Toymods » Tech & Conversions » flow rate for 7KE injectors?
flow rate for 7KE injectors? Tue, 28 December 2004 14:53 Go to next message
hey All,
i've had a little trouble finding the flow rate of toyota 7KE injectors, as used on the Townace SBV.
they are light green in colour and made by Aisan. and look like:
http://www.aisan-ind.co.jp/product/inj.jpg
any toyota techs out there have access to the flow data in service specs for the Townace SBV (K?42).
i think they are around 180-210, and know i could get them serviced and flow tested, but would like to get a better idea before laying out cash on them.
thanks in advance
Re: flow rate for 7KE injectors? Fri, 31 December 2004 01:30 Go to previous messageGo to next message
anyone?
da_snuff
Hobart
Re: flow rate for 7KE injectors? Mon, 03 January 2005 08:08 Go to previous messageGo to next message
thought id bump this one back up coz im also curious if someone knows the flow rate of the 7ke and the 4ke injectors respectively???
Re: flow rate for 7KE injectors? Mon, 03 January 2005 10:58 Go to previous messageGo to next message
the green top 4KE injectors are meant to be 145cc/min. good enough for a 1.3L to reach 6000-6500rpm with high VE
da_snuff
Hobart
Re: flow rate for 7KE injectors? Tue, 04 January 2005 02:50 Go to previous messageGo to next message
hmmmm, so they wouldnt be real good on my 5k then? im guessing the 7k ones would fit the same fuel rail?? maybe should track down some of them...
sorry bit of a thread jack here, but thanks for the help
Re: flow rate for 7KE injectors? Tue, 04 January 2005 07:47 Go to previous message
well that depends on how much air your 5K will use and what rpm you will run to.
7KE injectors are physically thinner (they are AISAN injectors, hence the reason for this thread), but will vaguely fit in the 4KE rail..
why use them when you can use any other of the toyota injectors? ie 4AG, 7MG etc etc...
so anyone know the flow rate of the 7KE injectors?
i will probably measure it myself, but would prefer not to set myself on fire if possible....
Previous Topic:Need help find this sensor for my mates GT4 Group A!!
Next Topic:fuel pumps ..what should i get
Current Time: Sun Nov 22 03:04:44 UTC 2026
Total time taken to generate the page: 0.01313591003418 seconds
