Toymods » Tech & Conversions » MX83 Cressida thermo fans
cressida_1jz
On Probation
MX83 Cressida thermo fans Thu, 30 December 2004 09:11 Go to next message
does anyone have any info on the best way for a thermo fan conversion to a 1j cressida.
IRA11Y
Club Member
Re: MX83 Cressida thermo fans Thu, 30 December 2004 09:52 Go to previous messageGo to next message
just wire it up to the thermo switch that runs the smaller fans, im sure theres a thermo switch on the 1J somewhere for the fans, should be pretty straight foward if you use the factorypickup points from the relay
cressida_1jz
On Probation
Re: MX83 Cressida thermo fans Thu, 30 December 2004 13:16 Go to previous messageGo to next message
what kind of thermos do u have.did u use the standard radiator from the mx83
cressida_1jz
On Probation
Re: MX83 Cressida thermo fans Thu, 30 December 2004 13:29 Go to previous messageGo to next message
thanks for the info man.where you from?what type of cressida do u have.mine is a 91 grande.cheers
sideshow
Re: MX83 Cressida thermo fans Thu, 30 December 2004 21:34 Go to previous messageGo to next message
1j have no fan switches
some 1j's have a hydraulic fan settup but this is conrolled by another ecu
just fit a thermo switch somewhere then fit the biggest signel fan u can fit
say like a 14in or 16 in
one big fan is usually better than 2 small ones
V8_MA61
Re: MX83 Cressida thermo fans Sat, 01 January 2005 12:57 Go to previous messageGo to next message
Can you weld? If so, make up a bracket and mount two of the biggest baddest fans you can possibly fit in there....I made up a bracket and bolted my ma61 radiator and 13+14" fans into my ma70...and they work perfect...
V8_MA61
Re: MX83 Cressida thermo fans Sat, 01 January 2005 12:59 Go to previous messageGo to next message
im also doing this for my ma61, it has a 4 core chev radiator in it, with a 16 and a 14" fan...and they are pretty damn hardcore...
SIMDOG
Bayside Melbourne.
Re: MX83 Cressida thermo fans Mon, 11 April 2005 13:56 Go to previous message
check out the thread on http://www.thermactor.com/forum There is a bit of discussion about different thermo fan setups people have used on Cressidas. Do a search on that forum. Smile
Previous Topic:check valve on stock 1JZ BOV
Next Topic:Welding chassis
Current Time: Fri Nov 20 12:11:16 UTC 2026
Total time taken to generate the page: 0.022642850875854 seconds
