar.O.
.wolfwood
Gold Coast
February 2005
Re: Turbo AE86 For Sale Sun, 17 April 2005 04:08 Go to previous messageGo to next message
what kind of raditor and thermo fan set up do you have, i have same motor set up with terbo and everything but it seems to get VERY hot, around 200'C when in lower gears in car parks, got any advice?
joshyd
Re: Turbo AE86 For Sale Sun, 17 April 2005 05:25 Go to previous messageGo to next message
yeh, move to hobart Laughing
Big Azza
Hobart, Tas
Re: Turbo AE86 For Sale Mon, 18 April 2005 09:11 Go to previous message
hey, i've got a twin core AE70 radiator with 2 x 10inch thermos on it for cooling. I also have a small oil cooler in front. I have had no overheating problems and the car has spent most of it's life in Queensland. I have worked on Turbo AE86's with standard radiators and no oil coolers in Queensland without any overheating problems, so maybe you should get your radiator core checked out, in fact I would make that a priority.
As for my car being Yellow... I had not seen any yellow AE86's at the time I painted mine. not that it is hard to change the colour, in like a weekend!
Previous Topic:SOLD: Celica GT4 Group A
Next Topic:WTB: CT110 postie bike
Current Time: Wed Nov 25 15:10:55 UTC 2026
Total time taken to generate the page: 0.035706996917725 seconds
