Classifieds » Parts Wanted » parts needed for ta22 auto to manual swap
parsi
Epping, Sydney.
parts needed for ta22 auto to manual swap Tue, 28 December 2004 05:58 Go to next message
yeah basically trying to swap the old ta22 from auto to manual. currently the parts i have are:
t50 gearbox, RPM heavy duty clutch, clutch and brake pedals, clutch master cylinder, gearbox cross member.
from what i gather the only parts i need now are (please feel free to correct me here as i am not 100% sure what is needed for the swap): the flywheel, tail shaft, centre console (preferably in the standard poo brown colour so it will match with the rest of thecar but then again that is not essential).
any help in sourcing these parts would be much appreciated
/hugh
fade-e
Re: parts needed for ta22 auto to manual swap Tue, 28 December 2004 07:26 Go to previous messageGo to next message
i have a flywheel and tailshaft you can have for $80 pick up
the flywheel is for a 2T/3T right?
parsi
Epping, Sydney.
Re: parts needed for ta22 auto to manual swap Tue, 28 December 2004 08:16 Go to previous messageGo to next message
sweet. damn that was a quick response.
yeah it is for the 2t engine.sorry forgot to mention that.
i will pm you for details.
fade-e
Re: parts needed for ta22 auto to manual swap Tue, 28 December 2004 08:55 Go to previous messageGo to next message
my work is on the net since i do cable tech support and then i get home and back on the net... i get bored at work so im always roaming the forums Very Happy
Dale_ta22
Forster NSW
Re: parts needed for ta22 auto to manual swap Thu, 30 December 2004 07:58 Go to previous messageGo to next message
Sounds like you have it covered! I did this to mine just two weeks ago now, pretty straight forward.
You'll need to short the neutral start switch (near where the reverse lights plugin, in the engine bay) which is as simple as pluging the two connectors into each other. And you'll also need to cut the shifter hole to go further forward (toward the firewall) as that's where it comes through.
Oh, you'll also need a spigot bearing as the auto doesn't have one
parsi
Epping, Sydney.
Re: parts needed for ta22 auto to manual swap Fri, 31 December 2004 01:52 Go to previous messageGo to next message
cheers,
thanks for the advice dale. Fade-e has already hooked me up with flywheel and tailshaft now all i need is a centre console...
can anyone help me out here.
cheers.
hugh.
juzzo84
Hornsby, N.S.W
Re: parts needed for ta22 auto to manual swap Sat, 01 January 2005 07:33 Go to previous messageGo to next message
i have a centre console!
0421822438
justin
chutz_pah
geelong
Re: parts needed for ta22 auto to manual swap Sat, 01 January 2005 11:14 Go to previous messageGo to next message
make sure you keep the old auto tailshaft as if you ever want to upgrade to a W series supra gearbox, i'm told that the auto one matches up almost perfect.
roadrunner
Hornsby, Sydney
Re: parts needed for ta22 auto to manual swap Sun, 02 January 2005 01:57 Go to previous message
i have the lot. I'm stripping a manual car at the moment.
0421 846 346
Previous Topic:wtd: seats for 1977 Ra23
Next Topic:Snowboard
Current Time: Wed Oct 28 05:18:28 UTC 2026
Total time taken to generate the page: 0.0080211162567139 seconds
