Toymods » Tech & Conversions » Gearbox removal on AE93 SX - a couple of questions
shovelnose
icon6.gif  Gearbox removal on AE93 SX - a couple of questions Mon, 27 December 2004 08:42 Go to next message
A friend is changing the clutch on his car and he has 2 questions.
1) How do you access the starter motor electrical connections under the exhaust manifold so they can be disconnected? The room around there is extremely tight.
2) Is it necessary for the drivers' side driveshaft to be removed as well as the passenger side?
Thanks in advance Smile
Lucid
Toymods Club Secretary
Re: Gearbox removal on AE93 SX - a couple of questions Mon, 27 December 2004 09:08 Go to previous messageGo to next message
shovelnose wrote on Mon, 27 December 2004 19:42
1. From memory I had to unbolt the starter motor and basically catch it when it dropped before I could access the wires to disconnect it. Alternatively, you can remove the exhaust manifold.
2. If the gearbox is coming out of the car the I would assume so. There may be a way around this but I can't picture it atm..
warrior
Sydney / NSW
Re: Gearbox removal on AE93 SX - a couple of questions Mon, 27 December 2004 09:50 Go to previous messageGo to next message
1. the starter has to be unbolted anyway to get the gearbox out. so unbolt the starter then undo the wires.
2. both CV joints have to be removed from the gearbox before the box can come out.
good luck
Karl
shovelnose
Re: Gearbox removal on AE93 SX - a couple of questions Mon, 27 December 2004 10:12 Go to previous messageGo to next message
Thanks a lot guys Smile
One more question...
As everything else was shut today, my mate picked up a PBR clutch for the SX from Repco (they only stock standard-not heavy duty). The price was very reasonable at $175 but he is wondering whether this is false econony.
He has used standard Daikin clutches in the past, but they haven't lasted (30,000 km max). And he has complained that he could really smell the clutch burning even on moderate hill starts.
Should he get the car checked out, or should he try a heavier duty clutch? If so, what pressure plate/disc combination would give a good durablity/driveablity compromise?
Your comments would be really appreciated.
DEA-L3R
bankstown syd
Re: Gearbox removal on AE93 SX - a couple of questions Wed, 29 December 2004 07:30 Go to previous messageGo to next message
i payed $350 for my heavy dutie clutch $175 is ok price for a standard clutch i reckon always go heavy dutie cause it last longer but depends how much u thrash it but it last longer than a standard
Lucid
Re: Gearbox removal on AE93 SX - a couple of questions Wed, 29 December 2004 08:01 Go to previous message
shovelnose wrote on Mon, 27 December 2004 21:12
How hard does your mate drive his car??! If he's smelling the clutch burning on even moderate hill starts, there may be another problem (rather than just the clutch itself). Did he get the flywheel machined when the clutch was changed in the past?
If he's doing mostly normal driving, and it's a standard 4AGE powering the thing, then I'd probably be inclined to go with a standard clutch. I've got a Daikin HD clutch in my car, and it's not really lasted all that well IMO.
Previous Topic:changing 4agze cams....
Next Topic:STICKERS FOR SX
Current Time: Fri Nov 20 15:51:21 UTC 2026
Total time taken to generate the page: 0.0051479339599609 seconds
