Toymods » Tech & Conversions » AE86 T series Axels, drum and disc
drift86levin
brisvegas
AE86 T series Axels, drum and disc Thu, 30 December 2004 07:49 Go to next message
just a quick kinda urgent question..are the T282 drum and T282 disc Axels the same? is there any differences at the axle flange?
thanks..
[Updated on: Thu, 30 December 2004 07:50]
CLG
Perth, Western Australia
Re: AE86 T series Axels, drum and disc Thu, 30 December 2004 14:03 Go to previous messageGo to next message
Yep they have different bearing faces, and dependant on which diff they come from, will also be a different length. Nice try though.
drift86levin
brisvegas
Re: AE86 T series Axels, drum and disc Fri, 31 December 2004 00:30 Go to previous messageGo to next message
it's a disc T282, and the axel would be coming from a drum T282, is it the bearings them selfs? the length should be right..
[Updated on: Fri, 31 December 2004 00:30]
mr2drift
Re: AE86 T series Axels, drum and disc Fri, 31 December 2004 00:43 Go to previous messageGo to next message
hey man, you'll find that the drum spec bearings are actually narrower than the disc spec ones, but they should still fit, you just cant use the disc spec ones in a drum spec housing. not sure about the end plates but 90% sure they are the same Laughing
TerryOBeirne
Redbank Plains,near Ipswi...
Re: AE86 T series Axels, drum and disc Fri, 31 December 2004 01:24 Go to previous messageGo to next message
the disc brake axles & retaining plates are different to the drum axle versions. the overall axle length is the same. some drum brake axles dont have enought room to take the wide disc brake bearing, and some do. the later disc brake axles have a larger spline
drift86levin
brisvegas
Re: AE86 T series Axels, drum and disc Fri, 31 December 2004 01:38 Go to previous messageGo to next message
i'll try tonight..it's for a mates car, i have a an 86 AE86 with a T282 LSD, and it has the same spline as an RA40 81' T292 single spinner..just something interesting...
drift86levin
brisvegas
Re: AE86 T series Axels, drum and disc Fri, 31 December 2004 01:43 Go to previous messageGo to next message
can the retaining plates be changed? it doesn't realy look terribly easy!
TerryOBeirne
Re: AE86 T series Axels, drum and disc Fri, 31 December 2004 01:56 Go to previous messageGo to next message
to change the retaining plates you have to remove the bearing which means destroying the shrink ring . thay come as part of the hub bearing kit. it is not clear what you are trying to do. I have a workshop in ipswich if thats any help. we press bearings on/off axles regularly. not very hard, just takes a while to do properly. many we get have bucked drive flanges due to fools trying to bash them apart. some we can re-machine, others are junk
drift86levin
brisvegas
Re: AE86 T series Axels, drum and disc Fri, 31 December 2004 02:01 Go to previous message
well the plan is..if the drum T282 axel has the right spline..i will grab that axel, and the disc T282 axel (bent flange plate) and swap the retaining plates over..and my mate gets to keep his disc rear end!
obviously were using new bearings..
Previous Topic:hilux diff ----> celica question
Next Topic:TruTrac LSD in my AE86
Current Time: Fri Nov 20 15:51:15 UTC 2026
Total time taken to generate the page: 0.0052030086517334 seconds
