Toymods » Tech & Conversions » Celica CV
toof
Celica CV Thu, 30 December 2004 10:39 Go to next message
just a quick q. the left outer cv boot on my st184 has given up the ghost. ive bought a new boot and was in the process of dissasembling it today when i realised i didnt have a big enough socket to whip the hub nut off. that problem will be solved tomorrow im borrowing a mates sockets who does have one big enough.
is there any siggestions on what/how i should pull things apart to just change the boot.
HighRolla
Re: Celica CV Thu, 30 December 2004 10:53 Go to previous messageGo to next message
Search around a bit... this is what I posted before, hope it may help:
If there's not too much crap in there you can just clean it up and use a stretch type boot so you dont have to seperate the joint. Turner driveshafts at brookvale have them. The boot is $20 and the cone that allows it to slip over is about $25.
ALso get the tool to do up the steel bands.
http://www.turnerdriveshafts.com.au/how2_cvbootkit .htm
toof
Re: Celica CV Thu, 30 December 2004 11:03 Go to previous messageGo to next message
hmm that reads almost like a cut/paste of your other CV post Razz
ive already bought a standard boot. i was just more interested in actual dissasembly procedure.
HighRolla
Re: Celica CV Thu, 30 December 2004 11:17 Go to previous message
That was precisely it.
If you are able to use a stretch boot there is not much to it.
Undo bolts to hub (you can leave steering arm attached), including 2 strut bolts and in the case of my corolla there were 2 or 3 little bolts that bolted the hub to lower control arm. Where people find it difficult is seperating the joint itself (need to put in vice etc), once you get the shaft out of the car (which I have not done). If you use the stretch boot the shaft doesn't need to come out of car.
http://home.swiftdsl.com.au/~benl1981/corolla/CV%2 0Boot%20Replacement/CV_boot_replacement.htm
Previous Topic:RDA Slotted Rottors 2CM Smaller than Stockersr??? WTF!
Next Topic:Weber Carby Kit for my 6AFC.
Current Time: Fri Nov 20 18:44:33 UTC 2026
Total time taken to generate the page: 0.0043489933013916 seconds
