Toymods » Tech & Conversions » AE 112 / 2001 Corolla Stereo Install - Help!!!
prands
Tamworth NSW
icon4.gif  AE 112 / 2001 Corolla Stereo Install - Help!!! Mon, 27 December 2004 13:39 Go to next message
I have a 2001 Corolla AE112. It has the stereo in the pod in the centre of the dash top.
I want to install a standard single DIN CD MP3 player in place of the factory CD.
How can I remove the old sound system?
BTW, I suspect the hole is double DIN (corrections welcome please), are there DIN blanking panels available? If so, where?
Paul
malazn
Re: AE 112 / 2001 Corolla Stereo Install - Help!!! Tue, 28 December 2004 01:13 Go to previous messageGo to next message
to remove the old cd player
you will need to remove the centre aircon vent.
use two screw drivers and at the TOP of the air con vent there will be two tabs which you have to pull down with the screw driver.
and then when the aircon vent is out remove the wiring harness for the emergency light.
now you will need a 12mm? socket and you look through the vent that you removed and at the bottom somewhere there will be two bolts.. once on each side. remove these two bolts and becareful not to drop them!! then slowly pull the whole pod towards the back of the car..
unplug both wiring looms and thats your factory cd out of the way.
now the factory cd is only single din but has a front face is a bit larger. there is a cover on top of the cd to cover the empty space up.
you can buy single din covers or trays its up to you what you want to do... they are available from toyota
cheers.
prands
Tamworth NSW
Re: AE 112 / 2001 Corolla Stereo Install - Help!!! Wed, 29 December 2004 19:59 Go to previous messageGo to next message
Thanks very much for your help, I will give this a try soon.
Paul
malazn
Re: AE 112 / 2001 Corolla Stereo Install - Help!!! Wed, 29 December 2004 23:24 Go to previous message
no worries mate...
if your still stuck after trying it pm me and i'll try and help you out..
Previous Topic:GA70 Supra Intercooler Dimensions..
Next Topic:suspension question
Current Time: Fri Oct 16 13:06:07 UTC 2026
Total time taken to generate the page: 0.005742073059082 seconds
