Toymods » Tech & Conversions » ae82 cv boot replacement
bobob
adel
ae82 cv boot replacement Thu, 30 December 2004 01:09 Go to next message
Hey,
I am trying to replace the split outer CV boots on my car. I now know why the boots are $45 and the new CVs are $300, the job of replacing the shaft is much easier than the boot!
I have pulled the shaft out of the hub and taken (OK cut) the old boot off. I can see all the bearings etc in the joint. I cant work out how to put the narrow end of the boot on because I cant work out how to pull the joint appart.
Am I looking for a circlip or something in the joint?
Does anyone have an exploded diagram of a rolla CV?
Or can quickly explain what to do next?
While I start the other side!!
tanman
Re: ae82 cv boot replacement Thu, 30 December 2004 01:16 Go to previous messageGo to next message
you will need circlip pliers
HighRolla
Re: ae82 cv boot replacement Thu, 30 December 2004 01:19 Go to previous messageGo to next message
If there's not too much crap in there you can just clean it up and use a stretch type boot so you dont have to seperate the joint. Turner driveshafts at brookvale have them. The boot is $20 and the cone that allows it to slip over is about $25.
ALso get the tool to do up the steel bands.
http://www.turnerdriveshafts.com.au/how2_cvbootkit .htm
[Updated on: Thu, 30 December 2004 01:21]
bobob
adel
Re: ae82 cv boot replacement Thu, 30 December 2004 02:22 Go to previous messageGo to next message
I cant see wherer to put the circlip pliers Sad
I am in Adelaide, its also a bit hard to drive now! If I knew that this bit was going to take as long as it has I would have ordered the strechy boots over!
bobob
adel
Re: ae82 cv boot replacement Fri, 31 December 2004 08:29 Go to previous message
thank you,
I took the inner off / appart and there was the circlip!
knock the inner bearings off the shaft, slide old boots off, new boots on, regrease, reassemble.
done!
Previous Topic:1g-gte reverse lights
Next Topic:Anybody know about the 1G-GTE????
Current Time: Fri Nov 20 10:39:43 UTC 2026
Total time taken to generate the page: 0.0063598155975342 seconds
