Toymods » Tech & Conversions » w5* input spline
matt_84
Ipswich
w5* input spline Wed, 29 December 2004 05:59 Go to next message
I have just bought an alloy case 5 speed box from the wreckers (he thought it was from an ra60, but couldn't be sure), and of course, the spline on the clutch plate is too big to fit on the input spline. My question is; do different versions of the w55/57's have different input splines, or is the clutch plate (to suit a 1ggte) I have, the wrong type?
EDIT: The box has a mid-type shifter position, if that helps identify it at all.
[Updated on: Wed, 29 December 2004 06:12]
Mr Revhead
nelson, new zealand
Re: w5* input spline Wed, 29 December 2004 07:06 Go to previous messageGo to next message
i was of the impression all w55 boxes had the same spline...
on a similar note does any one have a list of spline counts and measurements?
iv found various applictaion lists but no actual spline counts.
matt_84
Ipswich
Re: w5* input spline Wed, 29 December 2004 07:09 Go to previous messageGo to next message
Well both the input shaft, and the clutch plate have 21 splines, but the clutch is around 30mm diameter, and the input shaft is around 22mm.
matt_84
Ipswich
Re: w5* input spline Wed, 29 December 2004 07:26 Go to previous messageGo to next message
1st definitive and helpful answer will get $1 transferred to their bank account Very Happy
Re: w5* input spline Wed, 29 December 2004 07:45 Go to previous messageGo to next message
ALL W40/W50/W55/W57/W58 boxes have the same spline.
I've used the same clutch plate on a W40 and W50.
Then used that input shaft as a clutch aligning tool to the clutch which is now in my W57.
30mm sounds about right, but its not with me to check.
Tell me what box you have.
Sounds like it could be the wrong one.
But its just as likely that the clutch is wrong.
http://www.oz-enet.com.au/~peewee/yoda_5spd_boxes. html
matt_84
Ipswich
Re: w5* input spline Wed, 29 December 2004 07:57 Go to previous messageGo to next message
Grrr... I think its a T50. I think I should have slept some more after work before going shopping.
http://members.optusnet.com.au/bamdick/P1010003.jpg
No sandwich plate. Geez i'm annoyed now. Mad
Re: w5* input spline Wed, 29 December 2004 08:04 Go to previous messageGo to next message
Take it back
Swap it for an RA60 box.
matt_84
Ipswich
Re: w5* input spline Wed, 29 December 2004 08:07 Go to previous messageGo to next message
Yep, I will be. When I rang the guy after I got home, he assured me it was from an ra60. Tool. Mad
So where do you want your $1 sent, CrUZsida? Smile
[Updated on: Wed, 29 December 2004 08:08]
Re: w5* input spline Wed, 29 December 2004 08:10 Go to previous messageGo to next message
matt_84 wrote on Wed, 29 December 2004 16:07
Haha
Give it to the wrecker
matt_84
Ipswich
Re: w5* input spline Wed, 29 December 2004 08:24 Go to previous messageGo to next message
Haha, ok, i'll keep it.
Thanks for the help.
Re: w5* input spline Wed, 29 December 2004 09:40 Go to previous messageGo to next message
matt- this will help identify gearboxes:
http://www4.tpgi.com.au/users/loats/technical/ma61 /gearboxes.html
(thanks to ed_ma61)
at first glance of your pic, the lack of centre plate (be it alloy as found in my/wilbo's/etc supra gearboxes; or steel) says not W5x
maybe shove the dollar coin up the wreckers butt?
damn... so like me you had a mostly fruitless day wasted at wrecking yards?
cheers, charles.
matt_84
Ipswich
Re: w5* input spline Wed, 29 December 2004 10:05 Go to previous messageGo to next message
Hehe, I didn't spend too long at the wreckers, just the phone call before hand, and came to pick it up. Perhaps not being there long was part of the problem, I only had a cursory look at the box (yep, its alloy, out of an RA60 you say? great) and threw it in the car.
Once it was home, I noticed alot of things wrong with it. Not a happy chappy. Just glad it was the local wreckers, not wacol or oxley or something.
I'll be going on a scavenge tomorrow, most likely, anything you'd like me to look for at Ipswich ABC?
Re: w5* input spline Wed, 29 December 2004 11:47 Go to previous messageGo to next message
i'm still looking for plugs for the 4agze injectors... Wink but there's nothing at ABC (tried both today)
anyone know what uses same plugs as them?
matt: do you have the link to pics of different kinds of toyota injector plugs?
(sorry for the flagrant post hijack)
cheers, charles.
matt_84
Ipswich
Re: w5* input spline Wed, 29 December 2004 12:09 Go to previous messageGo to next message
This one?:
http://www.geocities.com/MotorCity/Pit/9975/dataBy Subject/Injectors.html
Re: w5* input spline Wed, 29 December 2004 12:26 Go to previous message
thats the one! sorry i did't look over at Helene and matti's site - i thought they only had pics for engines...
correction: (i was wrong) - i'm actually after 4 x type E plugs.
fwiw, there's a 3sge celica in the front section of the other ABC (intact except for radiator) with a $1500 price tag on it.
cheers and thanks!
[Updated on: Wed, 29 December 2004 15:22]
Previous Topic:Turbo compatibility
Next Topic:High Pressure / Hydraulic Hoses
Current Time: Fri Nov 20 18:00:10 UTC 2026
Total time taken to generate the page: 0.031299114227295 seconds
