Toymods » Tech & Conversions » microtech problem no sparks...please help!!!!
e performance
venezuela
microtech problem no sparks...please help!!!! Sun, 26 December 2004 17:29 Go to next message
Hi friends, i installed a lt8 microtech system in a mitsubishi v6 3.0 lts engine, the wiring is good, i see the CAS signal with use a oscilloscope, but i dont have sparks , if i put the handset in the test mode..... the sparks and injectors pulses are good..., but when i cranck the engine ..., no sparks and no injector pulses, i am installed about 4 microtechs on a 4g63, vw 2.0 lts, daewoo 2.0 and mr2 3sgte engines without the problems, i need help as soon as possible... please, sorry for my poor english..
__________________
TE72_Turbo
Re: microtech problem no sparks...please help!!!! Sun, 26 December 2004 22:00 Go to previous messageGo to next message
I'm sure you've already checked, but does the Microtech have power when cranking, or is it possible that the ignition 12V switching wire to the ECU loses power when the ignition is in the "start" position, shutting off the microtech?
If it does have power when cranking, can you see an RPM reading on the handset?
e performance
venezuela
Re: microtech problem no sparks...please help!!!! Mon, 27 December 2004 03:41 Go to previous messageGo to next message
hi, thanks for replay, the ambar led dont blink when i crank the engine..., stay brigth on...,and the red led stay off all the time.., for this reason.., i think..., that the microtech dont see the cas signal, but i dont sure because with the osciloscope is perfect.., the power (12 volts) is perfect on a microtech and the coil (direct30+ and switchet 15+), all of grounds are good, but tomorrow i will see the rpm in the handset.., thank you again
Kyosho
Wollongong
Re: microtech problem no sparks...please help!!!! Mon, 27 December 2004 10:48 Go to previous messageGo to next message
How do you know the Injectors are getting no pulse?
Have you checked they are pulsing by putting the osciloscope on the injector it self?
How do you know there is no spark? Have you run a timing light on it?
If you have no spark, check the plugs... We had a set foul today on an ECU install.
Check they are not fouled, check you have injector pulses at the injector via the osciloscope...
Re: microtech problem no sparks...please help!!!! Mon, 27 December 2004 12:47 Go to previous messageGo to next message
The orange LED flashes I think when the injectors are pulsing.
Red is an error, you usually wont get that until the car is started.
Are the ignitors on the unit inbuilt? or external?
If they are external, is the ecu setup correctly for them?
Are they grounded correctly?
e performance
venezuela
Re: microtech problem no sparks...please help!!!! Tue, 28 December 2004 03:49 Go to previous messageGo to next message
Hi friends and thanks again for your help.., yes i put the osciloscope in the injectors wiring..., no pulses...,all grounds are good, the power stay at microtech and the coil..., (12volts)when i cranck the engine...., the car has a external igniter, ignition coil and tdc sensor inside (built in) the distributor, i check the sparks crancking the engine with a spark plug wire conected to the secundary terminal of the coil with 1 spark plug earthed without the distribuitor cap, if i put the handset in "TEST MODE" with this method..., have a great sparks and injectors pulses good.., the green led and the ambar led stays brigth on without blinking and the red led never..., i am very confused with this problem.. today im faxed the wiring diagram of the car to the microtech dealer...., thanks again...
sideshow
Re: microtech problem no sparks...please help!!!! Tue, 28 December 2004 11:46 Go to previous message
did u buy the microtech new or 2nd hand
if new did u buy it to suit the v6 engine
if 2nd hand maybe its off a different engine and the setup for it is wrong
its very hard to go wrong with microtechs if u buy themn new and to suit the engine u r fittin it to
basically check the signal in
then signal out from microtech to the ignitor
then signal out from the ignitor to the coils
if u get no spark and no injectors at same time then its either crank signal in
or microtech is set up wrong internally or programmed wrong
usually if u get either one or the other is a stupid problem
but when u get no injetors or spark then its the crank sensor signal in or the mirotech is setup wrong
Previous Topic:Can I make a boost controller, bleed valve style
Next Topic:1jz problem - please help
Current Time: Fri Nov 20 10:28:54 UTC 2026
Total time taken to generate the page: 0.0070099830627441 seconds
