Toymods » Tech & Conversions » hilux diff ----> celica question
brett_celicacoupe
townsville NQLD
hilux diff ----> celica question Wed, 29 December 2004 07:57 Go to next message
gday,
i have searched but found nothing on this topic.
i kno of a hilux that i can get the diff for a hilux/celica diff conversion. the hilux is LN40 (diesel) and has a G series diff, 5 stud.
so my question is,
1. are all the G series diffs the same? this diff may not need to be as strong as the other G diffs seeing as it is only a piss weak diesel engine pushing it....correct me if im rong
will this diff be suitable for a conversion into my RA440 celica??
thanx
brett
[Updated on: Wed, 29 December 2004 08:07]
rob_RA40
c'town, NSW
Re: hilux diff ----> celica question Wed, 29 December 2004 07:58 Go to previous messageGo to next message
brett_celicacoupe wrote on Wed, 29 December 2004 18:57
gday,
impossible
brett_celicacoupe
townsville NQLD
Re: hilux diff ----> celica question Wed, 29 December 2004 08:01 Go to previous messageGo to next message
rob_RA40 wrote on Wed, 29 December 2004 18:58
gday,
impossible
well my first question is what i am really asking
'are all the G series diffs the same??'
TA-022
Glenmore Park, NSW
Re: hilux diff ----> celica question Wed, 29 December 2004 08:34 Go to previous messageGo to next message
http://forums.toymods.org.au/index.php?t=msg&t h=16645&start=0&rid=5072&S=e3425b71231 6517e480ff01dfd179492
and no ther not all the same.
i know that a rn20 hilux diff is 1370mm wide but a rn25 goes out to 1470mm wide.
strength wise i dont know i guess that would be a combination of centres and axles?
Nathan
PS on that note any1 know where to get a rn20 diff?
[Updated on: Wed, 29 December 2004 08:37]
brett_celicacoupe
townsville NQLD
Re: hilux diff ----> celica question Wed, 29 December 2004 09:59 Go to previous messageGo to next message
does any1 kno the width of that specific diff??
and the ra40 diff width to compare
thanx
brett
gold28
Madrid - Spain
Re: hilux diff ----> celica question Thu, 30 December 2004 08:34 Go to previous messageGo to next message
Grab a ruler and measure up some diffs. I think the RA40 is 1410mm wide, this should be the same as most of the Hilux diffs.
The diff code "G" specifies the crown wheel size. As far as I know, all the G series have the same size axles, but I am not sure. I know that the axle sizes do vary in other size diffs. Some of the G series diffs have a 4 pinion centre and others just a 2 pinion. Obviously the 4 pinion is stronger.
ra23celica
Re: hilux diff ----> celica question Thu, 30 December 2004 12:03 Go to previous messageGo to next message
I have fitted a late 90's Hilux Surf G series 4.3 LSD into a RN25 axle and it slid and bolted together beautifully. And yes, as far as I know, the LN/RN 30 - 40 series axles are the best width to suit a RA40 Celica.
Mitch.
brett_celicacoupe
townsville NQLD
Re: hilux diff ----> celica question Fri, 31 December 2004 02:09 Go to previous messageGo to next message
ok thanx alot ra23celica. i thought my ra40 diff is 1410mm wide but wasnt quite sure, this will be perfect then if i get that diff Smile
thanx 4 the help
brett
CelicaRA45
nth ringwood, Victoria
Re: hilux diff ----> celica question Fri, 31 December 2004 02:15 Go to previous messageGo to next message
brett try to find a mx23 rear end it has a F series which would be better and it is the same length as your 1 know. also try the msseries crowns as well early 1 had 4stud later had 5 stud same size diff again as the mx23 series m2
Re: hilux diff ----> celica question Fri, 31 December 2004 02:19 Go to previous message
ALL Crowns had 5 stud (although I can't be sure about RS10-30 but they're pre 1960).
Good luck finding an MX23 - the 3 Daves in Melbourne are buying them all. Laughing
Best bet remains the MS112 diff. Already has disc brakes.
Previous Topic:4piston brakes for a st162
Next Topic:AE86 T series Axels, drum and disc
Current Time: Fri Nov 20 15:31:02 UTC 2026
Total time taken to generate the page: 0.053839206695557 seconds
