Toymods » Tech & Conversions » 4piston brakes for a st162
3S-GE_Man
Gold Coast
4piston brakes for a st162 Mon, 27 December 2004 14:43 Go to next message
yeah a part from the st205 ones that might bolts up... what 4 psiton brakes and rotor combo would people sugest for a st162..i was thinking wrx ones cause the rotor is 5x100 stud like the st162 celica
But i was thinkign hilux 4 piston calipers would be easier to get my hands on!
Nezza Cool
Eagz
Heathridge WA
Re: 4piston brakes for a st162 Mon, 27 December 2004 14:47 Go to previous messageGo to next message
i suppose would be good. are you looking at the standard Wrx brakes or the additional Brembo version ? I think they speak for themselves
hehe but yer any would be nice, a mates dad has a WRX done up a lil c-west kits has nice 6 piston brake calipers
3S-GE_Man
Gold Coast
Re: 4piston brakes for a st162 Wed, 29 December 2004 12:27 Go to previous messageGo to next message
not the sti brembo ones...but the normal 'subaru' 4 pistons ones...would grind the subaru lable of them when i do, lol!
Nezza Cool
wagonist
Toymods Club Treasurer
Re: 4piston brakes for a st162 Thu, 30 December 2004 22:33 Go to previous messageGo to next message
Follow the link in my sig to see what's needed for an ST205 upgrade.
Good luck finding them though.
JustenGT4 has STi discs & Brembo calipers on his uber V8TT ST185, so I'm not sure how they work (but he has fully modded the steering knuckles for that car)
RobST162
Re: 4piston brakes for a st162 Thu, 30 December 2004 22:57 Go to previous messageGo to next message
But really why would you bother?
Unless you have big track intentions I wouldn't bother personally.
I believe it's a quite a hassle and expensive.
Just my thoughts anyway! Smile
wagonist
Re: 4piston brakes for a st162 Thu, 30 December 2004 23:02 Go to previous messageGo to next message
I believe you need to come for a ride sometime Rob!
Hell, mine are fitted to a turbo diesel!!!
A lot cheaper upgrade is the Jap spec twin piston ST165/ST185.
Bolts on, has a bigger pad contact area, & a lot easier to find.
If I was palnning on doing a 3S-GTE or 1MZ-FE swap later, I'd be thinking about this.
RobST162
Re: 4piston brakes for a st162 Thu, 30 December 2004 23:04 Go to previous messageGo to next message
I believe I do! Wink
yeah but for a Gen1 3SGE my thoughts would be go the 165/185 brakes.
A 20 minute bolt-on job that's so easy that it's... uh.. really easy! Neutral
edit: however for searches and posterity, I am pretty clueless as to what 4-piston brakes go on a 162 well. I know RX-7 calipers are a popular upgrade also. You need a custom mounting plate made up for them though, and of course new rotors.
[Updated on: Thu, 30 December 2004 23:06]
bbaacchhyy
Re: 4piston brakes for a st162 Fri, 31 December 2004 01:51 Go to previous messageGo to next message
wagonist wrote on Fri, 31 December 2004 09:33
You are correct on the discs (WRX STi jobbies - same as I used), but the Calipers are Z32 300ZX (or maybe R33 Skyline ones)
RWDboy
Re: 4piston brakes for a st162 Fri, 31 December 2004 02:25 Go to previous message
Having more pistons per caliper doesn't really do much for overall stopping power. In terms of sustained use of brakes then you might want to get a larger caliper w/- more pistons, but seriously when was the last time you did 20 straight laps of a circuit going 10/10ths?
If you are worried about your car hauling up, then get rid of weight, and get a bigger front footprint while braking (suspension anyone?)
Aside from that, the best advice I can give you is the advice Possum Bourne dished out - that is make sure that your brakes are mounted BLOODY well regardless of what you get, if you decide to get RX-7/R33/300ZX/WRX calipers and use a custom plate to mount them then make sure you get someone with a good rep to do it.
Oh and Hilux calipers are pretty hefty beasts, you'd be adding alot of unsprung weight to the fronts!!!
Previous Topic:wiring a st205 engine into a 185..
Next Topic:hilux diff ----> celica question
Current Time: Fri Nov 20 14:56:01 UTC 2026
Total time taken to generate the page: 0.0074789524078369 seconds
