Toymods » Tech & Conversions » which celica box behind a 202?
CoronaC
NSW - Blue Mountains
which celica box behind a 202? Fri, 24 December 2004 21:31 Go to next message
im just tryna find this out for a mate
which celica gearbox is used behind a 202 in a torana?
mates one is fucked and he doesnt know what it is, and he is like me right now no where we can jack it up and look for at least 2weeks.
Chris
TheStitt
Membership Secretary
Re: which celica box behind a 202? Fri, 24 December 2004 23:11 Go to previous messageGo to next message
Probably W50. Thats what most ppl tend to use. Its putting up with the abuse behind my 7M
Re: which celica box behind a 202? Fri, 24 December 2004 23:43 Go to previous messageGo to next message
I think you'll find it's a T50...
ChuckLandwehr
Re: which celica box behind a 202? Sat, 25 December 2004 04:07 Go to previous messageGo to next message
It will be a W50 with a Dellows bellhousing.
regards Chuck.
YelloRolla
On your mum!
Re: which celica box behind a 202? Sat, 25 December 2004 04:28 Go to previous messageGo to next message
W50 = correctomundo. You could prolly get a covnersion for the W55 - 57 - 58 but why bother? It is afterall a 202.
fade-e
Re: which celica box behind a 202? Sat, 25 December 2004 04:32 Go to previous messageGo to next message
it will be a celica steel case which as mentioned is the W50
CoronaC
Re: which celica box behind a 202? Sat, 25 December 2004 05:38 Go to previous messageGo to next message
w50 ey?
thanks for that everyone
Chris
styler
Re: which celica box behind a 202? Sat, 25 December 2004 15:28 Go to previous messageGo to next message
couldnt it also be a t50?
CoronaC
Re: which celica box behind a 202? Sat, 25 December 2004 15:54 Go to previous messageGo to next message
styler wrote on Sun, 26 December 2004 02:28
i have no idea, thats why im asking other people Razz
Chris
alex_ta22
Newcastle, Hunter Valley
Re: which celica box behind a 202? Sat, 25 December 2004 22:35 Go to previous messageGo to next message
I Doubt it, there not a very strong box
rotorace
Re: which celica box behind a 202? Mon, 27 December 2004 01:26 Go to previous messageGo to next message
while sort of on that topic, does anyone know if you can bolt up a corona 4 speed from a starfire, to a holden 6 ???
Re: which celica box behind a 202? Mon, 27 December 2004 02:26 Go to previous messageGo to next message
alex_ta22 wrote on Sun, 26 December 2004 06:35
They still use them.
Celica Steel box = W50
Celica Alloy box = T50
CLG
Perth, Western Australia
Re: which celica box behind a 202? Mon, 27 December 2004 03:06 Go to previous messageGo to next message
I've seen a few T50's used behind 202's they all suffer from a broken input shaft. Go with the tried and trusted conversion of a W50 from a 1976-81 Celica.
fade-e
Re: which celica box behind a 202? Mon, 27 December 2004 06:30 Go to previous messageGo to next message
the only reason why people use the T50 behind it is cause they are so cheap to buy... basically if it breaks, take it out and replace it with another that costs like $100 if that at times... also you can get a few T50s that are stuffed in some form and make a box, ie, have 10 stuffed T50s and you can end up with 3/4 good ones hence they go for the cheaper weaker box... also it is lighter and you can get a few runs out of them before blowing
the W50 is a tad harder to come by and more expensive, it is the better option definately as is stronger... though it is heavier, and not likely your gonna have a few lying round...
YelloRolla
On your mum!
Re: which celica box behind a 202? Mon, 27 December 2004 08:45 Go to previous messageGo to next message
rotorace wrote on Mon, 27 December 2004 12:26
can't see why not!
BabyZ
Armidale
Re: which celica box behind a 202? Mon, 27 December 2004 11:42 Go to previous message
My worked 202 has an alloy case T50, which hasn't busted yet. It has a CRS bellhousing, but Dellow did them too. As fade-e noted, they are cheap and relatively easy to find, and usually last ok if you upgrade the layshaft bearing.
Actually, mine has been showing a reluctance to remain in 5th lately ... might be time to swap it out. Or look for a W50 Rolling Eyes
Previous Topic:few questions
Next Topic:Stereo mounting Question
Current Time: Thu Oct 29 09:05:26 UTC 2026
Total time taken to generate the page: 0.0064609050750732 seconds
