Toymods » Tech & Conversions » need help with fillingout rear guards on ae86
joyride
fairfield NSW
need help with fillingout rear guards on ae86 Sat, 25 December 2004 00:08 Go to next message
http://img.photobucket.com/albums/v137/joyride/tofu86/IMG_1132.jpg http://img.photobucket.com/albums/v137/joyride/tofu86/IMG_1133.jpg
as you can see, the LHS wheel fills out he guard but the RHS doesnt go as far. it is due to the custom axle (i believe) being shorter on one side than the other. would a simple wheel spacer remedy this situation or can something else be done?
here is the diff/rear axle in question:
http://img.photobucket.com/albums/v137/joyride/tofu86/IMG_0926.jpg
this thing is causing me grief. i dont know if it is very tight LSD or if it is locked but it squeals and grinds like a mother****er around corners. although that is another story...
[Updated on: Sat, 25 December 2004 00:09]
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: need help with fillingout rear guards on ae86 Sat, 25 December 2004 00:26 Go to previous messageGo to next message
adjustable panhard rod is your friend.
edit: is that an alfa diff? A locked or tight diff will shudder while cornering and the tyres will chirp depending on the surface and rubber. another noises may m ean its fucked.
[Updated on: Sat, 25 December 2004 00:27]
mr2drift
Re: need help with fillingout rear guards on ae86 Sat, 25 December 2004 00:30 Go to previous messageGo to next message
simons got it, adjustable panhard will fix sitting to one side, but the noise? haha thats another problem
joyride
fairfield NSW
Re: need help with fillingout rear guards on ae86 Sat, 25 December 2004 00:56 Go to previous messageGo to next message
adjustable panhard rod, thanks, will do.
as for the diff, yes it is an alfa diff! i think 105/GTV??? no idea, i went onto the alfa forums (www.aus-cartalk.com) and they only helped so much Sad
the diff mainly makes noise (yes it does shudder and squeal) around corners but SOMETIMES makes noise along straight roads.
i'l have to get the noise on video while sitting inside the car....
under full lock and standing outside the car, i can see that the tyres are really trying to grip down on the road surface and break traction.... im still undecided whether it is a locked diff or LSD as my mechanic drained the oil from it and found small bits of metal Confused
Re: need help with fillingout rear guards on ae86 Sat, 25 December 2004 01:59 Go to previous messageGo to next message
Are my eyes playing games, or has some clown attempted to shove a whole Alfa transaxle in there? Therefore:
1. Whole transaxle is moving with suspension
2. Unsprung weight...
and a few other issues Very Happy
joyride
fairfield NSW
Re: need help with fillingout rear guards on ae86 Wed, 29 December 2004 01:24 Go to previous messageGo to next message
yeah i bought this diff off a toymod member and its giving me troubles... Sad
ae86slaver
Re: need help with fillingout rear guards on ae86 Wed, 29 December 2004 04:54 Go to previous messageGo to next message
joyride: that ae86 needs to be slammed!!!!!!!
i can't imagine how much roll your getting!
joyride
fairfield NSW
Re: need help with fillingout rear guards on ae86 Wed, 29 December 2004 06:02 Go to previous messageGo to next message
yeah i havent gotten around to putting in my suspension yet.
bodyroll is worse than being in a boat.
improvedae86
Re: need help with fillingout rear guards on ae86 Wed, 29 December 2004 06:18 Go to previous messageGo to next message
Mr shin , the 105 didn't use the transaxle they used a live axle which was very carefully located {the 116 gtv series used the transaxle} . The torque rod originally is located in at the top center of the diff so the sxles are not loaded with torque , and so to mimise the twisting force on the axle tube . Tube bending and breakage was common for those cars if raced hard , the centers are very strong as well as the axles are about f series size .
That panhard is on a crazy angle , possible due the spring perches not being at the correct height for the standard ae86's short springs . Can those be altered ? dropped ? because that looks way higher than standard . If the springs being used are standard height . And if you lower it i would be worried about there being no suspension travel at all .
joyride
fairfield NSW
Re: need help with fillingout rear guards on ae86 Wed, 29 December 2004 06:22 Go to previous messageGo to next message
its still riding on stock springs, the suspension hasnt been changed yet (im a busy person) but i think changing it wont help with the noise coming from the diff. its so loud that i'm sometimes afraid of driving it in fear that will will go pop very soon. even my old man doesnt want to drive it.
i've barely racked up 1200kms on the car since the rebuild last month.
edit:
here is a side shot (best i could find) of the car with stock suspension and diff fitted.
http://img.photobucket.com/albums/v137/joyride/tofu86/IMG_0942.jpg
i can fit my whole fist between the wheel arch and rear tyre. i dont think thats normal. Confused
[Updated on: Wed, 29 December 2004 06:26]
ShiRi
Re: need help with fillingout rear guards on ae86 Wed, 29 December 2004 06:52 Go to previous messageGo to next message
i could do it befor ei fitted my king lows and i still can on my lows... im using 15" rims and a t-18 diff..
i think your fine man
Re: need help with fillingout rear guards on ae86 Wed, 29 December 2004 11:40 Go to previous messageGo to next message
I do my best to avoid learning too much about Alfas wherever the hell I can Very Happy
improvedae86
Re: need help with fillingout rear guards on ae86 Fri, 31 December 2004 22:46 Go to previous messageGo to next message
mrshin wrote on Wed, 29 December 2004 22:40
Ahh there's not that much to learn , Weakly designed unreliable rusty piles
joyride
fairfield NSW
Re: need help with fillingout rear guards on ae86 Mon, 03 January 2005 23:54 Go to previous message
ok, so i took the car for a drive the other day and the damn diff is making WAS making a constant clicking noise, like how u put a basketball card through the spokes of a bike. yes that annoying noise. this was while driving on a straight road.
anyone know of a good diff/brake workshop in syd?
[Updated on: Mon, 03 January 2005 23:54]
Previous Topic:Swaybar stiffness
Next Topic:Can sump gasket goo be used on a gearbox?
Current Time: Fri Oct 23 02:06:46 UTC 2026
Total time taken to generate the page: 0.0058848857879639 seconds
