Toymods » Tech & Conversions » Coolent leaking! not Toyota vehicle
T_is4turbo
Liverpool/sydney
Coolent leaking! not Toyota vehicle Mon, 27 December 2004 08:15 Go to next message
g'day guys
My brother's 94 4WD Suzuki Vitara (yeah i know its a shitbox, but he likes it), anyways it has been surviced no longer then six months ago, but now, in the hot summer weather, coolent is starting to leak, all 5 gears is a bit hard to go in.
i was wondering what u guys might think the caused of all these problems, and how it could be fixed.
Dust
Re: Coolent leaking! not Toyota vehicle Mon, 27 December 2004 08:22 Go to previous messageGo to next message
for the coolant leaks just look under the bonnet, check hoses where they have the hose clamps on em, probably the most likely spot coolant is leaking from.
As for the gears maybe his clutch needs replacing or g/box is low on oil, or if he takes it off road perhaps its got water in it?
T_is4turbo
Liverpool/sydney
Re: Coolent leaking! not Toyota vehicle Mon, 27 December 2004 08:45 Go to previous messageGo to next message
thanks Dust
the coolent seems to be coming from the coolent excess bottle next to the radiator. when the car is stop after a drive in the summer, it som how builts up too much pressure and pushes some of the coolent to come out.
As for the gearbox, the clutch seem/feels fine, but i also think i might be low on gearbox oil!
river
Land of Oz
Re: Coolent leaking! not Toyota vehicle Mon, 27 December 2004 09:49 Go to previous message
When the engine cools down it should suck the fluid back into the radiator from the overflow bottle. If this doesn't happen then he's got a leak in his system somewhere.
The overflow bottle normally has a level mark on it and it should only be filled to that level when the engine is cold, otherwise if it's too full then it will overflow the overflow bottle.
Gearbox.... check the oil level and check the oil. If it's shitty and stinks then drain and refill the gearbox with clean oil.
seeyuzz
river
Previous Topic:Stereo mounting Question
Next Topic:6M on 5M EFI
Current Time: Wed Sep 16 10:35:20 UTC 2026
Total time taken to generate the page: 0.04264497756958 seconds
